    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 not connecting to google fit
    Scheduled Pinned Locked Moved Suunto 7
    6 Posts 2 Posters 1.3k Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • J Offline
      JohnJacobs
      Hello, i can’t connect the google fit app to my watch.
      i tried several times but always no connection
      What do i wrong
      Thxx in advance for your help
      John from the Netherlands
      Jamie BGJ 1 Reply Last reply Reply Quote 0
      • Jamie BGJ Offline
        Jamie BG Bronze Member @JohnJacobs
        @JohnJacobs
        Are you talking about not being able to 1) install your profile on google fit and or are you referring to 2) when you use the google fit phone companion app? If not either of these you may have to explain/provide more detail of your issue.
        1. Open Google Fit on your watch - (it should automatically run through the setup which includes adding your profile, in which case follow the instructions); Scroll down to settings and press it, Scroll down to Fit Account and press it, Choose your google account - if you have the wrong account set up, sign out, then choose the correct google fit account (needs to match the one on your phone).
        2. On your phone, google fit needs to be installed, and you need to be using the same google account as google fit on your watch. Open google fit on your phone, press icon on top right to confirm account is correct (change if necessary to match watch). Make sure the suunto app is linked by pressing on Profile (bottom right button), click on settings (cog icon top right), manage connected apps - make sure suunto wear is included. as a google fit apps and devices.
        3. On your watch launch the suunto app (top right button) - scroll down and select general options - Scroll down to where it says Google Fit and make sure the right account is selected, and that it is on.
        • J Offline
          JohnJacobs
          1. Open Google Fit on your watch - (it should automatically run through the setup which includes adding your profile, in which case follow the instructions); Scroll down to settings and press it, Scroll down to Fit Account and press it, Choose your google account - if you have the wrong account set up, sign out, then choose the correct google fit account (needs to match the one on your phone). My google fitt app disepeared (starting the start button left)
            Here is i think the problem, for getting a google fit account where i have to do this. i have a google account , is it the same or do i need to make it seperate and were i have to do this
          3.On your watch launch the suunto app (top right button) - scroll down and select general options - Scroll down to where it says Google Fit and make sure the right account is selected, and that it is on.
          This i can select no problem but i every time select my google account but it will not connect probebly I’m not doing something right
          THxx in advance for your help
          John
          Jamie BGJ 2 Replies Last reply Reply Quote 0
          • Jamie BGJ Offline
            @JohnJacobs
            There isn’t an app called Google fit, it’s broken into fit breathe, fit goals and fit heart rate. Launch fit goals (alternatively add workout tile as one of your tiles)
            • Jamie BGJ Offline
              @JohnJacobs use the same Google account for phone Google fit app and for watch Google fit app.
              • J Offline
                JohnJacobs
                Ok, thxx, i will try again
                • First post
                  Last post
                Suunto Terms | Privacy Policy
