    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Two way sync SA <-> S7
    Scheduled Pinned Locked Moved Suunto 7
    21 Posts 9 Posters 1.9k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • JorgeFDJ Offline
      JorgeFD
      This month I’m just doing a lot of virtual cycling using Zwift. It’s hard (for me) to see this everyday
      and in SA
      it is 2021. come on suunto!
      BulkanB Aleksander HA Brad_OlwinB Jamie BGJ 4 Replies Last reply Reply Quote 6
      • BulkanB Offline
        Bulkan Moderator @JorgeFD
        @jorgefd78 so are you asking for backward sync?
        From Suunto app to Suunto watches?
        Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
        JorgeFDJ 1 Reply Last reply Reply Quote 1
        • JorgeFDJ Offline
          JorgeFD @Bulkan
          @bulkan yes
          • Aleksander HA Offline
            Aleksander H Bronze Member @JorgeFD
            @jorgefd78 I’d also like this. I’ve started doing Yoga and I register my yoga sessions in the app after completing them so I can keep tabs on how often I’m doing it (making sure I do 3 a week). I only noticed yesterday that this information is not being synced back to my Suunto 7. I always take my watch off when doing Yoga as it gets in the way otherwise, so no point tracking it driectly on the watch.
            • sartoricS Offline
              sartoric Moderator
              There was an old request for this, as the Training views ( eg. target counter ) on watch is not in sync in those cases
              SVTS - 2.50.28
              SSSWHR BARO Amber - 2.8.32
              Samsung A5 2016 - Android 7.0
              Suunto App Android 6.8.9 beta
              • Brad_OlwinB Offline
                Brad_Olwin Moderator @JorgeFD
                This post is deleted!
                • JorgeFDJ Offline
                  JorgeFD @sartoric
                  @sartoric yes! I remember this and before I post this message I tried to find but didn’t find it
                  • Jamie BGJ Offline
                    Jamie BG Bronze Member @JorgeFD
                    @jorgefd78 currently only way to see this is in google fit - and google fit with latest updates only shows current week.
                    JorgeFDJ 1 Reply Last reply Reply Quote 0
                    • JorgeFDJ Offline
                      JorgeFD @Jamie BG
                      @jamie-bg what a mess 😞
                        @jorgefd78 said in Two way sync SA <-> S7:
                        I think this is more complicated than you might imagine, especially for those with more than one watch. I am not sure any company does this, correct me if I am wrong but the data from each watch (you can consider zwift a watch) would need to sync back. Different watches give me different recovery times and different VO2Max so I honestly don’t see an easy way to do this.
                        BulkanB stromdiddilyS 2 Replies Last reply Reply Quote 0
                        • BulkanB Offline
                          Bulkan Moderator @Brad_Olwin
                          @brad_olwin Garmin and Apple do it.
                          In Garmin is called Physio trueup . In case you have various watches and you can pick which one is your main device as daily tracker but if you workout with another it syncs.
                          Not only in the app. In the watches too.
                          Brad_OlwinB 1 Reply Last reply Reply Quote 1
                            Brad_Olwin Moderator @Bulkan
                            @bulkan said in Two way sync SA <-> S7:
                            In Garmin is called truesync. In case you have various watches and you can pick which one is your main device as daily tracker but if you workout with another it syncs.
                            If you have two Apple watches it will sync back to both? Did not know that, I thought Garmin might.
                            BulkanB 1 Reply Last reply Reply Quote 0
                            • BulkanB Offline
                              @brad_olwin nope in two Apple watches. My mistake.
                              But in Garmin for sure works.
                              BulkanB ldxmsgL 2 Replies Last reply Reply Quote 1
                              • BulkanB Offline
                                Bulkan Moderator @Bulkan
                                Let me add the link
                                https://support.garmin.com/en-US/?faq=EjPECQK58qA0xzJ5X74vm7
                                • ldxmsgL Offline
                                  ldxmsg Bronze Member @Bulkan
                                  @bulkan It definitely works - in the dark old days before I discovered Suunto I used to wear a Vivomove as my everyday watch, and an old Fenix for running - on days I wore both they would separately sync to Garmin Connect, which would then combine the steps and the total would sync back to both watches. As I’ve said in a separate thread, as someone who wears both a S7 and an S9B, often on the same day, I would love to see this functionality in the Suunto app and watches.
                                  1 Reply Last reply Reply Quote 3
                                  • stromdiddilyS Offline
                                    stromdiddily Gold Members @Brad_Olwin
                                    @brad_olwin Coros does this and it works beautifully.
                                    Workout with one watch, sync it to the app, activate another watch as the “primary” with the click of a single button and all updated metrics sync back to the new primary device (steps, daily calories, activities, etc.)
                                    It’s by far the best thing about their app.
                                    I 100% support this. I like using my A3P when I know GPS is going to struggle or logging weight sessions directly into the app, but none of that carries over to the 9.
                                    Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
                                    User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
                                    isaziI Brad_OlwinB 2 Replies Last reply Reply Quote 4
                                    • isaziI Offline
                                      isazi Moderator @stromdiddily
                                      @stromdiddily there is definitely a feature request for this, we just need some search kung-fu to find it 🙂
                                      Blog: isazi's home
                                        Brad_Olwin Moderator @stromdiddily
                                        @stromdiddily Did not know that….agree with the OP!
                                        • isaziI Offline
                                          isazi Moderator
                                          I think this is the request: https://forum.suunto.com/topic/4482/bidirectional-syncs
                                          Blog: isazi's home
                                          BulkanB 1 Reply Last reply Reply Quote 1
                                          • BulkanB Offline
                                            Bulkan Moderator @isazi
                                            @isazi said in Two way sync SA <-> S7:
                                            Good catch.
                                            I voted too. I’m really into this. With two watches is really handy,
                                            ldxmsgL 1 Reply Last reply Reply Quote 1
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
