    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Is my S9P deteriorating?
    Scheduled Pinned Locked Moved Suunto 9 Peak
    9 Posts 4 Posters 1.0k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Theo LakerveldT Offline
      Theo Lakerveld Bronze Member
      Hi, during the past couple of weeks my S9P is missing it’s edge. Battery life is getting worse (-45% in three days with ~3,5 hours of running, no sensors connected, no phone notifications), GPS loss (105 km ride is registered as 91 km ride with a lot of straight lines where I followed trails, the same was happening during the latest runs) and swimming counting lengths incorrectly (2100m is showed as 2700m). Well, it seems something is not correct and I will return it. Has anyone else seen this behavior?
      Previously used: Cyclosport HAC4, Polar S710, Ambit 2S, Ambit 3S, SSU, S5P, S9P Ti. Currently using: Race Ti.
      isaziI cosme.costaC 2 Replies Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @Theo Lakerveld
        @theo-lakerveld mine is performing as well as usual. For the GPS, are you using Galileo?
        Blog: isazi's home
        Theo LakerveldT 1 Reply Last reply Reply Quote 0
        • cosme.costaC Offline
          cosme.costa @Theo Lakerveld
          @theo-lakerveld I do not have a S9P but I do have and S9B and I guess in general they are not very different.
          First thing I would do is a soft-reset just in case, press upper button for 12/15 seconds. Then I would check that I do not have any custom battery mode that makes that the GPS is not using GPS best.
          If nothing of this works then I would contact support.
            Theo Lakerveld Bronze Member @isazi
            @isazi I didn’t change the settings lately and it has been quite flawless since i got it in July. I’m using GPS+QZSS+Galileo.
            isaziI 1 Reply Last reply Reply Quote 0
              Theo Lakerveld Bronze Member @cosme.costa
              @cosmecosta Yes, I’ve done the soft reset. That didn’t change anything.
              • isaziI Offline
                @theo-lakerveld right there are BIG issues with Galileo in this firmware, should be fixed in the next version, please use something else for now on (I have good results with Beidou in NL).
                Blog: isazi's home
                  Dimitrios Kanellopoulos Community Manager
                  We didn’t change anything that could have affected the battery.
                  However if you have not done a battery calibration after the update this could well be the reason.
                  So:
                  • Run the watch down to 0%
                  • Charge to full 100%
                  See if it drains fast
                  Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                    @isazi Thanks, I’m now changing to Beidou and checking if this helps.
                      Theo Lakerveld Bronze Member @Dimitrios Kanellopoulos
                      @dimitrios-kanellopoulos Thanks, I’ll drain the battery completely and see if this helps.
                      Register Login
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
