    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Plus sprints
    27 Posts 10 Posters 3.0k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • isaziI Offline
      isazi Moderator
      Sharing some sprint results using S+. I did some sprints while running, nothing structured, just sprint when you feel like sprinting, keep going for a while, rest.
      Here the table, showing the number of sprints. It correlates with my heart rate raising 🙂
      Then the pace. If we exclude the weird values around the beginning, again it correlates with my 5 sprints.
      And to finish the laps. You can recognize warm-up, cool-down, the sprints and the resting periods easily I guess.
      Overall I like the feature, and use it whenever I want to have a Fartlek like session.
      Blog: isazi's home
      1 Reply Last reply Reply Quote 3
      • isaziI Offline
        isazi Moderator
        This post was mainly made for @Frixos-Demetriades but anyone can share their experience with said feature 🙂
        Blog: isazi's home
        Frixos DemetriadesF 1 Reply Last reply Reply Quote 2
        • BulkanB Offline
          Bulkan Moderator
          I love the idea @isazi I will share my firsts 30/30 this week and try it by sprints. I use intervals normally.
          Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
          • Frixos DemetriadesF Offline
            Frixos Demetriades @isazi
            @isazi great thanks. So as I can see, sprints is mainly used for Fartlek training.
            Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
              Dimitrios Kanellopoulos Community Manager @Frixos Demetriades
              @Frixos-Demetriades or bootcamps or something else… It is basically a helper for marking fast sections in “realtime” rather than post processing.
              Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
              • J Offline
                jw cou Silver Members
                and about the offset for a sprint / manual lap to start and stop, I made a quick comparison between the results of S+ and what I would (arguably) consider as the ‘perfect’ start and stop of sprints from the pace graph, post workout.
                That does make sense but a “slow stop” of a sprint makes it harder to detect by S+, that’s where I noticed gaps of more than 5 seconds.
                • Richard ThygesenR Offline
                  Richard Thygesen
                  I really like this function, its great when running with friends that have the possibillity to create more advanced intervalls. However, when doing intervalls alone I miss the function to create more advanced structured intervalls on Suunto 9.
                  S9
                  S9 Peak
                  Race
                  J 1 Reply Last reply Reply Quote 3
                  • J Offline
                    jsuarez Bronze Member @Richard Thygesen
                    @Richard-Thygesen I share your view, but least you have this feature on the S9. Spartans don’t have this and Suunto won’t bring non-simple interval training to our watches. At least in the short/medium term.
                    • ? Offline
                      A Former User
                      What’s the utility of this feature? All you’ve done is run random distances at random paces. The lap button provides the same utility, and you can actually control when it stops counting the sprint.
                      isaziI Brad_OlwinB 2 Replies Last reply Reply Quote 1
                      • isaziI Offline
                        isazi Moderator @Guest
                        @zrumlow you can also just count time in your head, why do you need a watch?
                        Blog: isazi's home
                        • BulkanB Offline
                          Bulkan Moderator
                          While I was doing today the interval I have an screen with data of the current interval (not lap) but it wasn’t showing the data of the sprint while the sprint was working perfectly.
                          I will test it tomorrow, but looks like the screen with any data of interval is not showing if you are doing sprints. Or am I wrong?
                          J isaziI 2 Replies Last reply Reply Quote 0
                          • J Offline
                            jw cou Silver Members @Bulkan
                            @Bulkan That’s correct I think. The ‘interval screens’, i.e. the one activated when you use the interval mode are not used/activated by the S+ sprint mode, which uses the manual laps screens if any and the additional S+ srceen
                            • isaziI Offline
                              isazi Moderator @Bulkan
                              @Bulkan I don’t think this function trigger the same as intervals, well it triggers laps like the interval function does, but it does not use the interval fields in the watch.
                              Blog: isazi's home
                              BulkanB 1 Reply Last reply Reply Quote 2
                              • BulkanB Offline
                                Bulkan Moderator @isazi
                                @isazi @jw-cou that’s right, it what happened to me this morning, I set a screen for intervals and discovered it doesn’t trigger the fields of intervals.
                                Thanks!
                                Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                                  Dimitrios Kanellopoulos Community Manager @Bulkan
                                  @Bulkan however if you use the normal lap fields those will be updated
                                  • BulkanB Offline
                                    Bulkan Moderator @Dimitrios Kanellopoulos
                                    @Dimitrios-Kanellopoulos even if I have auto lap ON?
                                    • ? Offline
                                      A Former User @isazi
                                      @isazi great insight
                                      isaziI 1 Reply Last reply Reply Quote 0
                                      • Brad_OlwinB Offline
                                        Brad_Olwin Moderator @Bulkan
                                        @Bulkan Yes but auto lap will mark laps similar to SuutoPlus laps and IMHO confusing. I always turn auto lap off when using SuuntoPlus Sprint/Loop/Climb
                                        Vector/T6c/Vertical 2 Ti
                                          Brad_Olwin Moderator @Guest
                                          @zrumlow said in Suunto Plus sprints:
                                          The utility is that I do not have to push my lap button every time I start/stop an interval. All I do is the workout and laps are automatically recorded on the watch. Sometimes I forget to hit the lap button, I find it quite useful not to worry about the lap button and just do my workout.
                                          For flat workouts the Pace selection works well but I find for hill intervals the best tool is my Stryd and a power-based selection for SuuntoPlus
                                          Here is an example,: Workout from my coach: Vo2 Pick-ups at 10k to 5k pace. After warming up 1mile Z2. Then build pace for 1 min pick-up, rest 2 min. Then pick-up 2 min, rest 2 min. Then pickup 3 min, rest 2 min. Then pickup for 4 min, rest 2min. Then pick-up for 5 min, rest 2 min. Work at 10k pace. Keep your feet moving on rest interval, allow HR to drop into Z2. Then reverse 5,4,3,2,1 w/ 2min rest. Work at 5k pace.
                                          ? 1 Reply Last reply Reply Quote 3
                                          • isaziI Offline
                                            I’m glad you can be enlightened.
                                            Blog: isazi's home
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
