    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Bumpy and inaccurate altitude data with new Suunto 7
    Scheduled Pinned Locked Moved Suunto 7
    55 Posts 8 Posters 9.8k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • BrunoHB Offline
      BrunoH Gold Members @daltonthomas
      Hi @daltonthomas , unfortunately that error has been reported here in the forum numerous times. My own dialogue with Suunto support didn’t result in any concrete resolution. One possible reason might be the barometer hole being blocked. I wish Suunto could fix this. I ended up changing my Suunto 7 to another model with less “smart” features and more sports stuff. Altitude was not my only concern; there were stability problems too, some of which have been fixed already in a newer firmware!
      Compasses: M-311, A-10, SK-7
      Diving: Finnlight Navy 90, Vyper
      Sports: Metron, S7, S9B and Vertical
      • freeheelerF Offline
        freeheeler @daltonthomas
        @daltonthomas
        I think it’s reasonable to send it to Suunto once again with this data, comparison and detailed description.
        I hope you don’t loose trust in Suunto. I think they’re fantastic watches and maybe you “only” received a “monday morning” model.
        @BrunoH
        I know the issues of blocking baro holes from my old Suunto Core and now from my S9B. The S7 (my very own opinion as a development and design engineer) has a much better baro hole design to prevent the blocking and hence wrong measurements.
        But I learned how to buckle up my S9B to my specific needs and never had problems since 👍
        living sideways
        • D Offline
          daltonthomas
          Thanks for your help!
          The watch is packed and will be send tomorrow to Suunto service.
          The experience with this Suunto7 is not the best but the experience i had and still have with my old ambit2 is great. Therefore it will need a while till i will change the brand…:).
          If i would buy again a new Suunto watch i guess i would go for the S9 because of battery and sensors and hopefully less issues with the altitude measurement.
          • T Offline
            themrdjj
            I’m sending my watch back tomorrow as well. What I don’t understand is how they can just send a watch back to you within warranty that clearly isn’t working properly. I hope that doesn’t happen to me and it actually gets fixed or replaced. Before this I had a Polar watch but I really wanted one with full maps and the Garmin ones were too expensive for me. Let’s hope I don’t end up regretting my choice for Suunto.
            • D Offline
              daltonthomas
              @themrdjj
              Hopefully we both get a properly repaired watch back. I guess that standard suunto test procedure didnt catch the failure of my watch and they didnt read exactly my descpription of failure. Having the full maps was also the reason i changed from my old Suunto to Suunto7.
              • T Offline
                themrdjj
                The watch just arrived back from Suunto, much faster than expected. However, it came with the following comment: “I have tested your device for the faults reported in the fault description and performed all the necessary tests but discovered no fault with the pressure sensor.” That’s what I was afraid would happen. Well, I’m not sure what to do now. I’ll do more testing over the next week and post the results here again.
                Mff73M Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 2
                • Mff73M Offline
                  Mff73 @themrdjj
                  @themrdjj
                  i may have not read all the post carefully, sorry in advance, but :
                  do you have tested your non faulty S7 alone and yourself ?
                  i think you have tested :
                  you wearing faulty S7 --> you got issue
                  you wearing faulty S7 + someone wearing good S7 --> you got issue + someone didn’t
                  you wearing faulty S7 + you wearing good S7 --> you got issue on faulty S7 and good results on the other.
                  Could it be an issue influenced by your way of wearing the “main” watch (near the wrist, or…) and the second watch is worn “better” ?
                  SSU (retired), SV1, SV2
                  Wife : S9PP
                  SA: Always the latest beta :)
                  Android + Galaxy S205G
                  freeheelerF T 2 Replies Last reply Reply Quote 1
                    freeheeler @Mff73
                    @Mff73
                    I remember he did a test with both watches attached to his backpack, too… same results
                    living sideways
                    Mff73M 1 Reply Last reply Reply Quote 1
                    • Mff73M Offline
                      Mff73 @freeheeler
                      @TELE-HO said in Bumpy and inaccurate altitude data with new Suunto 7:
                      @Mff73
                      OK.
                      Maybe a backpack issue ? 🤣
                      Or some magnetic gloves ? 😉
                      Wife : S9PP
                        Dimitrios Kanellopoulos Community Manager @themrdjj
                        @themrdjj send it again and pm me with the case number if it still does not work ok.
                        Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                        • D Offline
                          daltonthomas
                          Just for information, i`ll get my watch back the next days. I got following information from service.
                          “Dear customer, I have replaced your device with a replacement unit that will come with a three (3) month service
                          warranty, which applies if the original devices warranty has expired”
                          I`ll let you know how correct the sensor is working as soon i did the first tours.
