    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Wear OS 2.39
    Scheduled Pinned Locked Moved Suunto 7
    71 Posts 16 Posters 13.2k Views 17 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Jamie BGJ Offline
      Jamie BG Bronze Member @Zab_55
      @Zab_55 Your watch has 3 main versions of software:
      Updated by manufacturer:
      Firmware - should be on H MR2 (google supplies to manufacturers who incorporate it and roll it out - this will include the suunto app on the watch - this is the one you can update via the settings. Its the base underlying structure of wear os.
      Updated by Google via the Google Play store on your watch:
      Wear OS - should be 2.19 - from what I can make out this is the flesh and muscles to the bone structure of the H MR2, and can be considered your operating system. Most users, especially those on 0.5GB of ram have noticed some performance and battery improvement off this update (note this is with most of them running firmware of H MR1 or older - only Suunto has the H MR2 update at this time.
      Wear OS home - should be 2.39 - this is your home launcher - the skin over the wear os experience and seems to be what may include the built in apps - but not certain. I do know that when we get 2.40 (no idea when) it will give us more tiles (looking forward to that) and I suspect the new weather app.
      Suunto of course isn’t responsible for this, however of course the rest of us on this forum or on reddit would be happy to assist you in trying to resolve any issues you may have with wear os.
      Disconnects are generally phone and or app related. Make sure that all of your wear os apps are on latest version (see above for watch - firmware doesn’t matter). Not sure what your phone should be as only know for android.
      I dont know if apple has this functionality - but make sure it isn’t restricting the wear os app on your phone in any regard - if the iOS system is closing down the app when not in use it will disconnect from your watch.
      If all your apps are up to date, a roll back may help for watch and or phone. (I know that iOS recently updated, so may be a case of wear os hasn’t yet caught up with that update, in which case only fix may be iOS rollback). Alternatively try restarting the watch - as sometimes it can help fix glitches like this, and or try restarting your phone (Had it happen once a couple of months ago with regular disconnects - it was something glitching on the phone - restarted phone and no more issues).
      1 Reply Last reply Reply Quote 3
      • Zab_55Z Offline
        Zab_55
        Thank you very much for your answer. It seems to be hit and miss with finding out what exactly is the issue. That iPhone update is a good point though.
        We will see what 2.40 brings, but as I mentioned before, the older version was just fine and I didn’t have issues ( at the time when I bought S7).
        My Suunto firmware is up to date, and ofc I don’t blame Suunto for this, not at all. I understand that this is probably Google’s fault and their lack of updates for WearOS ( hopefully they’ll change this soon)
        Thanks again !
        Jamie BGJ 1 Reply Last reply Reply Quote 1
        • Jamie BGJ Offline
          @Zab_55 - you can go back into the google play store and roll back the update, but not sure how much that will help as might roll it all the way back to the base (not that you have anything to lose).
          You might also want to consider setting your play store to manual update from autoupdate so that:
          1. you know when an update is available and can decide whether to install it or not (by seeing feedback etc).
          2. Saves battery life. Can sometimes try to update at very bad times, and as it can activate wifi, though most of the time it just does it through your bluetooth connection, making it a slow process (the 4100 chip shows it muscle on this task), it keeps your watch awake for longer and causes battery drain.
          I have mine on manual update, and every couple of days once I have it on the charger, I check the play store and then trigger any updates - so at least it uses wifi so quicker; and as charging no impact to battery life.
          Zab_55Z 1 Reply Last reply Reply Quote 1
          • Zab_55Z Offline
            Zab_55 @Jamie BG
            @Jamie-BG yes mate, that’s what I did, so actually testing it out. Hopefully it helps and as well setting the play store to manual updates might be the good point. Thanks !
            • pilleusP Offline
              pilleus
              WearOS version 2.21 on my Mobvoi watch, on my S7 2.19.
              New information about an update? 🤔
              https://www.instagram.com/moves.are.life/
              Suunto Vertical Black Lime
              Suunto 9 Peak Pro Black
              Suunto Spartan Ultra Stealth Titanium
              • M Offline
                Mi_chael Bronze Member
                2.39 for me waiting for 2.40 with the new météo widget and no tile limit.
                pilleusP 1 Reply Last reply Reply Quote 1
                • pilleusP Offline
                  pilleus @Mi_chael
                  @Mi_chael this is WearOS home app. 2.39 on the S7. Correct.
                  I speak about this version:
                  • M Offline
                    Where see that ?
                    pilleusP 1 Reply Last reply Reply Quote 0
                    • pilleusP Offline
                      pilleus @Mi_chael
                      @Mi_chael said in Wear OS 2.39:
                      Where see that ?
                      Settings - system - info - versions
                      • M Offline
                        I see 2.21
                        • iTomBI Offline
                          iTomB
                          2.19 on my S7
                          Handbiker
                          Spinal cord injury T7 - 16.09.2019
                          • D Offline
                            DavorP
                            2.19 on my Mobvoi watch (Ticwatch Pro 2020).
                            • pilleusP Offline
                              pilleus
                              Somebody an explanation why there are different versions on the same watches? 😲
                              J Jamie BGJ 2 Replies Last reply Reply Quote 0
                              • J Offline
                                johann.fuehrer Bronze Member @pilleus
                                @pilleus said in Wear OS 2.39:
                                Staged rollout in different countries/ IP network ranges…
                                But also other algorithms are possible. They like to balance network traffic to their servers to prevent peak load. Nearly everyone does this today if a larger number of devices are affected.
                                • M Offline
                                  mjposner
                                  My watch lost its custom face this a.m., thought it was an update but still on 2.39 here in the USA.
                                  • Jamie BGJ Offline
                                    Jamie BG Bronze Member @pilleus
                                    @pilleus Other than the H MR2 (firmware version) the wear os and wear os home app updates are pushed through by google via the play store and don’t have anything to do with suunto.
                                    Check and make sure no update in your play store, especially if set manual updates (best option as doesn’t cause battery drain due to store trying to update at inopportune moments.
                                    pilleusP 1 Reply Last reply Reply Quote 2
                                    • pilleusP Offline
                                      pilleus @Jamie BG
                                      @Jamie-BG I installed the latest updates from Google (WearOS and Fit) via ADB, because on my S7 there were no updates available in the PlayStore.
                                      The new tiles (weather and Fit) and the possibility to add more than 5 tiles are not included in the updates. It’s a feature Google has to change server side.
                                      On the Ticwatch Pro 3 GPS all the new tiles and the possibility to use more than 5 are working. Despite of the old WearOS version. H MR2 is not yet installed on the TWP 3.
                                      It’s strange. 😲
                                      Jamie BGJ 1 Reply Last reply Reply Quote 0
                                      • Jamie BGJ Offline
                                        @pilleus Strange - as none of the guys I chat with on Reddit that have the TWP3 have mentioned anything about having the additional tiles.
                                        • M Offline
                                          I want more tile and new weather widget…😥
                                          • pilleusP Offline
                                            pilleus
                                            Now my S7 has updated the WearOS version. But no option to add more than 5 tiles.
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
