    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Strange HR recording with Burner selected
    Scheduled Pinned Locked Moved Suunto 9 Peak
    16 Posts 4 Posters 2.1k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • TonyGT Offline
      TonyG Silver Members
      I have been getting some strange things happening to the recorded HR values when I use the Suunto + Burner app, the strangeness appears to be triggered when I pause the activity (on this occasion when I crossed a busy road).
      couple of things I noticed when out on the watch.
      the HR Zone outer circle got stuck on blue half way through the activity (zone 1) even though the watch was showing the correct HR when I was running 140 - 154 (zone 2 / 3)
      and appears to be represented in the HR chart?? see below
      but the zone values on the app appear to be correct as does the average Hr 142 for the entire recorded activity See above and below for zones %
      the splits within the app i.e every 1km seem to be correct also except split 10 where 99 average was recorded (this is where I think the pausing of the activity triggered the strangeness) see below 2 images
      the auto export to strava shows the recorded HR as it is in the chart and as such give average HR as 107 which is def wrong,
      confused as to what has gone wrong here with the data
      I have sent logs to suunto via the link in the app but didnt get any sort of reference number to share 😞
      I should add, this is the second time this has happened both when using the burner suunto + app.
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
        Dimitrios Kanellopoulos Community Manager @TonyG
        @tonyg do you have a link ? On Strava how does the hr look like?
        Was that a belt ?
        Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
        TonyGT 1 Reply Last reply Reply Quote 0
        • TonyGT Offline
          TonyG Silver Members @Dimitrios Kanellopoulos
          @dimitrios-kanellopoulos The HR on Strava looks like the chart on SA and as such gives 107bpm Average,
          here the link to SA,
          https://www.suunto.com/move/tonygray190/61740232111b7c1dbf59247b
          Strava
          https://strava.app.link/vVnV2ZxLAkb
          yes this was a chest strap
          Interestingly I have just read on Facebook group a chap with same or similar issue
          https://www.facebook.com/groups/SuuntoAmbit/permalink/4455281987897163/
            @tonyg was that a polar h10 ?
            • TonyGT Offline
              @dimitrios-kanellopoulos yes!
                @tonyg please share with me in pm the link. I have a possible explanation for this if I am correct.
                However I guess this is HRV / RR data issue.
                It’s been explained a couple of times and I think if you load the file on QS you will see the same result.
                The problem is that when the belt looses good readings RR data are only few creating a low heart rate.
                But then I have the question. Did you see on the watch the correct heart rate but only later in the app you have this issue ?
                • TonyGT Offline
                  @dimitrios-kanellopoulos throughout the run I saw good Hr reading on the watch, only once did i see a low hr reading, and that was after pausing the activity to cross the road, when i un-paused it it showed 55hr but very quickly (10 seconds or so) climbed back to 147bpm (where it should have been).
                  apologies, what link would you like shared?
                  Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 1
                    @tonyg pm the link please. 😅
                      @tonyg will be taking a look next week though so take your time.
                      • TonyGT Offline
                        @dimitrios-kanellopoulos sorry, not sure what link would you like pm’d
                        I thought I supplied them all in an earlier post.
                        • zhang965Z Offline
                          zhang965
                          I’ve got some weird noise
                          Winners Wear Winners
                            I found the issue.
                            • EgikaE Offline
                              Egika Platinum Member @Dimitrios Kanellopoulos
                              @dimitrios-kanellopoulos and it is?
                                Dimitrios Kanellopoulos Community Manager @Egika
                                @egika at some point it looks like the h10 stops broadcasting RR / IBI data (HRV) that we use to create the HR and switches to HR samples and quite a few HRV samples.
                                It looks like an h10 edge case (both users have the same belt) so I am not sure how this should be fixed
                                TonyGT 1 Reply Last reply Reply Quote 2
                                • TonyGT Offline
                                  @dimitrios-kanellopoulos would this be the case for all belts sold and used, I wasnt sure if all belts recorded or broadcast R-R data, so is the watch displaying a different value, as it was displaying the correct Hr Value throughout the activity and I was checking alot due to having this issue on a previous activity.
                                  Is it related to using the burner app? or would a drop in R-R data have this issue regardless.
                                  many thanks for exploring and discovering the issue.
                                  T
                                    @tonyg not realted to burner. Just your belt stops broadasting RR / HRV and switches to normal HR.
                                    • TonyGT TonyG referenced this topic on
                                    Register Login
                                    • First post
                                      Last post
                                    Suunto Terms | Privacy Policy
