    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Activities in SA map
    Scheduled Pinned Locked Moved Suunto app and other software services
    11 Posts 4 Posters 928 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • EfejotaE Offline
      Efejota Bronze Member
      I guess this is not the right forum, but SA forums seems to be related to bugs, etc. (admin: move to the appropriate one, if neceesary).
      I am wondering if it is possible to select a certain activity previously done (and thus, marked on the map) from the map screen in iOS SA. I have been trying to do it to check data from that activity whose date I do not remember and I have not found a way. Additionally, it would be a good way to save them as routes, if necessary.
      Any hint?
      Thanks
      sartoricS Brad_OlwinB 2 Replies Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @Efejota
        @efejota
        Just use the profile map and click on the activity
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.10.7 beta
        EfejotaE 1 Reply Last reply Reply Quote 1
        • EfejotaE Offline
          Efejota Bronze Member @sartoric
          @sartoric That is what I cannot do. I go to the map, see the lines of my activities there, but there is no list of activities and have found no way to select it touching on the line…
          Thanks for moving the post
          sartoricS 1 Reply Last reply Reply Quote 0
          • sartoricS Offline
            @efejota
            Are you using the map from the profile page?
            Maybe it’s not yet working in IOS
            SVTS - 2.50.28
            • EfejotaE Offline
              @sartoric I have accessed the map form every possible way in the App. The one close to the calendar, in home screen, and the map specific interface. If I go into my user icon (is that what you mean with “profile”?) there is no map.
              And in no map there is such a possibility. Maybe iOS limitation? Has anyone tried in that OS?
              Thanks
              • Brad_OlwinB Offline
                Brad_Olwin Moderator @Efejota
                @efejota you can see the activity in the map based on date range but you cannot select it unless you do so from the activity. You can create a route from the activity as well.
                Vector/T6c/Vertical 2 Ti
                Mff73M 1 Reply Last reply Reply Quote 0
                • Mff73M Offline
                  Mff73 @Brad_Olwin
                  @efejota
                  As @sartoric said, in Android, you can do what you want.
                  Go in your profile like you did, but then, click on the 3dots icon (menu)
                  On this map, you can click on dots to see and go to this particular activity.
                  Maybe not the same in iOS…
                  SSU (retired), SV1, SV2
                  Wife : S9PP
                  SA: Always the latest beta :)
                  Android + Galaxy S205G
                  • EfejotaE Offline
                    Efejota Bronze Member @Mff73
                    @mff73 clearly it is an iOS issue, no three dots icon.
                    And the map shows no dot to check, no matter from where do you access
                    @Dimitrios-Kanellopoulos, do you know if it is something to be developed or it will simply not be there in future updates? If the latter, it would be good to consider its addition, in my opinion.
                    @Brad_Olwin. Accessing from the map is more convenient. Think of going back to a place you have previously been but do not remember exactly when. It would be very easy to check that activity to have a route back, for instance.
                    Mff73M 1 Reply Last reply Reply Quote 1
                    • Mff73M Offline
                      Mff73 @Efejota
                      @efejota
                      Just to be sure, in this gear menu, don’t you have something like another link to another map?
                      But, little search on forum and it seems that it is an old “lack” of iOS vs Android.
                      Personnaly, I use this map very often to search for old moves of mine.
                      https://forum.suunto.com/search?term=IOS map&in=posts&matchWords=all&sortBy=relevance&sortDirection=desc&showAs=posts&page=2
                      Wife : S9PP
                      EfejotaE 1 Reply Last reply Reply Quote 0
                      • EfejotaE Offline
                        @mff73 No, nothing like that. It is a clear shortcoming of the iOS version, indeed.
                          @efejota said in Activities in SA map:
                          The versions are not identical and some features are not at parity. Whether all features will be at parity I do not know. These types of differences have happened many times in the past.
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
