    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Connected GPS feature SF3/Galileo supported smartphones
    Scheduled Pinned Locked Moved Suunto app and other software services
    48 Posts 5 Posters 6.5k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
      Dimitrios Kanellopoulos Community Manager
      Watch looks better. At the moment Galileo from.my tests does not give more than 4% improvement. Tested on Android and the test gps apps that support Galileo.
      Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
      Luís PintoL jthomiJ 2 Replies Last reply Reply Quote 0
        Dimitrios Kanellopoulos Community Manager @jthomi
        @jthomi said in Connected GPS feature SF3/Galileo supported smartphones:
        Maybe the app was exactly 204 descent and ascent? The screenshot from the data in the app is also pretty close, only 0,40 meters off.
        @slashas said in Connected GPS feature SF3/Galileo supported smartphones:
        @luís-pinto but why one the right it is stuck on 204?
        I would not bother with ascent at this time. All services do it their own way. Especially mygps files.
          Also the correct term is ascent. Elevation is altitude. You can say elevation gain for example or altitude gain or ascent.
          • Luís PintoL Offline
            Luís Pinto Platinum Member @Dimitrios Kanellopoulos
            @dimitrios-kanellopoulos In this case we cannot make that extrapolation, because Suunto app in smartphone will get information from 3 or 4 systems. We don’t know which satellites device use in certain activity. Unfortunately we cannot select on iOS or Android what system to be on/off.
            SR
            Site (gr7vel spin): https://youtube.com/channel/UCfHM0mXWS8S61h70Rzj9mfA
            Dimitrios KanellopoulosD NicolasPN 2 Replies Last reply Reply Quote 0
            • jthomiJ Offline
              jthomi Moderator Gold Members Silver Members @Dimitrios Kanellopoulos
              I also think watch looks better, you can see the track points, App has 2317 points and the watch 11684, guess that why its more accurate.
              And I guess nobody here would make a problem out of it. I think even if watch looks better, they seem pretty similar, don’t they…
              @dimitrios-kanellopoulos said in Connected GPS feature SF3/Galileo supported smartphones:
                Dimitrios Kanellopoulos Community Manager @Luís Pinto
                @luís-pinto said in Connected GPS feature SF3/Galileo supported smartphones:
                Afaik they use the system service. I can ask for you.
                Luís PintoL 1 Reply Last reply Reply Quote 0
                  @dimitrios-kanellopoulos If we can have access to information of native file maybe is possible to get that information (each satellite have one id). But in smartphones i really don’t know.
                  SR
                  jthomiJ Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
                  • jthomiJ Offline
                    jthomi Moderator Gold Members Silver Members @Luís Pinto
                    @luís-pinto We should need the raw data then?
                      Luís Pinto Platinum Member @jthomi
                      @jthomi i’m affraid yes.
                      SR
                      • jthomiJ Offline
                        I think the target market for the SF3 will be fine with the accuracy of the tracking. If you look really closely to the two tracks, sometimes watch is better, and sometimes the app. And some parts of the route both are way off, guess the way the data is displayed on the maps is a source of error itself.
                          I can do that for you.
                          Luís PintoL 1 Reply Last reply Reply Quote 1
                          • jthomiJ Offline
                            So, shall I give it another try tomorrow?
                              @jthomi And one important fact. All smartphones will have same performance? And OS can role a variable for results? What about antenna design in each phone? At this time i have many questions. We need several tests, several brand phones, different ambients. One variable we can’t domain. The choose of a GNSS system in phone. It’s not possible. In iOS i’m sure there isn’t.
                              SR
                                Luís Pinto Platinum Member @Luís Pinto
                                There are no doubts. Suunto app will get the management that the operating system allows. I don’t think developers can improve that. Is suppose that we will have very variable results depending to the phone. For occasional registrations with SF3 the quality will be reasonable for most of users.
                                SR
                                  @dimitrios-kanellopoulos That would be very valuable!
                                  SR
                                  • NicolasPN Offline
                                    NicolasP @Luís Pinto
                                    @luís-pinto don’t forget that phones can use not only satellites but as well the mobile network for better accuracy. So it’s even more difficult to know what has been really used to record the track. Maybe a combination?
                                    SST
                                    Luís PintoL 2 Replies Last reply Reply Quote 2
                                      Luís Pinto Platinum Member @NicolasP
                                      @nicolasp Well mentioned! I had forgotten that reality.
                                      SR
                                        @nicolasp By the way i found this in one app for iPhone (iSmoothRun):
                                        “GPS Quality
                                        A few words on GPS signal quality and accuracy. GPS accuracy is not controlled by the app (or any app) but by the device. Apps only define what are the accuracy requirements for the specific use. We run the iPhone GPS unit always on maximum accuracy mode (it doesn’t have much impact on the battery). Any app would give exactly the same results (you can run two apps in parallel to check). We usually give better results than other apps, when there is no GPS signal and other apps give positions from WiFi spots or cell towers, while we switch to pedometer till we get a satellite fix again.”
                                        SR
                                          I asked and the developers replied that the best mode for accuracy is asked and they do not ask for a specific location provider which means that it will use what the phone is capable of.
                                          1 Reply Last reply Reply Quote 3
                                          • jthomiJ Offline
                                            Another test from today’s tour:
                                            http://www.mygpsfiles.com/app/#Ai1QGGkJ
                                            Again with iPhone7 SuuntoApp tracking in comparison to tracking with the Suunto Spartan Sport.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
