    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Barometric sensor malfunction on my Suunto Ambit3 Peak?
    Scheduled Pinned Locked Moved Ambit
    17 Posts 11 Posters 4.1k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • casimirovC Offline
      casimirov
      Hi, I have had a Suunto Ambit3 Peak for about 4 years now and for the past few weeks I have been having problems measuring altitude and Atmospheric Pressure.
      I have always had the watch properties with active in the Automatic Profile and FusedAlti on and always with Reference with auto adjustment, having always worked well until a few weeks ago.
      In the last few days I have never been able to have temperature values ​​or Atmospheric pressure and the altitude values ​​are always out of adjustment, even during an exercise with the GPS active. I’ve tried everything to fix this, I’ve reset the clock, restarted the clock and even cleaned the area next to the clock, and unfortunately everything remains the same. Did the Barometric sensor break down? If so, it’s worth worth fixing? What can I do? since I have this malfunction, my trainings have incorrect and even non-existent altimetry values. I look forward to your help. Thanks!
      isaziI ? H S 4 Replies Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @casimirov
        @casimirov contact support for this.
        Blog: isazi's home
        casimirovC 1 Reply Last reply Reply Quote 0
          casimirov @isazi
          @isazi ok Thanks! Do you know if the possible repair of the sensor is too expensive.
          The watch have 4 years, and now there are newer watches. Will it pay to try the repair? If you buy a new watch, is suunto still a good option? Thanks
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            @casimirov I am sure Support will be able to tell you how much does it cost for repair, I don’t know. I do not own an Ambit, I have a Suunto 9 Peak.
            Blog: isazi's home
              casimirov @isazi
              @isazi and you recommend the Suunto9?
              • ? Offline
                A Former User @casimirov
                @casimirov said in Barometric sensor malfunction on my Suunto Ambit3 Peak?:
                Clean the baro holes, make a reset/reinstalation of software.
                In the meantime, contact support, just in case those two procedures don’t work.
                • toni_vT Offline
                  toni_v Bronze Member
                  The exact same thing has happened to me. Is there a way to use GPS altitude instead of barometric?
                  • H Offline
                    halajos Bronze Member @casimirov
                    @casimirov I had such an issue once, after a day of skiing. Pressure and temperature weren’t shown on the alti/baro screen, altitude was also completely wrong. Try adjusting the altitude manually to a reasonable value through the options menu. This was the fix for me, and my A3P is still working.
                    • ? Offline
                      A Former User @toni_v
                      hi @toni_v,
                      yep, you can create an app on movescount (hint: RESULT = SUUNTO_GPS_ALTITUDE).
                        casimirov @Guest
                        @andré-faria
                        I’ve already done this and everything remains the same. I still don’t have values ​​for temperature, atmospheric pressure and altitude does not update. Possibly it was the sensor that failed, no?
                        S 1 Reply Last reply Reply Quote 0
                          casimirov @halajos
                          @halajos
                          Yes I’ve already done that but later during the activity the altimetry value doesn’t update and during training I don’t have altimetry values, although all gps functions work normally.
                            casimirov @Guest
                            @walker I don’t quite understand what to do. What will be the advantage or how does it work? Thanks
                            • S Offline
                              steb24 @casimirov
                              @casimirov Did you ever resolve this issue and/or contact support? I also have this same problem with my Ambit3 Peak. Example below 1) from Suunto app with barometric altitude data and 2) from Strava showing GPS altitude. I can’t really reset this manually down from 30,000 to 15!!! Thanks.
                              • ? Offline
                                A Former User @steb24
                                @steb24 This is a somewhat known issue. I had the same. It’s a hardware defect of the pressure sensor/chip. I didn’t get in touch with Suunto, because the watch was well out of warranty. Repairing this will in all likelihood be too expensive.
                                • amidasA Offline
                                  amidas
                                  I’ve got exactly the same problem about 1.5 years ago. I still use the watch as is.
                                  • S Offline
                                    SUAldana @casimirov
                                    Hello @casimirov,
                                    How do you recommend cleaning the barometer sensor? I also have a Suunto Ambit3 Peak and it’s not reading pressure and temperature.
                                    Thanks!
                                    • Paulius D.P Offline
                                      Paulius D.
                                      Hi all, I have my Ambit 3 peak for about 6 years. first time the pressure sensor failed after using it for 4 years, then after a yearI sent it to refurbish because it is a good watch, its the best to keep devices that are working nice. But again one year after refurbishing it is failing again. I wish to disconnect the pressure measurement feature, because now the watch thinks its in verry high altutude and it doms the display and it is really annoying.
                                      Register Login
                                      • First post
                                        Last post
                                      Suunto Terms | Privacy Policy
