    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Something went wrong!
    Scheduled Pinned Locked Moved Suunto 7
    ascents
    14 Posts 4 Posters 932 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      Sascha Domres Bronze Member
      https://photos.app.goo.gl/7pRSRXDgT9ULGirD7
      Something went wrong!The ascents measured are not correct. Suunto App shows 2577 m? Strava has 476 m Imported. 476 m should be correct…
      Wahoo shows 519 m…
      Maybe a Bug in the App?
      • isaziI Offline
        isazi Moderator
        First check some common answers here: https://forum.suunto.com/topic/4301/suunto-7-altitude-issues/
        Blog: isazi's home
        S 1 Reply Last reply Reply Quote 1
        • S Offline
          Sascha Domres Bronze Member @isazi
          @isazi thank you… i did that… but i don’t understand the reason… i don’t talk about 100 m…
          And strava hast the right ascent…
          https://photos.app.goo.gl/o25oYPktG7ZcVUFm7
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @Sascha Domres
            @sascha-domres did you correct the elevation on Strava?
            Blog: isazi's home
            S 1 Reply Last reply Reply Quote 0
            • S Offline
              @isazi you are right, Strava has correct the ascent automaticly…
              maybe it has to do with the fact that I drove part of the route according to a route that I had built with the Suuntoapp. At some point I drove free … My Wahoo bolt showed 519 m ascent after the tour. This value seems very realistic to me. I started my tour at about 300 meters above sea level … So I don’t live in the Alps 🙂
              freeheelerF 1 Reply Last reply Reply Quote 0
              • freeheelerF Offline
                freeheeler @Sascha Domres
                @sascha-domres
                in strava you can basically “switch” between corrected and “measured” altitude.
                What would be interesting is to see a link of your activity when you upload it to quantified-self.io. My opinion: there you see the real thing and you can determine by the graph etc if something went wrong
                living sideways
                pilleusP S 2 Replies Last reply Reply Quote 1
                • pilleusP Offline
                  pilleus @freeheeler
                  @freeheeler said in Something went wrong!:
                  Yes, but only with watches with barometer which are in Strava’s database.
                  A precise barometer watch is nearby Strava’s corrected data. And Strava’s data concerning the altitude are excellent.
                  https://www.instagram.com/moves.are.life/
                  Suunto Vertical Black Lime
                  Suunto 9 Peak Pro Black
                  Suunto Spartan Ultra Stealth Titanium
                  freeheelerF 1 Reply Last reply Reply Quote 2
                    freeheeler @pilleus
                    @pilleus
                    a baro watch should be close to Strava, yep 🙂
                    his S7 seams to be off by >500%, even with baro… that’s why it would be helpful to see the graph… it’s a bit redundant to the other thread. but well, I understand that, sometimes it’s not easy to match the word used in the thread with the search word someone has in mind
                    living sideways
                    pilleusP 1 Reply Last reply Reply Quote 1
                    • S Offline
                      Sascha Domres Bronze Member @freeheeler
                      @freeheeler
                      https://quantified-self.io/user/t50RPd8omhRjaYk6RdDBVJB9eAb2/event/fac65fba2117b72260f9e36f139b19fa270d503428044f8c53ad58a7ac17b35d
                      I hope ist works
                      isaziI 1 Reply Last reply Reply Quote 2
                      • pilleusP Offline
                        pilleus @freeheeler
                        @freeheeler I think that the possibility to calibrate the altitude manually would solve a few problems with the S7.
                        I do not understand, why this is missing. A precise altitude on the start point and the barometer and fused alti will give perfect data. 👍
                        I assume that the watch can work properly without covering the barometer.
                        • isaziI Offline
                          @sascha-domres lots of spikes on your altitude profile. Do you have a picture of how were you wearing the watch? Maybe something was covering the baro sensor?
                          Blog: isazi's home
                          freeheelerF S 2 Replies Last reply Reply Quote 1
                            freeheeler @isazi
                            @isazi
                            too many spikes, fully agree 👍
                            it looks very obvious to me
                            living sideways
                            • S Offline
                              @isazi Okay, thanks for the many answers. It may well be that I covered the barometer with half of my jacket.I didn’t really think about it, I just wanted to see the pulse and route and couldn’t go without a jacket because it was too cold … yes, pushed up and then surely slipped down to the S7
                              • isaziI Offline
                                @sascha-domres it’s possible, check if it happens again and if that is the reason. And if you believe there is something wrong with your watch, contact support also.
                                Blog: isazi's home
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
