    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Intensity zones - empty field
    Scheduled Pinned Locked Moved Suunto 5
    16 Posts 7 Posters 1.8k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Łukasz SzmigielŁ Offline
      Łukasz Szmigiel
      So there’s this screen I’ve never used before:
      And there are two fields - one on top and the second on the bottom.
      And while I have the tempo set as the bottom field and it’s being displayed ok, the top field is nowhere to be found (I’ve set it to avg HR) during the workout. The top area is simply blank.
      What am I missing?
      S9PP 2.50.28
      ChrisAC 1 Reply Last reply Reply Quote 0
      • ChrisAC Offline
        ChrisA Platinum Member @Łukasz Szmigiel
        @łukasz-szmigiel
        hi wow you found it (and me too just looking in the app) - I thought that this Field isn’t even on the S5. I know it from the S9 where it shows you your current hr zone and it works like a „ladder“ (above the highlighted coloured field are the next higher hr and below the next lower zones) You can see your HR and see how many beats you’re away from the next higher or lower zone and so it helps you to stay in the given zone - or switch to a lower or higher one by the amount of beats it shows at the top or below the colours bar. On the S9 it also works for pace. I searched for it on the s5 but it is not mentioned in the manual (it IS in the 9s manual) couldn’t find it and I am happily surprised that it seems to be there. I am pretty sure that it wasn’t there some months ago, since I was really actively looking for it - I really liked it with the S9B - picture from the manual attached
        Cheers Christian
        Currently Race I
        Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 1
          Łukasz Szmigiel @ChrisA
          @chrisa yeah I believe it wasn’t there. My friend bought S9 recently and I’ve found it as I was giving him a short overview of SA. Pretty sure this screen wasn’t there. Or was it?
          I’ve noticed how it works and it does as you described. Pretty useful when doing zone training.
          However - notice on the image you’ve attached there’s a custom field in the top area. It seems that it can be programmed with SA but during the workout it’s not there. The bottom one works fine however.
          So, is it a bug in S5 or SA? Or am I missing something?
          S9PP 2.50.28
          sartoricS 1 Reply Last reply Reply Quote 0
          • sartoricS Offline
            sartoric Moderator @Łukasz Szmigiel
            @łukasz-szmigiel said in Intensity zones - empty field:
            For sure you’re missing the field 😁
            I can see it (using avg hr)
            SVTS - 2.50.28
            SSSWHR BARO Amber - 2.8.32
            Samsung A5 2016 - Android 7.0
            Suunto App Android 6.7.12 beta
            Suunto App IOs 3.8.0 (21526) beta on MBP M1 Max
            Łukasz SzmigielŁ 2 Replies Last reply Reply Quote 0
              Łukasz Szmigiel @sartoric
              @sartoric why it doesn’t appear on my S5 even when avg HR is set on first field? During the run, nothing is there.
              S9PP 2.50.28
                @sartoric check this out:
                It’s set in SA as in the screenshot from my original post. Avg HR on 1 and pace on 2. While pace is displayed (it’s - - as I’m indoors when taking the picture), first field (avg HR) isn’t.
                S9PP 2.50.28
                BulkanB Brad_OlwinB sartoricS ChrisAC 4 Replies Last reply Reply Quote 0
                • BulkanB Offline
                  Bulkan Moderator @Łukasz Szmigiel
                  @łukasz-szmigiel Put altitude in the top field and check if works…
                  I assume you did a soft reset before asking… is from the first course in this forum. 😛
                  Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
                  • Brad_OlwinB Offline
                    Brad_Olwin Moderator @Łukasz Szmigiel
                    @łukasz-szmigiel I’ll check this out when I get home. I have used this in Carousel mode where it worked fine but I cannot remember if both the upper and lower fields were selectable. It will be later tonight US time when I can get back to you.
                    Vector/T6c/Vertical 2 Ti
                    • sartoricS Offline
                      @łukasz-szmigiel
                      Afair S5 has slightly different view (check the middle section) due to screen size, so could be an SA issue, that’s showing the wrong one.
                      I guess there was a topic about it, and the fact that for S5 there was the carousel one.
                      Maybe it shouldn’t be there 😄
                      SVTS - 2.50.28
                        @sartoric seems possible. I think that I remember such thread. And I remember being upset that colored zones in the centre were connected to something and couldn’t be used by default (I can’t remember exactly what was is) 😄
                        But it’s here. Either planed or not - I find it very useful. Even if it’s here to stay without the top field.
                        @Brad_Olwin thanks for checking!
                        @Bulkan have you tried turning it off and on again? 😛
                        S9PP 2.50.28
                        Brad_OlwinB 1 Reply Last reply Reply Quote 1
                        • ChrisAC Offline
                          @łukasz-szmigiel tried it today too, and it looks like yours - uppermost field is missing:
                          But I am really happy that it is there now and I will certainly use it. Thanks 🙂
                          Currently Race I
                            @łukasz-szmigiel I had to wait for a different firmware. Mine is indeed what you see on the watch. I think the sport mode customization is wrong. I will report this.
                            1 Reply Last reply Reply Quote 3
                              Łukasz Szmigiel
                              Thanks for checking! Yeah, even with only one custom field, this screen is really nice.
                              S9PP 2.50.28
                              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                              • suzzloS Offline
                                suzzlo Moderator
                                It also works on a Spartan Sport Wrist
                                I think here, screen size is the key topic
                                BR
                                Suunto: Race, S9Peak, Spartan Sport Wrist
                                Garmin: FR745, Edge 530
                                SA topics:
                                • Guides - https://forum.suunto.com/tags/guides
                                  Dimitrios Kanellopoulos Community Manager @Łukasz Szmigiel
                                  @łukasz-szmigiel the issue is ack.
                                  Creator of quantified-self.io
                                  youtube.com/c/dimitrioskanellopoulos
                                  instagram.com/dimitrioskanellopoulos
                                  www.strava.com/athletes/7586105
                                    Łukasz Szmigiel @Dimitrios Kanellopoulos
                                    @Dimitrios-Kanellopoulos just a friendly reminder that the issue still persists and is also a thing in S9PP.
                                    S9PP 2.50.28
                                    • First post
                                      Last post
                                    Suunto Terms | Privacy Policy
