    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    How to upload a fit file to SA?
    Scheduled Pinned Locked Moved Suunto app and other software services
    10 Posts 4 Posters 2.0k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      shmish
      Following on this post: Re: How to edit a move in suunto app?
      The power readings from my power meter are double what they should be. I used to have a method for correcting this and re-uploading to Movescount. Now it is a bit trickier. So far what I’m doing is downloading the fit file from SA. I then adjust the power (currently using FIT FileTools, which seems to work very well). However, I’m stuck on how to get this data back to SA. I created a Quantified-self account and connected it to SA. I deleted the workout with the wrong power and uploaded the corrected fit file. This shows correctly in quantified-self. But I don’t get how this syncs to SA. It doesn’t seem to sync on it’s own.
      Thanks
      • EgikaE Offline
        Egika Platinum Member
        @shmish where Do you upload it to QS? Are you using the upload in “services”?
        Have you deleted it from SA as well?
        S 2 Replies Last reply Reply Quote 1
        • S Offline
          shmish @Egika
          @egika Yes, I uploaded the FIT file to QS. I have services turned on. I don’t think I deleted it from SA. I’ll try that.
          • S Offline
            shmish @Egika
            @egika I should say that I deleted the workout from sports-tracker.com, but not the suunto app.
            • EgikaE Offline
              Egika Platinum Member @shmish
              @shmish said in How to upload a fit file to SA?:
              To be clear, there are two ways to upload an activity in QS. Are you sure to use this one?
              • S Offline
                shmish
                Thank you. I was uploading via the dashboard. Uploading with the services worked, thanks.
                • Sam RosenfeldS Offline
                  Sam Rosenfeld
                  Hey,
                  I am trying to upload a fit file I edited through quantified self.
                  I have done as you describe above, uploading via services, but it still doesn’t show in the suunto app.
                  It says it uploads the file and checks for errors, and then it disappears.
                  Do I need to delete the old fit files of the original activities before uploading?
                  Thanks!
                  EgikaE Mff73M 2 Replies Last reply Reply Quote 0
                  • EgikaE Offline
                    Egika Platinum Member @Sam Rosenfeld
                    @Sam-Rosenfeld There have been changes to QS so I think this service does not work anymore.
                    What is still working, is to use Runalyze, which has a Suunto upload:
                    Sam RosenfeldS 1 Reply Last reply Reply Quote 4
                    • Mff73M Offline
                      Mff73 @Sam Rosenfeld
                      @Sam-Rosenfeld
                      i personnaly use Mytourbook Windows application which can connect to you Suunto account, download you activities for offline management, editions, and upload back to Suunto if needed.
                      https://forum.suunto.com/post/150501
                      SSU (retired), SV1, SV2
                      Wife : S9PP
                      SA: Always the latest beta :)
                      Android + Galaxy S205G
                        Sam Rosenfeld @Egika
                        @Egika thanks! I was able to use it and upload the modified fit files.
                        I also tried mytourbook but I failed to authorize to suunto for some reason.
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
