    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 GPS precision
    Scheduled Pinned Locked Moved Suunto 7
    4 Posts 2 Posters 472 Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • G Offline
      Grillo54
      On my sunday trekking the altimeter marked all day 100-120m less than realty , how is it possible with the GPS on? How can i solve this problem?
      Jamie BGJ 1 Reply Last reply Reply Quote 0
      • Jamie BGJ Offline
        Jamie BG Bronze Member @Grillo54
        @grillo54 had that before when it incorrectly sets the alitimeter at the start.
        Went through a period of this and then it just sorted itself out, but during that period had the altitude field on a data screen and before setting off would check it to make sure. However even if off it should reset it self during the activity, but for some reason it wasn’t.
        Usually got the issue if I was disconnecting watch from phone - that is when it tended to appear more frequently.
        G 1 Reply Last reply Reply Quote 0
        • G Offline
          Grillo54 @Jamie BG
          @jamie-bg my trek lasted between 5 and 6 hours how is it possible that the altimeter has never reset and was always wrong while the GPS track was perfect?
          • Jamie BGJ Offline
            @grillo54 had that happen - sometimes it just doesn’t fix the start altitude. You will probably find that actual ascent and descent is correct (which sounds like it was based on your original post).
            You would need to speak to suunto as to why it does that, as I don’t know. Tried numerous combinations, couldn’t get anything to actively trigger the issue and or to fix the issue when it occurred - sometimes it corrected itself sometimes it didn’t. Checking alt before starting, I could sometimes catch and fix it by stopping activity, discarding it, starting up activity again and waiting for fix and a bit longer - sometimes it worked, sometimes it didn’t. As I said starting the activity while still connected to a phone did seem to reduce the occurance when this was happening.
            Personally I think it may be due to how its pulling the GPS data, and then aligning it to DEM maps? But don’t know enough about the inner workings.
            Altitude issues aren’t unusual - loads of posts about this on all different watches etc. For example I found my F6 was doubling ascent & descent, so changed some settings - and hey presto all sorted and now matches based on other watches and based on topo & DEM maps.
            Register Login
            • First post
              Last post
            Suunto Terms | Privacy Policy
