Suunto 9 Peak
@aroo7 all transreflective screens have a little of those issues. If this is under a lot of backlight it’s ok. If it’s under little/none it depends
@dimitrios-kanellopoulos the white dial is highlighted in pink light. It looks a bit like night mode
@sartoric and @NickK it is not a reflection. the dial is highlighted in pink light, it is not visible outside in the sun
First impressions on the S9P replacing my S9Baro titanium:
DESIGN
- It is really very very beautiful but I find it too small as its screen. I think that for my wrist size the ideal would be a watch of about 46mm with a bigger screen for my eyes
On the other hand, for my wife’s wrist who also ordered one, it is perfect! - Very pleasant to wear
- The screen is of much better quality than the S9B
FUNCTIONALITY
- During my test, I left at an altitude of 84m and I made 5 accelerations of 30’’ with recovery of 45’’ on a small circuit to test the GPS precision and with the OHR:
- When I came back to the starting point, my altitude was 82m
- The GPS track (GPS+QZSS+BEIDOU) seems to be really good as you can see on the circuit training I did 8 times. - The pace curve shows the accelerations well - My heart rate was a little higher than usual at the same pace, about 5-10 beats above normal, which is too much. On the other hand, the 5 accelerations are clearly visible and the watch seems quite responsive. I will continue to test this because it seems promising but there is still room for improvement in terms of reliability. It’s useless for me if the accuracy is not improved.
- SpO2 is not regular enough and the fluctuations are important when comparing two measurements one after the other, which makes this feature not very useful if it lacks reliability…
- I’m waiting for a feature to do a recovery test based on heart rate variability.-
I don’t know yet if I’ll test the ORH on my run this week end because I don’t trust it… to see
@aroo7 said in Suunto 9 Peak:
Green is not green more like blue
Same. But I find the display clearer to read, it has more contrast and coating on sapphire is less reflective compared to S9B.
Mine arrived today. I like the screen! It’s much crisper than the S5: here are some pics side by side. It’s really a „light“ watch compared even with the S5
With backlight
Without backlight outdoors
Comparing „the green“
Will do some walking now- running and cycling at the weekend is planned
I don’t mean light reflection ON the screen but through the screen due to backlight and indoor light.
Check the images up here … do you see the same reddish colors on natural (sun) light ? -
@sartoric
yes - it was a bit tight
Just got it a few minutes before the pictures and I still “struggle” which hole in the strap to choose. But I like the new “pin” to fix the strap - kept it a bit looser on short first test walk. Really very readable display and almost not noticeable on the wrist!
Looks realy « mini » this new peak ! It must be bizar in the first times. We got used to having Ambits, Spartans or S9 at wirst but in there are thick.
Tell me: if i link a S9P with my SA, will i lose my customs sport mode ?
Can i create a new custom sport mode if i haven’t a Suunto watch linked to SA ? -
@ink357 said in Suunto 9 Peak:
Yes
No
And if your watch is busy syncing or so SA warns you that you that your watch is busy and you can’t save your sport mode customizations.
@chrisa The new pin at the strap doesn’t function so well with bike mount. It’s hard to push the pin on the hole and it to stay there during rides.
Wondering how Suunto planned this to be used? Or do I just need separate straps.
I think I got my first excuse for shopping
@s1ngletracker
I might be odd… but I prefer my watch on my wrist. It’s just a feeling, but I think it’s less likely that it gets damaged…
…nice bike, what I can see! … by the way
A small remark, when pushing down to see the HR on the watch, there is of course a delay before getting the first correct value.
On S9Baro I think that we had something visual to tell that watch was searching for the HR, in the current version of S9P, it is not the case (but the case for SpO2). -
@v-sacre
the heart icon with a running circle during the search, yes.
Speaking about the delay: would it be possible to flip thru the screens more flowy? when I scroll down it always stops at the HR for few seconds before I can fluently scroll further down. -
@freeheeler said in Suunto 9 Peak:
@v-sacre
Speaking about the delay: would it be possible to flip thru the screens more flowy? when I scroll down it always stops at the HR for few seconds before I can fluently scroll further down.Regarding the delays, also for starting activity.
Is this due to animations?
Right now it is the only point I find in the watch a bit annoying, in some circunstances I find it “slow”.
I remember in android times there was a trick to disable animations and make it faster, I hope that is “possible” on the suunto s9p.
Or we are on the limit of the hardware? -
@andré-faria delays are longer than in S9b?
@marcin-byrtek said in Suunto 9 Peak:
I never had S9B…
But compared to FR45,245 and F6S it is slower.
It is the only thing in the watch that to me doesn’t feel premium.
But yeah, no big issue, just my feedback. -
just now, on the train, I’m doing a test of the OHR at rest.
i measure by hand and with a chronometer 41 pulsations per minute and the watch gives me between 78 and 82…
second test, I measure 40 and the watch goes down to 42 and then goes back to 67…
third test,
i’m 42 and the watch goes down at the end of 42 after staying at 55.
And my SpO2 at 71% or not working
so random…
Register Login
