    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    backlight
    Scheduled Pinned Locked Moved Suunto 9 Peak
    30 Posts 9 Posters 2.7k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • A Offline
      alexej19
      hi, the funktion backlight on my suunto 9 peak thas not work properly - what could be the problem. my prefernce is _>Raising your wrist in regular time mode or during an exercise will activate backlight.
      where could be the proplem…it is very important that it works. I switched form suunto 9 baro, where it works perfectly. thnx alexander
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Online
        isazi Moderator @alexej19
        @alexej19 can you show your configuration and what is the issue you are experiencing? Do you want the screen to be dark all the time and only wake up on raise to wake?
        Watch: Suunto Vertical Ti
        Blog: isazi's home
        A 1 Reply Last reply Reply Quote 0
        • A Offline
          alexej19
          i would like if i raise the watch that there is blacklight. I tried all the different settings.
          my current setting is: On: Raising your wrist in regular time mode or during an exercise will activate backlight.
          and Standby: adaptiv
          generall backlight: off
          thanks for help
          • I Offline
            ist-1973
            Suunto 9. The “Raising the wrist” function is enabled. In training mode, it turns on the backlight. Does not turn on the backlight in normal mode.
            Does it work for other users?
            • A Offline
              alexej19 @ist-1973
              @ist-1973 hi it does not work. i m using again my old watch suunto 9 there it works properly.
              • A Offline
                alexej19 @isazi
                @isazi
                A
                alexej19
                6 days ago
                thanks for help
                • isaziI Online
                  @alexej19 I’ll test if it works for me, i use raise to wake only during exercise and it works there.
                  Blog: isazi's home
                  • A Offline
                    alexej19 @isazi
                    @isazi the problem is during the nightruns and also in the night if there is the mode don’t disturbe the raise modus doesn’t work. this problem is with the suunto 9 not.
                    • isaziI Online
                      @alexej19 so this issue only happens if you have DND (do not disturb) active?
                      Blog: isazi's home
                      • A Offline
                        alexej19 @isazi
                        @isazi yes. for instance i have don’t disturb (for the simple reason not to get all the msg) from 20-7:30 and in that time the function rise doesn’t work. in the night if i like to see the time also therefore i have to press a buttun. which is not ideal. in any case, even if the not disturb mode is switched on the sensitiveness of “raise” is verry bad. Sorry for that. in any case i like the suunto brand very much and will not change. but such bugs are not soo good
                        isaziI 1 Reply Last reply Reply Quote 1
                        • isaziI Online
                          @alexej19 well this is how it is supposed to work, no? With DND backlight should not work unless a button is pressed. As for sensitivity, yes it is not good enough.
                          Blog: isazi's home
                          • A Offline
                            alexej19 @isazi
                            @isazi no it should work if you rise it (as on the suunto 9) even if it is not disturb light should go on…otherwise you always have to press a button in the night, during sleeping when the what is on your table beside the bed.
                            • isaziI Online
                              @alexej19 it should not do that also on the S9. It has been fixed in the next firmware. With DND no light is on unless you press a button.
                              Blog: isazi's home
                              • EgikaE Offline
                                Egika Platinum Member
                                Let’s call it “by design”. By design the light should not come on with raising the watch during DND.
                                Maybe someone would like to have it in a different way, but this is what Suunto’s engineers have planned. Reason is for the light to stay off, if you turn in your bed wearing the watch.
                                t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
                                A 1 Reply Last reply Reply Quote 1
                                • A Offline
                                  alexej19 @Egika
                                  @egika yes ok thanks. it is understandable during night by turning. but, many don’t wear the whatch in the night but leave it beside the bed and if they press the wrong button (no the middle one) the whatch turns in sport modus or in heart monitoring…so you wake up ;-). i suggest a solution: in DND modus that backlight could be switched on (force backlight on). so in the night if you lift the watch it switches on and after you leave it down on you table beside after a few seconds it switches in any case off. I handle it at the moment that way, before i sleep i force the backlight on manualy. I don’t understand why suunto 9 it worked automatically.
                                  • Jan SkolimowskiJ Offline
                                    Jan Skolimowski
                                    Hi
                                    Raise to wake does not work. I do not have DND on, but still not working. I have to press center button to wake watch. I just got the watch. Is it connected to the latest update?
                                    • Brad_OlwinB Offline
                                      Brad_Olwin Moderator @Jan Skolimowski
                                      @jan-skolimowski How is your watch set in Settings?
                                      Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing
                                      Jan SkolimowskiJ 2 Replies Last reply Reply Quote 0
                                        Jan Skolimowski @Brad_Olwin
                                        @brad_olwin
                                        Backlight:
                                        Brightness - High
                                        Standby - Adaptive
                                        Raise to Wake - On
                                          @brad_olwin hi, any ideas?
                                            @jan-skolimowski soft reboot watch. I have two S9 Peaks and both are working fine for backlight.
                                            Jan SkolimowskiJ 1 Reply Last reply Reply Quote 0
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
