    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    VO2 Max
    Scheduled Pinned Locked Moved Suunto 9 Peak
    62 Posts 23 Posters 14.7k Views 22 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • isaziI Offline
      isazi Moderator @surfboomerang
      @surfboomerang my values are in line between S9 baro and peak, and also Garmin watches.
      Blog: isazi's home
        Dimitrios Kanellopoulos Community Manager
        When determining the vo2max it can differ.
        Example:
        on other watches you did a good relaxed session
        On your new watch you have not done that
        Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
        • MarcWM Offline
          MarcW
          Out of interest from reading this, has anyone here done an actual VO2max test in a lab?.. if so what is the difference between lab vs watch? I have done a few lab tests and Suunto watch shows the same for me.
          • zhang965Z Offline
            zhang965
            i did 58 in lab
            with s9b I got 68 65 62
            Winners Wear Winners
            D 1 Reply Last reply Reply Quote 0
            • D Offline
              dulko79 @zhang965
              @zhang965 slowly converging 😆
              App: beta
              Phone: Iphone
              iOS
              • Brad_OlwinB Offline
                Brad_Olwin Moderator
                I have 56 in the lab and 48-50 with Suunto 9Peak and baro and 49 with Garmin.
                Vector/T6c/Vertical 2 Ti
                L 1 Reply Last reply Reply Quote 0
                • L Offline
                  Likarnik Gold Members @Brad_Olwin
                  I got 65 in lab, but never more than 60 on S9P, but S9B showed 62 a year ago.
                  Currently it shows 45.4, because I did slow (Z2) verticals in last two weeks, so mostly power hiking up and running down. Fast run on flat - VO2 goes up.
                  • cosme.costaC Offline
                    cosme.costa
                    I had 60 in the lab and I’m around 56 to 59 in my S9B, depends a lot on the type of exercise you do, quickish/shortish/flatish run my VO2max goes up, the longer and hilly my runs are it goes down.
                    • MarcWM Offline
                      MarcW
                      Thanks for all for sharing, really interesting to see! Mine is 63 in lab and 62 on Suunto watches (both Suunto 9 Baro and Suunto 9 Peak)
                      • freeheelerF Offline
                        freeheeler
                        might seem a bit offtopic, but does anyone know if this type of HR error effects VO2max results?
                        normally I wear merino shirts for sports but sometimes during mental derangements, I pick plastic shirts and my observation is that they send greetings from tesla to the sensor 😉
                        living sideways
                        cosme.costaC TheGuyFromTheSummitT 2 Replies Last reply Reply Quote 1
                          cosme.costa @freeheeler
                          @freeheeler said in VO2 Max:
                          It definitely affects! I think the important parameters for VO2Max are HR and pace. From my findings, you can have a nice bump in VO2Max if you run as fast as possible, 4/5 km in Z4 (Z3).
                          I understand you are using a chest strap, I use polyester T-Shirts and never had this bad readings, now I’m using the Polar OH1 and it is the better for my use, I only want HR as a reference so I do not need more and I don’t care if there is a bit of delay regarding the chest strap.
                          • TheGuyFromTheSummitT Offline
                            TheGuyFromTheSummit Silver Members @freeheeler
                            @freeheeler i always wear polyester shirts, but I use a Polar H10.
                            3 weeks ago I did a lab test on the treadmill and an ekg was used to check the HR. Out of curiosity I used my H10 as well.
                            Data was absolutely on point (max ± 1 bpm).
                            How old is you HR belt?
                            And btw I wouldn’t trust the VO2 max the watch give you.
                            My watch estimated a VO2max 15% lower than it really is (lab test)
                            freeheelerF 1 Reply Last reply Reply Quote 1
                              freeheeler @TheGuyFromTheSummit
                              @theguyfromthesummit
                              my chest strap is about 13 months old and exactly after 12 month I’ve had to replace the battery.
                              It stopped working from one day to the other.
                              I’ll try and observe today again with a merino shirt.
                              it surprises me that you and @cosme-costa don’t have issues like that with synthetic shirts, I thought this was one of the main reasons why we see these spikes 🤔
                              I use the VO2max value only as a reference for myself to understand if I am better or less in shape than in the past. The actual value itself doesn’t tell me much.
                              But I also made the experience that it is jumpy depending on the topography or how fast and far I am going… so basically, I could as well ignore it 😂
                              living sideways
                              isaziI 1 Reply Last reply Reply Quote 0
                              • isaziI Offline
                                isazi Moderator @freeheeler
                                @freeheeler I’ve never had those spikes with a working strap. Did you put yours in the washing machine? I once killed one that way. Current one is one year old, I had to replace the battery at some point last year, but it’s working well.
                                Blog: isazi's home
                                freeheelerF 1 Reply Last reply Reply Quote 0
                                  freeheeler @isazi
                                  @isazi
                                  No, I never put it in the washing mashine. I wash it by hand only.
                                  living sideways
                                  MarcWM 1 Reply Last reply Reply Quote 1
                                  • MarcWM Offline
                                    MarcW @freeheeler
                                    @freeheeler and you probably know, but worth repeating, if you completely wet the strap under the tap in some water before putting on it can help to eliminate some of that electrostatic discharge. It’s why usually after a while (you sweat) it helps.
                                    • MarcWM Offline
                                      MarcW
                                      Always hard to put on a wet HR strap though in the morning 😄
                                      isaziI Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                      • isaziI Offline
                                        isazi Moderator @MarcW
                                        @marcw said in VO2 Max:
                                        That’s why I only run in the evening 🙂
                                        Blog: isazi's home
                                        Brad_OlwinB 1 Reply Last reply Reply Quote 1
                                          freeheeler @MarcW
                                          @marcw
                                          yes, I know. I’m wearing chest straps for over 4 years frequently now.
                                          Hence I am going to order my 5th strap today… I really should start tagging the activities when I notice the strap is dying…
                                          I remember that the newer strap should have been improved, but I can’t tell what’s been improved since it starts giving crazy results after one year, just like the straps before 🤷
                                          living sideways
                                            Brad_Olwin Moderator @isazi
                                            @isazi said in VO2 Max:
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
