    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Impossible to have GPS
    Scheduled Pinned Locked Moved Suunto 7
    9 Posts 5 Posters 1.0k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Georges De AquinoG Offline
      Georges De Aquino
      Hello EveryBody!
      When I want start an activity with my S7 (new), it’s impossible for me to have GPS, arrow GPS on Suunto App still grey, I can wait longer but no change…
      I have WIFI connection to help watch, but result is same…
      Thanks
      pilleusP Brad_OlwinB 2 Replies Last reply Reply Quote 0
      • pilleusP Offline
        pilleus @Georges De Aquino
        @Georges-De-Aquino is location enabled in watch settings - connectivity?
        https://www.instagram.com/moves.are.life/
        Suunto Vertical Black Lime
        Suunto 9 Peak Pro Black
        Suunto Spartan Ultra Stealth Titanium
          Georges De Aquino
          Problem is same…
          I don’t understand
          Setting:
          Bluetooth On
          Wifi On
          NFC
          AirPlane: Off
          Positionning (To phone and Watch): On
          And Suunto App:
          Saving Energy
          Localisation Precision : Better
          Screen: Off
          Jamie BGJ 1 Reply Last reply Reply Quote 0
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @Georges De Aquino
            @Georges-De-Aquino what type of activity?
            Vector/T6c/Vertical 2 Ti
              Georges De Aquino
              for exemple, running
              • Jamie BGJ Offline
                Jamie BG Bronze Member @Georges De Aquino
                @Georges-De-Aquino have you installed any 3rd party GPS apps?
                Also check app permissions for suunto app.
                Is location enabled on the Google fit app?
                When you are outside, prior to starting activity, have you tried going to the map screen, and pressing on position icon.
                If you start activity, do you get a fix and track after a couple of minutes, and does it track ok for rest of activity?
                  Georges De Aquino
                  Thanks you for you help
                  1. No others GPS are installed on my watch
                  2. Permissions for Suunto are able
                  3. I don’t you use Google Fit, but I started App, and location is enable
                    But No GPS
                  I find in a forum how to test GPS only for Google Wear Watch in developper mode.
                  But no captation of GPS!!!
                  "I strongly suggest that you run a manufacturer’s GPS test on your watch. Firstly make yourself a developer by going to Settings > System > About and tapping the build number 7 times. You will find a new Developer options menu item. Select this, and scroll down to Manufacturer service tool and select it. You will find a GPS Test option which you can run (you need a clear view of the sky, not indoors). This will test the standalone GPS in your watch and its ability to lock onto satellites. If your watch passes this test (ie. finds satellites) then you should be able to use untethered GPS in your fitness app. "
                  • Jamie BGJ Offline
                    @Georges-De-Aquino are you sure you have a suunto 7?
                    So you enabled Dev options?
                    You went into Dev Options and scrolled right to the bottom where you chose Manufacturer (service tool)?
                    You then scrolled down the list to the 4th last option (between pressure and ECompass)? - Says GPS Test?
                      Dimitrios Kanellopoulos Community Manager
                      Hi. I think your unit is faulty. Please contact support. I can help if needed.
                      Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
                      Register Login
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
