    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Poor performance heart beat monitor Suunto 5
    Scheduled Pinned Locked Moved Suunto 5
    8 Posts 6 Posters 801 Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • NL-PaulN Offline
      NL-Paul
      Hi there, I bought a Suunto 5 with a build in heart monitor (with the latest update), a couple of weeks ago. This heartbeat monitor is very unreliable!. My previous watch was the Ambit 3 with a separate heartbeat monitor. When I compare both watches on the same MTB track I have an average heartbeat rate of approx 145 for the Ambit and 75 on the Suunto 5!?. I followed the advise from Suunto and tried serval other things (not too tight, higher up the wrist, the other arm etc) without succes. And occasionally it seems to work.
      Does any one have the same experience?
      • isaziI Offline
        isazi Moderator
        Wrist optical HR on mountain bike is very hard to get right, and the sensor on the 5 is years old, so not sure you can get good results with it. Not what you want to hear probably.
        Blog: isazi's home
        • EgikaE Offline
          Egika Platinum Member @NL-Paul
          @NL-Paul wrist heart rate is a constant challenge.
          Especially during biking where you firmly grab the handle bar and get shaken all the time.
          Also skin color and probably hair has an influence.
          Best solution: get yourself an external chest strap HR sensor again which you can easily connect to your S5 👍
          t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
          1 Reply Last reply Reply Quote 3
          • Saketo NemoS Offline
            Saketo Nemo Moderator
            Ovviously the ambit 3 heart belt is compatible with your suunto 5, so you can use that, if you still have it.
            As mentioned, handlebar vibrations are the worst to counteract, even worse than running in my experience.
            • Stefan KerstingS Offline
              Stefan Kersting Platinum Member
              If you want exact HR measurement you have to use HR belt and not the wrist. There is up to 20% difference between wrist HR and belt HR
              Instagram: https://www.instagram.com/helgelandsbukken/
              https://www.instagram.com/suunto_adventures/
              IG: Helgelandsbukken, suunto_adventures
              Vimeo: vimeo.com/helgelandsbukken
              Blogg: https://turblogg.midnattsola.com
              • NL-PaulN Offline
                NL-Paul
                Many thx. The reason I bought the 5 was the broken heart rate monitor on the Ambit. I’ll have to search for HR Belt. Thanks again.
                isaziI 1 Reply Last reply Reply Quote 0
                • isaziI Offline
                  isazi Moderator @NL-Paul
                  @NL-Paul I use the optical HR of my S9for hiking and mountaineering, so I’m sure you can use the one on the S5 for many activities.
                  Blog: isazi's home
                  • Ɓukasz SzmigielƁ Offline
                    Ɓukasz Szmigiel
                    I used to run with OHR and it was really ok for regular flat runs. The OHR struggled to get a good reading when going downhill fast when there were lots of erratic hand movement in difficult trail runs.
                    So I went with H10 and I’m happy. For regular runs I don’t see that much of a difference (well, maybe first 10 minutes are sometimes weird with OHR) but when doing trails HR belt is pretty awesome. The reaction time with HR belt is amazing compared to OHR.
                    However, for hiking and regular walks OHR in S5 works well. I very seldomly get weird readings for no more than fifteen seconds.
                    S9PP 2.50.28
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
