    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Always on display and swimming
    Scheduled Pinned Locked Moved Suunto 7
    15 Posts 5 Posters 1.7k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • herlasH Offline
      herlas Silver Members
      Hi there,
      Anyone else seeing issues while pool swimming with Suunto 7 and the new always on display that randomly the Suunto app on the watch moves out and you’re on another screen? Then have to press the Suunto app button to go back? This wasn’t happening with the previous version I think 🤔
      thanks
      SRS Ti
      SRun (primarily road runner so testing SRun is a must ;))
      Jamie BGJ 1 Reply Last reply Reply Quote 0
      • Jamie BGJ Offline
        Jamie BG Bronze Member @herlas
        @herlas - shouldn’t be happening, as per the details provided the touchscreen is supposed to be disabled when using a swimming tracking actiivty.
        is it moving to another screen in the suunto app, or is it going back to the home screen. If it is back to home screen it sounds like your quick settings bar is being pulled down, or your home/menu button is being pressed.
        • herlasH Offline
          It goes to another app, it’s weird haven’t done any differently and this has happened more than once, if it happens again will note more details.
          Thanks
          SRS Ti
          • herlasH Offline
            As additional info, we’re doing manual laps pressing the lap button, which is also mapped to the app it goes to 🤔
            Hasn’t occurred again though
            SRS Ti
            • Jamie BGJ Offline
              @herlas - why are you doing manual laps? If using the suunto app with the swimming pool tracking option it should automatically record the laps you swim…
              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                Dimitrios Kanellopoulos Community Manager @Jamie BG
                @Jamie-BG correct
                Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                • herlasH Offline
                  I guess cause there’s no drilling mode and when you’re training they won’t get captured e.g. drills, kicking etc so I use manual laps to keep an idea on that.
                  Thanks
                  SRS Ti
                  Jamie BGJ 1 Reply Last reply Reply Quote 1
                  • Jamie BGJ Offline
                    @herlas have you looked at the swim app on the play store. Been a while since I last used it and know it has been updated. May have some solutions for you. If no auto link to suunto app you could probably use SyncMyTracks or similar to pull into suunto app.
                    • herlasH Offline
                      Can you share link? I haven’t tried anything out of the built in Suunto app, heard it’s the one we should use, concerned with external apps as Suunto 7 battery lifetime is already a challenge, don’t want to eat more 🔋 than currently eating 🙂
                      SRS Ti
                      • Jamie BGJ Offline
                        @herlas App: https://play.google.com/store/apps/details?id=com.spiraledge.swimapp&hl=en
                        I used to use in on my Ticwatch S2 as google fit didn’t have swim tracking. Can’t remember all the features and exactly what it contained, as so far have only been able to do some open water swimming and I used the Suunto app for that (prior to latest September update).
                        It may use more battery, you will have to check and find out. Unless you are swimming or over 3 hours you will probably have enough battery to last the day.
                        Am surprised you think the S7 battery life is a challenge. I would think that it would easily track a swim session and have enough to make it through to that evening or the next day. Are you remember to put your watch in flight mode only prior to going in the pool (if not that could be part of your battery issue).
                        • herlasH Offline
                          Well, I also track other sports, so that’s why I sometimes don’t make it through a single charge.
                          Thanks for sharing the app.
                          Back on the original issue, if it’s confirmed lap button (lower right) randomly goes to open the app that is user mapped for that button, sounds like we need to look for a bug where somehow alter latest update started happening, my first guess is when using AOD, still to be confirmed tho
                          SRS Ti
                          • Jamie BGJ Offline
                            @herlas - weird, as when I am in the suunto app, the lap button only seems to work for that app i.e. add a manual lap time, with a long press opening the suunto app settings (where the right buttons then become up and down buttons).
                            • masi0M Offline
                              masi0
                              So how do you all handle swimming with Suunto App then? Does the screen powers off while swimming or there is an option to disable touch screen while swimming?
                              • Jamie BGJ Offline
                                Jamie BG Bronze Member @masi0
                                @masi0 not sure as haven’t had a chance to swim yet since sept update. Based on info suunto provided touch screen is supposed to be locked when you are in swim mode and on data screen, so suspect the three right buttons, top to start, pause, centre to lock change screen, bottom to set manual lap, end session, long press to get to options, then top and bottom to scroll in options menu and middle to select. Works like that for rest of activities.
                                EgikaE 1 Reply Last reply Reply Quote 2
                                • EgikaE Offline
                                  Egika Platinum Member @Jamie BG
                                  @Jamie-BG said in Always on display and swimming:
                                  This
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
