    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Transfer routes from logbook to navigation?
    97 Posts 21 Posters 15.7k Views 20 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • N Offline
      nikshot
      Hello,
      Is it possible to transfer routes from “Logbook” to “Navigation” without using the Sunto mobile application?
      When I let my Sunto 9 Baro follow my routes, after recording the route I can’t use it to go back unless I transfer it from the Suunto mobile app, and this cell phone addiction would be a wildlife problem for me - I may not have range, phone battery, etc.
      I apologize in advance for the spelling.
      Greetings
      SUUNTO 9 BARO TITANIUM & SUUMNTO AMBIT 2 SAPPHIRE
      Dimitrios KanellopoulosD David YoungD 2 Replies Last reply Reply Quote 6
        Dimitrios Kanellopoulos Community Manager @nikshot
        @nikshot unfortunately not atm
        Creator of Quantified-Self.io
        youtube.com/c/dimitrioskanellopoulos
        https://instagram.com/dimitrioskanellopoulos
        https://www.strava.com/athletes/7586105
        N 1 Reply Last reply Reply Quote 0
        • N Offline
          nikshot @Dimitrios Kanellopoulos
          @dimitrios-kanellopoulos NO, no, I meant that logbook routes cannot be used without the mobile application:
          isaziI Mff73M 2 Replies Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @nikshot
            @nikshot yes you cannot take a route from the watch at the moment and use it for navigation, without passing via the app.
            Blog: isazi's home
            N 1 Reply Last reply Reply Quote 1
            • Mff73M Online
              Mff73 @nikshot
              @nikshot
              Your question is well understood, and the answer is : no, it is not possible with the Spartan/S lines.
              It was with Ambit, it is not possible… at the moment = who knows…
              I am pretty sure there is a reques for this in the forum, search and vote is your best weapon 😉
              Suunto Spartan Ultra (since 2016) FW: 2.8.24 (retired)
              Suunto Vertical all black
              Wife : S9PP
              SA: Always the latest beta :)
              Android 13, Galaxy S205G
              N 1 Reply Last reply Reply Quote 3
              • N Offline
                nikshot @isazi
                @isaziI also have Ambit 2 Sapshir, it works … and Suunto 9 baro does not, very unfortunate …
                Thanks for the answers.
                isaziI 1 Reply Last reply Reply Quote 0
                • isaziI Offline
                  @nikshot yes it was there for the Ambit series. Maybe it will come back, I do not know, Suunto does its research in deciding which features to have and which not.
                  Blog: isazi's home
                  • N Offline
                    nikshot @Mff73
                    @mff73I also have Ambit 2 Sapshir, it works … and Suunto 9 baro does not, very unfortunate …
                    • David YoungD Offline
                      David Young Bronze Member @nikshot
                      @nikshot By ‘range’ do you mean a phone signal?
                      To be clear, the transfer can be done with Bluetooth, so you don’t need a phone signal.
                      The problem I had is the last time I wanted to use the functionality is that the pairing had been forgotten, so I had to restart the pairing process while sitting out on a hillside trying to shield my phone from the rain.
                      Not ideal.
                      • N Offline
                        nikshot @David Young
                        @david-youngYes, and when you don’t have a signal, you can’t transfer the route from Suunto to the phone first, because the information obviously has to reach Suunto’s website …
                        Mff73M David YoungD 2 Replies Last reply Reply Quote 0
                        • Mff73M Online
                          Mff73 @nikshot
                          @nikshot said in Transfer routes from logbook to navigation?:
                          Yes you can.
                          Totally without signal, you can transfer activity to the phone (bluetooth), then transform this activity into a route in SuuntoApp (in the phone and offline) then transfer it to watch (BT).
                          Thing you can’t do is download (need network) the fit files or GPX files.
                          So, answer to original question is no (not without phone) but yes offline with a phone.
                          Wife : S9PP
                          N 1 Reply Last reply Reply Quote 7
                            @nikshot You don’t need a phone signal to copy your watch’s logbook record to your phone and then copy it back to the watch as a fully-featured route.
                            Bluetooth will do this.
                            The process is dealt with locally inside Sunto App.
                            As many people are pointing out, Suunto’s older watches handled the process internally.
                            Hopefully Suunto will take notice!
                            • N Offline
                              @david-young Yes, I understand, but after a few days in the mountains, phones often run out of battery and then Suunto becomes useless…
                              DMytroD 1 Reply Last reply Reply Quote 0
                              • DMytroD Offline
                                DMytro @nikshot
                                @nikshot you could create POIs on the watch and use bearing navigation. Sure, not the same, but not useless non the less.
                                • N Offline
                                  nikshot @DMytro
                                  @дима-мельниченкоIn theory it is so, but in practice it is different, especially when we talk about heavily broken terrain with peaks and valleys, screes and precipices! In such terrains when using POIs
                                  to cover 2-3 km can cost you days! I use POIS regularly when I’m looking for a place, but then I count on going back the same way and that’s when I need the track that my Suunto did. And one question - why is my Suunto doing tracks when I won’t be able to use it back ??? Don’t get me wrong, I’m a Suunto fan, this is my second watch from the brand, but in this 9 series this is a serious omission that needs to be corrected !!! It is not serious for the watch to be dependent on a phone …
                                  EgikaE David YoungD 2 Replies Last reply Reply Quote 1
                                  • EgikaE Offline
                                    Egika Platinum Member @nikshot
                                    the answer is simple:
                                    it is not a descision not to do this, as everyone agrees, this is a useful function.
                                    Starting with the Spartan line Suunto has undergone a massive change with their whole ecosystem.
                                    That means, all feature wishes needs to be prioritized - and this feature (use recrding as route in watch) has been lower on the list than other functions.
                                    t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
                                    1 Reply Last reply Reply Quote 4
                                      But you will, you just need to sync the S9 with your phone.
                                      I agree it’s not ideal, but it’s what we have.
                                      I think that if I were worried about finding my way back through challenging terrain I would wear my Traverse on my other wrist and record on that as well.
                                      • N Offline
                                        nikshot @Mff73
                                        @mff73Hello again,
                                        This weekend I tried what we talked about.
                                        Here’s what happens when your phone is out of range:
                                        The information really enters via Bluetooth in the phone, but it gives me no connection to the Internet and offline, the buttons for recording and transferring the route are missing - I am attaching photos:
                                        and here the route does not exist at all:
                                        now I am attaching photos after internet connection:
                                        So, the answer to the question is that with a phone without internet it is not possible to use routes that are currently created by the watch … which makes Suunto completely dependent on the phone, and hence makes many accents that the new Suunto is famous for meaningless, like long battery life - what about the phone battery if with short life ??? And the main accent of Suunto is that it is GPS navigation 🙂 which you can’t use without a phone, etc …
                                        Mff73M sartoricS David YoungD 3 Replies Last reply Reply Quote 2
                                        • Mff73M Online
                                          Mff73 @nikshot
                                          @nikshot
                                          i have tried it before answering you 😉
                                          have you put your phone on airplane mode to do this test ? if yes, you need to enable bluetooth for sure 😉
                                          no internet doesn’t mean no wireless communication to watch 🙂
                                          the phone doesn’t need to be connected to internet but the watch need to be connected (linked) to the phone.
                                          Wife : S9PP
                                          • N Offline
                                            nikshot @Mff73
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
