Stopwatch issue
I think that I’ve found a bug in the stopwatch settings.
Seemingly, the only way to exit the stopwatch screen back to the normal watch/time face is to swipe left to right on the screen. There is no back button functionality on the stopwatch screen.
The reason this is a problem is that the touchscreen doesn’t work if you’re fingers or the screen is wet so in that case there is no way to exit the stopwatch screen.
Irritating… -
@ramrod I can’t reproduce - long-press to the middle button works for me to exit stopwatch. Could you maybe record a video of the issue?
@ramrod A long press of the middle button should solve this problem
Yep, that works. Thanks guys
Register Login
