I am interested in a suunto application that would work on windows application and not on the phone.I have suunto ambit3.
As debated a lot on this forum this is most likely never going to happen.
Try some third party tools like quantified-self, runalyze, trainingpeaks etc…
I will get rid of the Suunto watch, the old application was not top notch, but now the new one is not working properly. All I wanted to do was put the activity on hold, but it didn’t work. I will not bother with this anymore.
@jahtba
in all your posts we try to help, but i really think we don’t understand properly what you really want to do.
What is an “activity on hold” ? -
@mff73 I am 70 years old, still active, so far I have had the Movescount app and the download is working fine. With the Movescount app, I transferred the data to Strava, where my friends are. Movescount no longer accepts activities, and the new application does not send data to Strava despite the settings. If the old has been abolished, the new should be better, but unfortunately this is not the case. You could let Movescount (they didn’t update it that way) at least continue to work on the cable. Unfortunately, Suunto does not care about its users, which will be known sooner or later.
@jahtba
In fact Suunto app still send data to Strava, as you can see in several discussions here.
If it’s not working there’s probably something strange with your configuration / specific case.It would be helpful to know what watch do you have.
@sartoric said in Suunto desktop application:
It would be helpful to know what watch do you have.suunto ambit3 sport
@jahtba you can perfectly sync your Suunto Ambit 3 Sport with Suunto App and have your workouts uploaded from Suunto App to Strava
I believe everything is described here https://www.suunto.com/Support/faq-articles/transition/how-do-i-use-the-suunto-services-with-ambit3/
If you have any specific question please ask here or contact support
@pavel-samokha
I made a mistake because I did not replace Moveslink2. This time I repeated the whole process of changes and tested the operation, the matter also works with the transfer to Strava. It will take me a while to get used to it.
Thanks for the help that helped me a lot.
Register Login
