    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery Issue when Paused
    Scheduled Pinned Locked Moved Suunto 7
    8 Posts 5 Posters 817 Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Jamie BGJ Offline
      Jamie BG Bronze Member
      I think there is a bug/feature issue when you pause an activity. From what I can see it continous to track everything in the background - can sort of understand HR maybe, but can’t understand why it continous to track GPS - there is a reason I have put it pause.
      Due to this when I pause and pop into a shop to pick up some items, GPS continous to try and track, and as it can’t fix, well you can imagine what it does to battery life. That 10-15 mins in a shop can chew through more battery than my 1 hour tracked session.
      Surely the GPS can be turned off when we pause an activity, to save battery life. Can see why keeping GPS tracking is a better option than not, when you consider the variety of reasons for pausing - i.e. you don’t want that section tracked!.
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @Jamie BG
        @jamie-bg I believe other Suunto watches in the S line do the same. The S9 will also adjust altitude with FusedAlti during a pause.
        Blog: isazi's home
        • isaziI Offline
          isazi Moderator
          So, thinking about this I believe this is not a bug but a clear design decision from Suunto. If pause would stop the sensors, you would need time to reacquire GPS, HR, etc. after each break, and that would be a disaster for most users. Better would be to have a long kind of break that disables everything, similar to Garmin’s “resume later” option, and leave the current pause as it is.
          Blog: isazi's home
          Brad_OlwinB Mff73M 2 Replies Last reply Reply Quote 3
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @isazi
            @isazi said in Battery Issue when Paused:
            And…this is solved by just starting another activity if the pause is sufficiently long. I see this as a rather low priority issue compared to having auto pause or customizable HR zones, disabling auto lap, etc.
            Vector/T6c/Vertical 2 Ti
            • Mff73M Online
              Mff73 @isazi
              It was clearly this for SSU at least.
              Those who need to keep battery during long pause without stopping activity, need to des activate GPS during pause, and activate it manually again after pause. I don’t know if it is the same for S7.
              SSU (retired), SV1, SV2
              Wife : S9PP
              SA: Always the latest beta :)
              Android + Galaxy S205G
              Jamie BGJ 1 Reply Last reply Reply Quote 0
              • Jamie BGJ Offline
                Jamie BG Bronze Member @Mff73
                @mff73 no convient option to do this in S7 - very automtated from this perspective.
                Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                  Dimitrios Kanellopoulos Community Manager @Jamie BG
                  @jamie-bg This is a drawback but also according to design for all suuntos.
                  Drawback -> Pause and go indoors. GPS powers fully and wastes battery
                  Benefit -> No wait for GPS lock , still can use maps , still can see speed etc.
                  Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
                  Jamie BGJ 1 Reply Last reply Reply Quote 2
                  • Jamie BGJ Offline
                    Jamie BG Bronze Member @Dimitrios Kanellopoulos
                    @dimitrios-kanellopoulos - maybe if paused the GPS fix setting could change to a quick check every 1/2 mins and if no fix after 10s stops trying - that would significantly improve battery life, especially from it continously trying to fix.
                    And or maybe if app paused and in background - no GPS.
                    If running and in background GPS remains active?
                    Not sure how feasible any of these options are - but would think they are worth a consideration, especially considering the target market.
                    Register Login
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
