    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 5 24/7 HR + notifications battery life
    Scheduled Pinned Locked Moved Suunto 5
    battery lifesuunto5
    12 Posts 4 Posters 2.2k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Tomas5T Offline
      Tomas5 Gold Members
      Hello, i just bought Suunto 5 watch as replacement for my old Ambit 2S. I was quite excited that suunto materials promote 7 days battery life with 24/7 HR and mobile phone notifications. I today charged battery to 100% (first time) at 10:00. Now is 16:53 and only 83% percent of battery. I didn’t do almost anything with watch. I have HR monitoring turned on, notifications turned off, airplane mode or battery saving modes are off and backlight in toogle mode and turned off. It looks like it lost around 2,5% every hour. It means it will be drained after just 40 hours. That is far from 7 days battery life as promoted by suunto. I checked and i have newes firmware 2.13.18, watch was manufactured just 1 month ago so battery should be at it’s best. What is your experience with Suunto 5 with HR monitor turned on 24/7 ?
      Is this bad battery life normal for suunto products or I have some defective device?
      I found some older posts but it was related to older firmware version.
      Thank you.
      Suunto Ambit 2 > Suunto 5 > Suunto Race 2
      surfboomerangS 1 Reply Last reply Reply Quote 0
      • surfboomerangS Online
        surfboomerang @Tomas5
        @tomas-0 Keep in mind that the battery drainage isn’t linear. My experience is that the rate is higher above 80% and below 20% then between.
        Some things you can try before contacting Suunto support.
        • Reboot the watch and phone
        • Try to let the watch run totally dead. Then charge it fully (also a while after it reached 100%)
        If that didn’t resolve it, contact Suunto support
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
        Tomas5T 1 Reply Last reply Reply Quote 0
        • Tomas5T Offline
          Tomas5 Gold Members @surfboomerang
          @surfboomerang thank you for fast reply, i am going to google how to reboot watch and i will try whst you suggest.
            @tomas5
            Performing the soft reset:
            Suunto Ambit: long-press all 5 buttons at the same time for 10s then release them.
            Suunto Ambit2/ Ambit2 S/ Ambit 2R: long-press all 5 buttons at the same time for 10s then release them.
            Suunto Ambit3 Run/ Sport/ Peak: long-press all 5 buttons at the same time for 10s then release them.
            Suunto Ambit3 Vertical: long-press all 4 corner buttons at the same time for 10s then release them. You will need to turn the device back on by long-pressing the upper right button.
            Suunto Traverse/ Traverse Alpha: long-press all 4 corner buttons at the same time for 10s then release them. ou will need to turn the device back on by long-pressing the upper right button.
            Suunto Spartan Collection: long-press the upper right button for 12s and then release it.
            Suunto 3/ 3 Fitness: long-press the upper right and left buttons for 12s and then release them.
            Suunto 5: long-press the upper right and left buttons for 12s and then release them.
            Suunto 7: has a specific procedure and it is essential you read these instructions.
            Suunto 9/ 9 BARO: long-press the upper right button for 12s and then release it.
            OnePlus Nord 4
            • DMytroD Offline
              DMytro
              does anyone actually reach this battery life? I get 3-4,5 days out of mine s9 with hr/sleep but no notifications.
              surfboomerangS isaziI 2 Replies Last reply Reply Quote 0
                surfboomerang @DMytro
                @дима-мельниченко https://forum.suunto.com/topic/3674/suunto-9-baro-quick-discharge-problem/67?_=1616082985205
                OnePlus Nord 4
                DMytroD 1 Reply Last reply Reply Quote 0
                • DMytroD Offline
                  DMytro @surfboomerang
                  @surfboomerang but you don’t have daily hr and sleep on. I think it singnificantly decreases the battery life.
                  surfboomerangS 1 Reply Last reply Reply Quote 1
                    @дима-мельниченко That indeed can reduce the battery lifetime significantly
                    OnePlus Nord 4
                    • Tomas5T Offline
                      i will return in few days with info if soft reset and full charge cycle helped.
                      • isaziI Offline
                        isazi Moderator @DMytro
                        @дима-мельниченко OP is talking about the S5 not the S9.
                        Blog: isazi's home
                        • DMytroD Offline
                          DMytro @isazi
                          @isazi are there more advanced algos or more energy efficient hr sensor in s5? Battery on s9 is supposed to be beaffier, no?
                          I kinda extrapolated my experience with s9 and spartan trainer whr, which is the previous to s5 modell. But of course I can’t say for sure, since I had no direct experience with s5.
                          • Tomas5T Offline
                            Tomas5 Gold Members
                            This is my battery life. HR 24/7 enabled, sleep tracking enabled, bluetooth notifications disabled, vibration disabled, tones in button off mode. I did use GPS for 10minutes. I had one indoor activity with HR for 20 minutes. Once per day i synchronised with suunto app. Every day a played with watch around 5-10 minutes. Backlight was off 99% of time.
                            So it looks i was too rush. Battery drop was fast only above 80% of battery. At around 80% i did soft reset. Maybe it helped to stop rapid battery drain.
                            I am very satisfied with result.
                            1 Reply Last reply Reply Quote 7
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
