    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS/GLONASS sgee update
    Scheduled Pinned Locked Moved Ambit
    50 Posts 11 Posters 9.2k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User @SnusR
      @snusr maybe this was a quick fix and it didn’t have to be released on beta channel. This is not uncommon in IT world.
      Pretty sure next beta will include all the fixes from current public. 🙂
      • ? Offline
        A Former User
        Sadly back to this topic again.
        Today I had no GPS fix on my run! I don’t wear my watch all day, just for my runs, and apparently when I opened Suunto app about one hour before my run the GPS data got synced. Even if about one hour was passed and all this time the watch was on my wrist, so no sleep mode activated, when I started the activity tracking, GPS had hard time to get a fix. After waiting almost 10 minutes for a fix, I decided to start anyway and leaving the GPS to search for fix during activity. My run was done and guess what? GPS fix wasn’t acquired and no GPS data was recorded. The recorded distance was way off, I didn’t expected magic from the accelerometer, but almost 1 km difference… it’s crazy on a 8.3 km route. Basically today I run with just a stopwatch. 🤣
        I don’t know if bad GPS sgee data or data corruption during sync or the watch didn’t had enough time to “install” GPS sgee data, but in the end I don’t even care, it’s just sad! I can’t understand why we can’t have an option in Suunto app for us to decide when GPS optimization should take place?
        Tracking my runs is starting to be a joke, sometimes heart rate data is trash, other times GPS track is wonky and now no GPS at all.
        This is not how I imagined the digital transition. 😒
        Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
          Dimitrios Kanellopoulos Community Manager @Guest
          @andrasveres so why didn’t you check if you have agps?
          I see you also have an ambit. That syncs fine agps.
          The no fix ain’t a problem with the agps. The watch should get gps fix without agps as well especially the ambit.
          Nor should it have bad tracks.
          I would contact support maybe it’s hw
          Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
          • ? Offline
            A Former User @Dimitrios Kanellopoulos
            @dimitrios-kanellopoulos I’ve checked and it had refreshed data and the watch had almost an hour to process it. I’m not saying that the sync doesn’t work, I’m just suspecting occasionally something goes wrong.
            Yeah, I know it should get GPS fix without sgee data, but believe me, it didn’t and it was just as clear and sunny as today (and now gets fix in seconds with the same sgee data). It would be great if I had an option to do manual GPS data sync when I consider being a right time (I can use my Ambit with 2-3 days old sgee data just fine), without being forced to turn off auto-sync and do manual sync after each run.
            Now if I pick up my watch for a run and Suunto app out of nowhere sync the data, mostly GPS fix issue is what I end up with. Maybe it is not related as you say, but this is what I noticed occasionally and thankfully not regularly. Usually as I noticed I get bad track (offsets or corner cuts or insane jumps) when it struggles with GPS fix at start.
            Will check a couple of days from now on and if it will happen more frequently I will contact support.
            PS: sorry for getting my rage out here, but after some hard days these kind of issues are getting frustrating. ☮
            Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
              @andrasveres it’s ok. But just to pinpoint the issue. If agps /sgee is transfered it cannot be an app problem.
              • ? Offline
                @dimitrios-kanellopoulos yep, it’s complicated. I don’t know how sync is implemented, but if in some circumstance corrupt data is transferred… or sync is done right before activity start and the watch doesn’t have enough time to process it… it’s not an app issue, but it’s an issue for the user.
                Another thing I noticed long ago is that when Suunto app is syncing the watch doesn’t show “M sync” as does with SuuntoLink and as I remember it did with Movescount app. I notice that a sync is ongoing because the watch is reacting with lag to button push.
                Anyway, I disabled the auto-sync again. It’s an inconvenience I can live with. 🙂
                PS: even an app notification would be fine for me, just to know GPS optimization was done, so I’m aware about it before my next run. 😉
                  @andrasveres if you have an updated sgee timestamp then the file is ok (in theory).
                  It means that the watch managed to decrypt the file and extract the date.
                  Now wether the data that sirstar sends are fine that is where it gets complicated
                  • ? Offline
                    @dimitrios-kanellopoulos said in GPS/GLONASS sgee update:
                    Thank you for this piece of information. 🙇
                    Yep, and I suppose there is no server side validation for this data on Suunto side?! Another question, if I may, regarding this: do you know (or can ask) this data (in particular for Ambits) contains satellite data for country, region, hemisphere or whole globe data?
                      @andrasveres
                      There is no need for validation as the data are in their own format.
                      It contains info for all regions
                      • ? Offline
                        Thanks, that rules out the case when phone would transfer invalid region data. Now I’m really clueless why this issue pops up from time to time.
                        Register Login
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
