    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 Altitude 100m off
    Scheduled Pinned Locked Moved Suunto 7
    7 Posts 3 Posters 876 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • W Offline
      who93
      Hi,
      With the latest update (September 2020), the altitude is wrong on my watch.
      I did a tour to a mountain (1433m) and before the update, the altitude was correct.
      However, after the update I did the same tour (start - top - end are the same, but a different route) and here the altitude is at 1334m.
      I also checked in the city, my phone GPS says 400m altitude, my Suunto shows 293m. The 400m is more likely to be accurate.
      Is there a way to calibrate the altitude sensor?
      BR
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
        Dimitrios Kanellopoulos Community Manager @who93
        @who93 do you have some location data ? Where is that point that had issue? Suunto uses MSL FYI
        Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
        • W Offline
          who93
          @Dimitrios-Kanellopoulos said in Suunto 7 Altitude 100m off:
          The peak was Schöckl.
          Since it was the same peak on both routes, the altitude should be roughly the same in both pictures. Also note, the start of the route was on both days the parking lot of the cable car - at the cable car station there is a mark with an altitude of 800m - my Suunto showed me (last picture) below 700m. So already the starting point is wrong.
          In my office, Google maps show me an altitude of 360m, an app on my phone using GPS shows me 390m but my Suunto watch gives me 290m. So again ~100m offset
            hmmmmm indeed I see better now. Did you use maybe fusedtrack / non best GPS ?
            • W Offline
              who93
              Thanks for the reply, I checked, the setting in the Suunto app is already at “Best”. There is no way to calibrate the altimeter? Is the altitude estimated using GPS? I downloaded the app
              Altimeter for Wear OS on my watch and there the correct altitude is shown (I guess this app uses GPS information).
              I noticed that this Altimeter app for WearOS first also samples 299m but then, after a second or two, it shows the correct altitude of 360m.
                That 299 should be the barometric altitude.
                Suunto checks GPS and corrects that eventually.
                Try this please.
                • Find an open space and leave the watch outside while recording. Leave the altitude screen as you have in the picture on. It should in about 15mins max change to 360.
                Tell me the results
                • markytarkyM Offline
                  markytarky Silver Members
                  This happened to me too, but with S9baro. The altitude was off about 80-100m. The ascent and descent was precise though. I used the “endurance” battery setup. Could be that the case? Thanks.
                  Instagram
                  Watch: S9B customized, S9P all black
                  Suunto App: iOS beta
                  Register Login
                  • First post
                    Last post
                  Suunto Terms | Privacy Policy
