    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Will there be a way to export training data as GPX to a PC after the transition?
    Scheduled Pinned Locked Moved Digital service transition
    10 Posts 5 Posters 1.8k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • László Lajos JánszkyL Offline
      I have only an old Android phone and I doubt the Suunto app will run on it. Currently I just sync my Ambit 3 Run with Moveslink2 on my Windows PC and download the GPX file from Movescount. Will there be a way to do the same after the transition?
      • isaziI Offline
        isazi Moderator
        You can use Suuntolink on your PC, but will need, I guess, to create an account on the app.
        Blog: isazi's home
        • isaziI Offline
          isazi Moderator
          Then to access FIT or GPX files you can connect the app to a service like quantified-self that you can access with your browser.
          Blog: isazi's home
            Isn’t there a way to mock out movescount.com? I mean I could add it to my hosts file and write a local service that would receive whatever the watch sends. Or does it sync with SSL?
            M 1 Reply Last reply Reply Quote 0
            • M Offline
              margusl @László Lajos Jánszky
              @László-Lajos-Jánszky said in Will there be a way to export training data as GPX to a PC after the transition?:
              https://github.com/ghoss/Movescount_Emu
              László Lajos JánszkyL 1 Reply Last reply Reply Quote 1
                László Lajos Jánszky @margusl
                @margusl Lookos good, but it is only for Ambit 1 and 2 watches and I have Ambit 3.
                  Dimitrios Kanellopoulos Community Manager
                  I think the watch is not communicating directly with movescount
                  Creator of Quantified-Self.io
                  youtube.com/c/dimitrioskanellopoulos
                  https://instagram.com/dimitrioskanellopoulos
                  https://www.strava.com/athletes/7586105
                  • M Offline
                    Are you referring to project desription or Moveslink2 actually failed when syncing Ambit3 with mock server?
                    As you asked if you could write a local service, adjusting existing mock should be quite trivial compared to writing one from scratch.
                    Anyway, what problem are you trying to solve by service mocking? If you just want your activities as GPX, it’s way more convenient converting Suntolink2 SML files or using Openambit instead.
                    StarryskyS 1 Reply Last reply Reply Quote 0
                    • StarryskyS Offline
                      Starrysky @margusl
                      @margusl The “movecount_emu” is missing a file: system / SQLite3 php,is there a solution? thanks!
                      • M Offline
                        margusl @Starrysky
                        @starrysky , PHP is not quite my thing and it has been a while, but I’d start by checking phpinfo() to see if sqlite module is loaded and if it’s not, you probably need to edit your php.ini
                        Is there a particular problem you are trying to solve with mocking a service?
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
