    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery saving mode.
    Scheduled Pinned Locked Moved Suunto 7
    30 Posts 5 Posters 4.5k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • olymayO Offline
      olymay Gold Members
      @Kajkom I have just put my S7 into battery saver manually in order to test it’s operation (i had to do it manually as I haven’t it fall into this mode in months so can’t remember how it works).
      When in battery saver, the screen activates when I raise my wrist, or press the home/power button. The three buttons on the right hand side do nothing.
      The brightness seemed set around mid brightness and did not change when I moved from bright light to dim light.
      The battery indicator was roughly at the mid point, yet in WearOS it shows it to be at 97%.
      No issues of a black screen.
      I did have to hold the home/power button for longer than I thought I would in order to turn WearOS back on again.
      @Kajkom can I ask why you use the battery saver so much? In my impression this mode is purely for the times when you are running out of battery but still need a way of telling the time. When in this mode the watch does nothing except display the time and date - even my 'plastic fantastic1 £10 Casio watch does more.
      It seems most people are getting roughly 48hrs of battery life from their S7 and it more than lasts a day. If you are needing a watch to last longer than this (due to being away from a charger for extended periods) then maybe a WearOS device isn’t for you? If you prefer the battery saver mode, than you have bought a VERY expensive digital watch that does nothing but tell the time (buy a Casio instead as it also has timers, alarms, etc, and lasts for years on a battery).
      I’m just curious about why you use the battery saver mode so much, nothing more 🙂
      Suunto 7 Graphite Copper
      Suunto App Beta (Android - Pixel 6 Pro)
      KajkomK 2 Replies Last reply Reply Quote 0
      • KajkomK Offline
        Kajkom @Kajkom
        @kajkom
        I will write it very clearly that I do not criticize the SUUTNO brand and their products in any way, I only ask specifically about matters that concern only my copy.
        “In battery saver mode, the screen activates when I lift my wrist or press the Home / Power button. The three buttons on the right do nothing”
        The question is, how many times have you done it, for example, 1 time, 2 times a day …?
        The whole problem is the lack of repeatability of such simple functions that I write about.
        • KajkomK Offline
          Kajkom @olymay
          @olymay
          Everyone has the right to use the watch in the way they want and it is given by the manufacturer, but the functions they provide will be repeatable, so with the Casio you write about, because probably every company can afford it, and especially SUNNTO.
          • KajkomK Offline
            Kajkom @olymay
            @olymay
            For me, the battery saving mode is great because it doesn’t drain it when I don’t need it and that’s it.
            olymayO 1 Reply Last reply Reply Quote 0
            • olymayO Offline
              olymay Gold Members @Kajkom
              @kajkom I was not criticising your use of the battery saver mode, far from it, I was simply trying to understand why you use it, and how often, in order to try to help.
              At face value, buying a smart watch with health and fitness tracking features but then turning it all off seems odd. But maybe you are often far away from the ability to charge the watch and need it to last multiple days?
              If you want a fitness watch that lasts multiple days, then a S9P or a Garmin might be a better option.
              If you want a smartwatch that lasts multiple days, they don’t exist yet sadly.
              I am simply confused as to why you use the battery saver mode. No criticism at all, just confusion.
              Answering your question about how often I check the raise to wake feature in battery saver mode - literally only for a few minutes whilst I checked it prior to the message I posted. I do not use the battery saver mode (I want a smartwatch that tracks my health, not a simple digital watch, I have a drawer full of them).
              I pop my watch on charge whilst I shower each day and those few minutes are more than enough to keep it with enough battery to last well over a day, I never get close to running out of battery.
              But like I said, your use case may be different and you may not be able to charge it easily, hence needing battery saver.
              I am only trying to help, please don’t think otherwise.
              • Al SaceA Offline
                Al Sace @Kajkom
                @kajkom
                hi, as I have the same problem did you already find out what the reason is? battery saver mode turns into black screen. sometimes after 2 hours sometimes 2 days.
                • KajkomK Offline
                  Kajkom @Al Sace
                  @al-sace
                  the service offered to restore the factory settings, and if it does not help, send the watch back to the service.
                  I let go of the topic …
                  Al SaceA 1 Reply Last reply Reply Quote 0
                  • KajkomK Offline
                    Kajkom @Al Sace
                    @al-sace
                    I made the recommendations of the website and it did not have any effect,
                    • Al SaceA Offline
                      Al Sace @Kajkom
                      @kajkom
                      I just ordered a new one to see if für same occurs. thank you very much for response.
                      KajkomK 1 Reply Last reply Reply Quote 0
                      • KajkomK Offline
                        Kajkom @Al Sace
                        @al-sace
                        let me know in the comment if the new one is “better”
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
