    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    ¿How to configure HR Intensity Zones in Suunto7?
    Scheduled Pinned Locked Moved Suunto 7
    18 Posts 7 Posters 1.3k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • lorylandL Offline
      loryland
      I would like to change Intensity Zones limits but I can’t find how.
      Thanks
      EgikaE Jamie BGJ Brad_OlwinB 3 Replies Last reply Reply Quote 0
      • EgikaE Offline
        Egika Platinum Member @loryland
        @loryland because it is not possible (yet)
        t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
        lorylandL 1 Reply Last reply Reply Quote 2
        • lorylandL Offline
          loryland @Egika
          @egika Understood. Thanks a lot.
          • Jamie BGJ Offline
            Jamie BG Bronze Member @loryland
            @loryland
            Not sure if this will impact it or not, but in your profile (on the watch in the suunto app - general options), you can adjust your resting and max HR. Not sure what/how/if that impact HR zones or any of the other calcs (including sleep etc).
            isaziI 1 Reply Last reply Reply Quote 0
            • isaziI Offline
              isazi Moderator @Jamie BG
              @jamie-bg max HR should impact zones.
              Blog: isazi's home
              Aleksander HA 1 Reply Last reply Reply Quote 1
              • Aleksander HA Offline
                Aleksander H Bronze Member @isazi
                @isazi Can confirm. I’ve set my max hr, and zones adjusted.
                  Incidentally. Does anyone know why the watch asks about resting heart rate? What does it use this for?
                  Jamie BGJ 1 Reply Last reply Reply Quote 0
                  • Brad_OlwinB Offline
                    Brad_Olwin Moderator @loryland
                    @loryland The zones the watch uses are in the user manual. I adjust my max on the watch to have the zones match my training zones as close as possible. This works for me.
                    Vector/T6c/Vertical 2 Ti
                      Aleksander H Bronze Member @Brad_Olwin
                      @brad_olwin said in ¿How to configure HR Intensity Zones in Suunto7?:
                      For those of us to lazy to find it,
                      • Jamie BGJ Offline
                        Jamie BG Bronze Member @Aleksander H
                        @aleksander-h - I suspect that this helps determine sleep and recovery calcs.
                        JANTIKAINENJ 1 Reply Last reply Reply Quote 1
                        • JANTIKAINENJ Offline
                          JANTIKAINEN Bronze Member @Jamie BG
                          @jamie-bg I think so too but ay idea where does it come from and does it change from time to time? In the watch my rhr is 60 and that’s too high.
                          Samsung Galaxy S24
                          Suunto Race Titanium
                          Aleksander HA EgikaE 2 Replies Last reply Reply Quote 0
                            Aleksander H Bronze Member @JANTIKAINEN
                            @jantikainen said in ¿How to configure HR Intensity Zones in Suunto7?:
                            I think 60 is just the default. Click it and you can change it.
                            JANTIKAINENJ 1 Reply Last reply Reply Quote 0
                              JANTIKAINEN Bronze Member @Aleksander H
                              @aleksander-h yes I changed it. Would be cool if the watch would change it automatically according to fit level.
                              Samsung Galaxy S24
                              1 Reply Last reply Reply Quote 3
                              • EgikaE Offline
                                Egika Platinum Member @JANTIKAINEN
                                @jantikainen be careful. The value is resting heart rate, not minimum heart rate (when sleeping).
                                Resting heart rate is when you sit on your sofa day-dreaming.
                                If you set resting HR too low it will always think you are stressed…
                                Aleksander HA JANTIKAINENJ Jamie BGJ 4 Replies Last reply Reply Quote 0
                                  Aleksander H Bronze Member @Egika
                                  @egika said in ¿How to configure HR Intensity Zones in Suunto7?:
                                  Hmm. That’s interesting.
                                  Now that we have 24/7 HR tracking, would be nice if the watch could determine resting HR itself, and maybe adjust it a couple of times a month if necesarry.
                                  [Edit] Is this actually documented anywhere? Can’t see any mention of it in the S7 manual. Only mention of resting HR seems to be where to find it and how to change it. No mention of what it affects.
                                    JANTIKAINEN Bronze Member @Egika
                                    @egika Yes no problem. It was set to 60 by default but when I measured it I had like 47 so I changed it to 50 which is more correct than 60.
                                    Samsung Galaxy S24
                                      @egika By the way, this is what Firstbeat write’s in their blog about resting hr,
                                      “How is resting heart rate determined?
                                      Resting heart rate refers to the lowest level at which a heart rate can momentarily drop. Often the time of rest and the lowest heart rate is in the morning at 03–06, the circadian rhythm of the rest of the body with physiological reactions is at its calmest. Heart rate measurements taken during coffee breaks or on home sofas certainly provide direction, but true resting heart rate is always measured overnight”
                                      Samsung Galaxy S24
                                      • Jamie BGJ Offline
                                        Jamie BG Bronze Member @Egika
                                        @egika and that is exactly what mine was doing. Have since pushed it up a bit based on my 24/7HR graphing and my recovery is now making much more sense.
                                        Based it on the phone apps sleep chart, put in HR against it. Wasn’t overly that much different to initial rate but has made a difference.
                                        • First post
                                          Last post
                                        Suunto Terms | Privacy Policy
