    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Energy saving tilt not persistent
    Scheduled Pinned Locked Moved Suunto 7
    15 Posts 6 Posters 990 Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • EgikaE Offline
      Egika Platinum Member
      How do I make the energy saving tilt to wake stay on?
      It’s always reverting to normal tilt to wake in the background after short time…
      I have toggled both switches multiple times and restarted the watch.
      No change
      t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
      Jamie BGJ 1 Reply Last reply Reply Quote 0
      • Jamie BGJ Offline
        Jamie BG Bronze Member @Egika
        @egika
        Weird as I definitely do not get that issue. That issue used to be an issue with I think the September update but they fixed it in the Jan update, so weird that it is now presenting in the April update - but I personally haven’t seen that issue.
        if you are on the latest update you may have to perform a reset. Maybe something got mixed up that a restart isn’t fixing.
        Marco GM 1 Reply Last reply Reply Quote 0
        • Marco GM Offline
          Marco G @Jamie BG
          I switched from the normal tilt to wake to the power save mode just a week ago and did not have any issue.
          • EgikaE Offline
            strange.
            I switch powersave tilt on, and sometimes even when still in the gestures settings, it switches back to tilt to wake.
            Sometimes it takes the setting and I can successfully use the powersave tilt, but after a few minutes it’s off again 😞
            @Jamie-BG reset means to wipe all the data and start fresh setting everything up from scratch? I’d rather avoid this.
            N 1 Reply Last reply Reply Quote 0
            • N Offline
              Nshkira @Egika
              @egika Do you change watch faces? If you change one with power saver mode to a watch face without it - setting will go to tilt to wake on and stay.
              • EgikaE Offline
                @nshkira I tried.
                Using a watch face with no power save option works with normal tilt to wake on.
                My issue is with the power save watch face. Using it in power save mode does not work. It always reverts to full power tilt to wake 😞
                olymayO 1 Reply Last reply Reply Quote 0
                • olymayO Offline
                  olymay Gold Members @Egika
                  @egika Couple of random suggestions…
                  Do you have settings for tilt to wake on the watch and in WearOS on the phone conflicting each other? Maybe one is overriding the other?
                  Also - and this is a very random long shot - make sure tilt to wake is off, turn on power saver tilt and then immediately restart the watch by holding the power button (just a restart, not a full reset!).
                  This was an issue I experienced back in September and this was a way around it.
                  Also, as a final point, make sure your watch is running the latest firmware (as this was present back in september but was resolved by january).
                  Suunto 7 Graphite Copper
                  Suunto App Beta (Android - Pixel 6 Pro)
                  • EgikaE Offline
                    @olymay thank you.
                    Indeed I was among the first to discover the bug that the Suunto Wear App would change these settings to what it initially found.
                    Now it happens without even starting any app.
                    Also the phone app does not conflict, it reflects the watch setting and is off, when the watch is off and vice versa.
                    Now my issue seems to be even bigger: even the normal tilt to wake setting does not stay off, if I deactivate it together with the power save tilt to wake.
                    After a few minutes tilt to wake is active again…
                    Wtf…?
                    • EgikaE Offline
                      I found a lot of reports when searching for this issue:
                      Like this one:
                      https://support.google.com/wearos/thread/34134190/when-tilt-to-wake-gesture-is-set-to-off-it-turns-itself-back-on-how-do-i-keep-it-turned-off?hl=en
                      How do I delete the cache of the WearOS app in S7
                      • EgikaE Offline
                        Found it.
                        And it did not help…
                        Had to fully reset the watch and start from scratch 😞
                        • Jamie BGJ Offline
                          @egika did that fix the issue though?
                          H 1 Reply Last reply Reply Quote 0
                          • H Offline
                            Harboe Bronze Member @Jamie BG
                            @jamie-bg I had the issue of power tilt shifting to tilt to wake. It came to the conclusion that it was because I had used a watch face that didn’t support the power tilt. I tried everything I could think off, uninstall watch face/reboot, without being able to get power tilt to work. Ended up resetting the watch and its working perfectly again. Annoying, but now I know and at least reinstalling doesn’t take to long.
                            • Jamie BGJ Offline
                              Jamie BG Bronze Member @Harboe
                              @harboe - only suunto and moto watch faces use power tilt.
                              Though it was only suunto but recently discoverd that moto also has that functionality.
                              Sort of suggests it should be open to everyone, but not seen any others. Maybe it has to be a manufactuerers watch face…
                              • H Offline
                                @jamie-bg I believe its because of the 3100 processor. And the 4100 plus is we ever see any devices using it (Suunto 7 us hopefully).
                                • Jamie BGJ Offline
                                  @harboe sorry - should have qualified that it is open to everyone with a 3100/4100+ chip. Initially I thought it was something that suunto had incorporated into the watch in the system update - however as Moto can also do it, it must be wear os integrated. Its just a pity that no one else is using it, including watch face makers.
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
