    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    How to add a map / track to a move in Suunto App?
    Scheduled Pinned Locked Moved Suunto app and other software services
    9 Posts 6 Posters 1.3k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Kuba SarataK Offline
      Kuba Sarata Bronze Member
      Hi all,
      my wife just asked me an interesting question. Looking for an answer for a while now but nothing’s popping out. Hope you’ll be able to help me out 🙂
      The question was - how to add a track /map I’ve created in route planner to a move I’ve created in the app. In Movescount there was an option to create a route and then add it like that but I can’t find it here.
      Any ideas? Thanks a milion!
      Kuba
      surfboomerangS 1 Reply Last reply Reply Quote 1
      • surfboomerangS Offline
        surfboomerang @Kuba Sarata
        @kuba-sarata Not sure if I understand you correctly, but you can import created routes with a GPX file. And you can also create a new route from a previous activity by saving it as a route.
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
        Kuba SarataK 1 Reply Last reply Reply Quote 0
          Kuba Sarata Bronze Member @surfboomerang
          @surfboomerang thank you for replying 🙏 What I’ve meant is a situation when:
          1. I’m adding a move manually to the Suunto App. Just taping add and adding data from memory.
          2. The move doesn’t have a map / track as it was created manually.
          3. I’m creating a track in the route planner (in the App)
          4. I want to add the track to the move I’ve created <-- this step I don’t know how to make.
            Cheers!
          Brad_OlwinB Mff73M 2 Replies Last reply Reply Quote 1
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @Kuba Sarata
            @kuba-sarata That is not possible AFAIK. You need to track the activity with a Suunto watch or the app. If you have a fit file you can upload that to the Suunto App using Quantified Self.
            Vector/T6c/Vertical 2 Ti
            • Mff73M Offline
              Mff73 @Kuba Sarata
              @kuba-sarata said in How to add a map / track to a move in Suunto App?:
                Cheers!
              as @Brad_Olwin said, the only way now to do what you want, would be to convert your track made in this external route planner into a REAL activity fit file = with time stamps, and all data required by fit structure.
              This way it could be possible . it won’t be exactly your process : not create a manual activity in SA and add it a track, but import a totally externally activity fit file.
              SSU (retired), SV1, SV2
              Wife : S9PP
              SA: Always the latest beta :)
              Android + Galaxy S205G
                @Brad_Olwin @Mff73 thank you for your feedback. It’s a shame that it’s not possible anymore. Cheers!
                • E Offline
                  Emery Walls
                  I’m also having difficulty with this issue
                  E 1 Reply Last reply Reply Quote 0
                  • E Offline
                    Emery Walls @Emery Walls
                    @Emery-Walls said in [How to add a map / track to a move in Suunto App? [LINK REMOVED ] can help you add a route/map that you created in the route planner to a route you created in the app
                    sartoricS 1 Reply Last reply Reply Quote -1
                    • sartoricS Offline
                      sartoric Moderator @Emery Walls
                      @Emery-Walls
                      This looks like spam or worse … speak now or forever hold your ban
                      SVTS - 2.50.28
                      SSSWHR BARO Amber - 2.8.32
                      Samsung A5 2016 - Android 7.0
                      Suunto App Android 6.8.9 beta
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
