    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Backlight sensitivity curiousity - S9P
    Scheduled Pinned Locked Moved Suunto 9 Peak
    11 Posts 5 Posters 1.5k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • BakxMB Offline
      BakxM
      Hi,
      Since days are getting shorter and more and more evening bike-rides end in twilight or darkness, I notice that the backlight switching of my S9P is a bit off to say the least.
      When attached to the handlebar in front of me, when darkness sets in, the switching of the watch is about every 2 to 3 seconds from bright to savemode. I can imagine that going through a bump in the road might trigger the backlight. But this is a consisent behaviour with alternating every 2-3 seconds and not being even on that. So one time it’s 3secs, after that it might be 1 sec any which way.
      Haven’t noticed this behaviour in daylight during summer time.
      When just lying around on a desk, this works as expected and only turns on when I pickup the watch. Same goes for wearing it on the wrist.
      Did I miss out on a particular setting or is this a bug ?
      Cheers, Marcel
      T6 / Stinger / Ambit / Ambit3 Peak / Spartan Ultra / Suunto9 Baro / Suunto Race / Suunto Race2
      surfboomerangS L BakxMB 5 Replies Last reply Reply Quote 1
      • surfboomerangS Offline
        surfboomerang @BakxM
        @bakxm Just a wild guess… Could it be that you’re riding under street lanterns or other light sources?
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
        BakxMB 1 Reply Last reply Reply Quote 0
        • BakxMB Offline
          BakxM @surfboomerang
          @surfboomerang nope, it’s not that dark yet for the street lanterns to be on.
          Did a quick check during the afternoon ride around 17h (still plenty of sun out), but I can’t seem to notice any difference in the backlight when there’s normal daylight.
          Will try to make a more exact time when this is starting in relation to sunset time. Though it might be dependent on cloud conditions as well I guess.
          • L Offline
            lamp21 @BakxM
            @bakxm
            similar issue.
            For my case, running in the evening with darkness. I raised my watch on my wrist, but the backlight doesn’t come up as expected. I have to do it a couple of times to get the right angle for the light to display.
            Not sure if I’m doing the correct “gesture” to turn on the light.
            my settings from “Raise to wake” is set to “Exercise only”.
            • BakxMB Offline
              BakxM @BakxM
              Did an all-dark bikeride tonight. New firmware, but still same problem.
              Backlight keeps turning on/off during the ride and because it’s on the handlebar, that’s pretty annoying
              Could be that the bumping of the bike is turning on the backlight, but I can’t find a good pattern for that based on the small bumps in the road and its asphalt all the way.
              Will try to ride with a pre-defined work-out (Cycling - Basic) in the watch this week, as the one I normally use is a custom-made work-out.
              Any advice on how to proceed ? Open supportcase ?
              • BakxMB Offline
                BakxM @BakxM
                same result , backlight turning on/off during the bikeride with different intervals every 1 to 2 secs.
                herlasH 1 Reply Last reply Reply Quote 0
                • herlasH Offline
                  herlas Silver Members @BakxM
                  @bakxm guess it wasn’t designed to work on the handler bar, I’ve experienced the same with S9B and S9P, backlight doesn’t have a pattern while on the handler bar.
                  While running, my experience is that raise to wake is very tricky to get working in current software for S9P, guess it hasn’t had it’s second iteration, who knows 🙂
                  SRS Ti
                  SRun (primarily road runner so testing SRun is a must ;))
                  A3P (drill mode for pool swimming 🤦🤷)
                  Galaxy Z Flip 3 / Galaxy S24+
                  • Brad_OlwinB Offline
                    Brad_Olwin Moderator @herlas
                    @herlas I have found that a quick raise of the arm fairly effectively turns the backlight on. Slowly raising your arm often does not trigger the backlight so it has not been tricky but does require that the accelerometer recognizes you are raising your arm.
                    Vector/T6c/Vertical 2 Ti
                    • herlasH Offline
                      herlas Silver Members @Brad_Olwin
                      @brad_olwin yeah I’ve tried some of that, still need practice to get it consistent , also when running in complete dark, I’ve seen my wrist light up while doing my normal running arm motion.
                      SRS Ti
                        @bakxm I think I found the issue.
                        It looks like the Raise-To-Wake feature isn’t really triggered by a certain arm swing pattern, but more with a sudden movement in any direction. The backlight even turns on if I move my wrist away from me instead of towards me.
                        Today I noticed that if I level the watch (face up) and very shortly lift it up and down keeping the watch level, the backlight also turns on. This is the same movement when you mount the watch on your bike with a handle bar mount and your bike is a little bit shaking because of the road.
                        The movement you have to make is very light so this could explain the watch is constantly turning on and off the backlight. Try mounting the watch on your wrist and don’t touch the handle bar with that arm. I think the backlight will stay off then
                        Maybe Suunto will address this is upcoming firmware…
                        OnePlus Nord 4
                        • BakxMB Offline
                          BakxM @BakxM
                          Just a short note on a very old annoyance 🙂
                          This issue is fixed since last weeks fmw update.
                          Backlight now stays off when watch is positionend on handlebar, during bikeride.
                          Much appreciated, but wondering if this was an actual RFC or by accident 😄.
                          1 Reply Last reply Reply Quote 3
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