                          Cheers.
                          • T Offline
                            themrdjj @Mff73
                            @Mff73 I haven’t compared it with another Suunto 7, just with my old Polar watch, my phone’s data and the Strava-corrected data. I will do more tests this week and pay even more attention to wearing it correctly, let’s see.
                            @Dimitrios-Kanellopoulos Will do, thanks!
                            @daltonthomas That’s good to hear!
                            Mff73M 1 Reply Last reply Reply Quote 0
                            • Mff73M Offline
                              Mff73 @themrdjj
                              @themrdjj
                              Sorry, i mixed with @daltonthomas 😞
                              Wife : S9PP
                              freeheelerF 1 Reply Last reply Reply Quote 0
                                freeheeler @Mff73
                                @Mff73
                                me too 🙈
                                living sideways
                                • T Offline
                                  themrdjj
                                  Here’s another thing to try out. Can some of you who have a S7 please download this app :https://play.google.com/store/apps/details?id=de.taxilearn.phi.hoehenmesser and compare it with the following video of what it looks like on mine? The amplitude of the pressure change seems to be around 0.1-0.2 hPa.
                                  https://youtu.be/sD4pk6ZnfZ0
                                  pilleusP 1 Reply Last reply Reply Quote 0
                                  • pilleusP Online
                                    pilleus @themrdjj
                                    @themrdjj my S7 is jumping between 972,88 and 972,92 hPa. I calibrated to the correct pressure at sea-level.
                                    The identical amplitude on my Casio WSD-F21HR and Skagen Falster 3.
                                    https://www.instagram.com/moves.are.life/
                                    Suunto Vertical Black Lime
                                    Suunto 9 Peak Pro Black
                                    Suunto Spartan Ultra Stealth Titanium
                                    • T Offline
                                      themrdjj
                                      I did some more testing over the last week, here are some altitude profiles where I compare the raw data from the S7 to the Strava-corrected data (the colours are mixed up, but it’s clear which one comes from the watch). Sometimes it’s worse, sometimes better, but the overall magnitude is wrong and it’s pretty bumpy (and no, those bumps are definitely not correct).
                                      I made sure that the watch was always synced and I did frequent reboots as well. I always waited at least 1-2 minutes after the GPS connection was found, often longer. The GPS tracks in all of these activities were pretty good, so the GPS certainly isn’t the problem.
                                      While wearing the watch (on my left arm, a few cm away from the wrist), I always made sure not to cover the barometer hole. I don’t sweat much either, don’t have very hairy arms and didn’t use the watch in muddy or particularly wet conditions, so I’m quite sure that the barometer itself just isn’t working properly, perhaps in a way that is overlooked during the standard Suunto lab tests.
                                      I’m sending in the watch again this afternoon. @Dimitrios-Kanellopoulos I’m going to send you the number by PM now.
                                      @daltonthomas Any updates on yours?
                                      freeheelerF 1 Reply Last reply Reply Quote 2
                                        freeheeler @themrdjj
                                        @themrdjj
                                        good luck, dude!
                                        I hope they find the issue or at least change the sensor ✊
                                        living sideways
                                        • D Offline
                                          daltonthomas
                                          Hello,
                                          today my wife tested the watch back from service with new replacement unit.
                                          Because bluetooth adress changed, i believe really the unit was changed.
                                          Its unbelievable, the first tour ( she climed a mountain from 841 m altitude to 1516 m altitude), the watch showed 3824 m ascend and 3832 m descend. She wore the watch correctly on her left arm.
                                          We are starting of thinking that we are too stupid in using a Sport watch correctly…:)
                                          What we know is that the last 5 years with the Suunto Ambit2, we never had issues with the altitude.
                                          Enclosed the more detailed data of the track. I have no idea how the wrong data comes from because the altitude itself is more or less correctly (apart from the descent-parts during climbing up). During the tour the data of the watch was not checked, therefore i don`t know when the wrong altitude started.
                                          Data of the track:
                                          https://quantified-self.io/user/rxqh5UVb9LhOn2n6zRIh2gHKXMH2/event/9gLkppcytWZHY1uCZMnx
                                          freeheelerF T 2 Replies Last reply Reply Quote 0
                                            @daltonthomas
                                            if you zoom in you see a lot of spikes in the alti graph. I saw something similar today with my S9B. Wet condition, watch worn relatively loose on the wrist with the body over the jackets cuff.
                                            It gave me 721m instead of reality around 520m.
                                            Back to “if you zoom in”: you gain over 27m within 20 seconds. This would result in over 4’800 meter per hour 😉
                                            Maybe something covered the sensor unintendedly.
                                            I would give it some more tries ✊
                                            living sideways
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
