    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    VO2max
    39 Posts 12 Posters 4.8k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Djordje SD Offline
      Djordje S Bronze Member
      Hello,the more I practice VO2max is decresing πŸ™‚
      I do not expect to have some super high value but on the other I do not expect to decrese as well.
      Any advice maybe? πŸ™‚
      Thx.
      TheGuyFromTheSummitT DMytroD 2 Replies Last reply Reply Quote 0
      • TheGuyFromTheSummitT Offline
        TheGuyFromTheSummit Silver Members @Djordje S
        @djordje-s Honestly I wont look at the VO2max at all. Mine changes Β±4 from workout to workout.
        I do not know the algorithm, but I guess Suunto does not implement such things like temperature. So better not trust it.
        DMytroD Djordje SD 2 Replies Last reply Reply Quote 1
        • DMytroD Offline
          DMytro @Djordje S
          @djordje-s which activities do you do? VO2max is the most accurate when running on an even terrain.
          Djordje SD 1 Reply Last reply Reply Quote 0
          • DMytroD Offline
            DMytro @TheGuyFromTheSummit
            @theguyfromthesummit as I do mostly walking and hiking, mine is 28.7 XD
            • surfboomerangS Offline
              surfboomerang
              Some algorithm background from Firstbeat:
              https://www.firstbeat.com/en/science-and-physiology/fitness-level/
              Suunto Vertical Titanium Solar
              OnePlus Nord 4
              TheGuyFromTheSummitT 1 Reply Last reply Reply Quote 1
                TheGuyFromTheSummit Silver Members @surfboomerang
                @surfboomerang is this the one Suunto is using?
                surfboomerangS 1 Reply Last reply Reply Quote 0
                  surfboomerang @TheGuyFromTheSummit
                  @theguyfromthesummit I believe so, but someone correct me if I’m wrong.
                  OnePlus Nord 4
                  • PENNACNPP Offline
                    PENNACNP Bronze Member
                    I frequently run with both my Suunto 9 Peak and Garmin Fenix 6X, and the two devices yield vastly different VO2 max values while having similar averages for pace and heart rate. Unfortunately, (for better or worse, and true or not) the lower values suggested by the Suunto 9 Peak are discouraging to a novice, and they do not seem to coincide with my perceived effort. In fact, I also had a Suunto 9 and the VO2 max values from that more closely approximated the Fenix than those produced by the S9P. I wonder if this is a known issue?
                    SUUNTO VERTICAL TITANIUM SAND
                    SUUNTO 9 PEAK PRO TITANIUM SLATE
                    SUUNTO 9 PEAK GRANITE BLUE TITANIUM
                    SUUNTO 9 BARO CUSTOM
                    TheGuyFromTheSummitT 1 Reply Last reply Reply Quote 0
                      TheGuyFromTheSummit Silver Members @PENNACNP
                      @matthew-robertson I do not know why, but I would trust your fenix more.
                      @all Nevertheless you can not use VO2max as a fitness-indicator. It is strongly genetically limited and you should use a Lactat-Testing as a better indicator.
                      Usually VO2max is used, because it changes quickly and is easier to measure.
                      PENNACNPP 1 Reply Last reply Reply Quote 0
                        Djordje S Bronze Member @DMytro
                        @dmytro Walking and running
                        DMytroD 1 Reply Last reply Reply Quote 0
                          Djordje S Bronze Member @TheGuyFromTheSummit
                          @theguyfromthesummit I know that it is not reliable but again it really annoying that you see a decrese every time πŸ™‚
                            @djordje-s Ahh ok
                            have you changed anything in terms of intensity/ volume?
                            • DMytroD Offline
                              DMytro @Djordje S
                              @djordje-s I think it may be because of walking. If I do a few runs in a row, my VO2max grows nicely, but a couple of longer walks sink the value.
                                I havent.Basically standard route with little change.
                                  @dmytro So to try with few running and to see what is happening? πŸ™‚
                                  • DMytroD Offline
                                    DMytro @Djordje S
                                    @djordje-s I’d suggest more running, less walking.
                                    My walks also work if hr is elevated enough + speed is above 6.5kmh
                                      @dmytro and multisport? Walking+running
                                      • DMytroD Offline
                                        DMytro @Djordje S
                                        @djordje-s I’m not sure if multisport activities are contributing to VO2max. You can check this by performing an activity, then looking for it in the VO2max tab in SA.
                                        I just want to say that it’s my personal experience. When I go hiking my vo2 plummets as only horizontal speed is being considered by the algorithm. When I go walking - I’m not sure: maybe the algo considers my HR for the speed to be too high, or maybe HR is just not high enough to provide a reasonable dataset for extrapolation.
                                        I heard from people on the forum that both walking and running results in reasonable VO2max values.
                                          @dmytro Also one observation.My VO2max was also low before hard reset.After that the value was high and now it decresing after every exercise πŸ™‚
                                          • DMytroD Offline
                                            DMytro @Djordje S
                                            @djordje-s well, it makes sense. If algo before the hard reset considered your vo2 to be low, after you’ve reset the values, it needed time to converge to the similar value.
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
