    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Ceinture cardio
    Scheduled Pinned Locked Moved Suunto 7
    10 Posts 6 Posters 1.0k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • EmbrunE Offline
      Embrun
      Bonjour,
      Existe-t-il une ceinture cardio qui puisse fonctionner avec la montre.
      Car le cardio de la montre, n’est pas fiable.
      Merci de votre aide
      Cordialement
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @Embrun
        @embrun not with the Suunto app on the watch.
        Blog: isazi's home
        EmbrunE 1 Reply Last reply Reply Quote 0
        • EmbrunE Offline
          Embrun @isazi
          @isazi Dommage
          Merci
          MdzOttM 1 Reply Last reply Reply Quote 0
          • MdzOttM Offline
            MdzOtt @Embrun
            @embrun I hope i am not reading this wrong, but any BT HR belt will work with the watch. You can use Suunto original, Wahoo, even Garmin.
            And yes, they work much more reliably. I use the HR belt 90% of the time (for all activities where HR makes sense). You need to (should?) disable the wrist HR for the activity.
            R2
            S9 Baro
            SA on Android
            Ambit 3 Peak
            Ambit 2 Sapphire
            DMytroD cosme.costaC 2 Replies Last reply Reply Quote 0
            • DMytroD Offline
              DMytro @MdzOtt
              @mdzott yeah, but not with S7 when using suunto app. There the functionality of connecting a belt is absent.
              • cosme.costaC Offline
                cosme.costa @MdzOtt
                @mdzott said in Ceinture cardio:
                On Suuntos, that can pair a HR belt/armband you do NOT need to disable the wrist HR, the watch gives always preference to the paired device. The only thing is that the HR belt or armband needs to be paired before you choose the sport you are going to practice because the watch can’t switch between wrist and belt.
                EmbrunE MdzOttM 2 Replies Last reply Reply Quote 0
                • EmbrunE Offline
                  Embrun @cosme.costa
                  @cosmecosta
                  Merci de m’avoir répondu.
                  J’ai une ceinture “Geonaute Bluetooth”, comment je fais pour l’appairer avec ma montre ?
                  cosme.costaC 1 Reply Last reply Reply Quote 0
                    cosme.costa @Embrun
                    @embrun said in Ceinture cardio:
                    @cosmecosta
                    If you have a Suunto 7 you can’t use a external HR belt, but you can use other apps that can pair external bluetooth belts (I do not know them, but I know they exist, probably battery life is going to be worse). If you use an Ambit, Spartan or S9/S9P/S5/S3 you can pair a bluetooth belt without a problem.
                    Jamie BGJ 1 Reply Last reply Reply Quote 0
                    • Jamie BGJ Offline
                      Jamie BG Bronze Member @cosme.costa
                      @cosmecosta sportygo and ghostracer used to be 2 options, plus google fit (but the app itself is very poor).
                      • MdzOttM Offline
                        MdzOtt @cosme.costa
                        @cosmecosta I did not know that. Good to know. Thanks.
                        R2
                        S9 Baro
                        SA on Android
                        Ambit 3 Peak
                        Ambit 2 Sapphire
                        Register Login
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
