    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    "route_in_progress" ?
    Scheduled Pinned Locked Moved Suunto 7
    10 Posts 5 Posters 930 Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Nigel Taylor 0N Offline
      Nigel Taylor 0 Bronze Member
      Imported a GPX to the Suunto App on phone, added my POI’s, and clicked the toggle to sync to watch.
      On the watch if I start the Suunto App and select a route, I’ve now got the routes I expect to have, plus an extra duplicate of the latest one, which has a name of “route_in_progress” (not a name I’ve ever given).
      I removed all routes from the watch (in the phone app), and that extra “route_in_progress” route remains.
      Rebooted Watch, its still there, re-added the routes I want on the Watch by toggling in the phone app, they all arrive, but the “route_in_progess” route remains.
      How do I get rid of it? 😞
      Rob33R Brad_OlwinB 2 Replies Last reply Reply Quote 1
      • Rob33R Offline
        Rob33 Bronze Member @Nigel Taylor 0
        @nigel-taylor-0 I have exactly the same case!
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @Nigel Taylor 0
          @nigel-taylor-0 soft reset the watch and it should take care of it.
          Vector/T6c/Vertical 2 Ti
          Nigel Taylor 0N 1 Reply Last reply Reply Quote 0
            Nigel Taylor 0 Bronze Member @Brad_Olwin
            @brad_olwin How do I do that?
            I can only see how to ‘restart’ or ‘reset to factory settings’ (hard-reset?)
            ‘restart’ hasn’t resolved it.
            ‘reset to factory settings’ I don’t want to do!
            Mff73M 1 Reply Last reply Reply Quote 0
            • Mff73M Offline
              Mff73 @Nigel Taylor 0
              @nigel-taylor-0
              https://forum.suunto.com/topic/5843/duplicated-route-route-in-progress/10
              SSU (retired), SV1, SV2
              Wife : S9PP
              SA: Always the latest beta :)
              Android + Galaxy S205G
              Nigel Taylor 0N 1 Reply Last reply Reply Quote 2
                Nigel Taylor 0 Bronze Member @Mff73
                @mff73 said in "route_in_progress" ?:
                @nigel-taylor-0
                Thanks - logout and login of the phone app did the trick…syncs the ‘route_in_progress’ route across to the phone app, then just untick the saved on watch toggle, and delete the route, and all is good again.
                Rob33R 1 Reply Last reply Reply Quote 2
                • Rob33R Offline
                  @nigel-taylor-0 I had to do it several times, after having unpaired and then paired at the beginning the sync did not work, but it ended up working …
                  In this respect I noticed that quite often the synchronization of the routes is a little random, it is often necessary to start again several times …
                  • Mff73M Offline
                    Mff73 @Rob33
                    @rob33
                    Did you unpair and repair “only” ? Or logout and login ?
                    As far as I discovered, logout do unpair AND login will trigger routes from watch properly.
                    Wife : S9PP
                    Rob33R 1 Reply Last reply Reply Quote 0
                    • Rob33R Offline
                      Rob33 Bronze Member @Mff73
                      @mff73 I started by “forgetting” the connection on the SA app, dissociating the bluetooth connection and deleting the connection in the watch …
                      But it took a couple of times for it to work. At the beginning the “route in process” appeared in SA but even by unchecking this route and then synchronizing, it remained present in the watch …
                      But like I said this is not the first time that I have to go over and over again to delete or add routes in the watch … I find that this bug quite often.
                      F 1 Reply Last reply Reply Quote 0
                      • F Offline
                        Frederic Bronze Member @Rob33
                        I have the same issue 😞
                        Anyone has found a permanent fix ? Is Suunto aware of it ?
                        Suunto Vertical
                        My Suunto Workflow
                        MyTourbook - First Steps
                        Questions or bugs ?
                        Register Login
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
