    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery dying after a day
    Scheduled Pinned Locked Moved Suunto 5
    4 Posts 3 Posters 497 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • A Offline
      aidmax
      Hi community,
      I bought Suunto 5 about a half a year ago. Lastly, the battery won’t run longer than a day. Tried soft reset, but no luck.
      • isaziI Offline
        isazi Moderator
        You can also try a hard reset, but if it’s the battery better you contact support.
        Blog: isazi's home
        • Brad_OlwinB Online
          Brad_Olwin Moderator @aidmax
          @aidmax That should not be happening. Mine lasts much longer. As @isazi said a hard reset might work. Otherwise, it may be the indicator is not calibrated. Let the watch drain completely until it dies (GPS on will speed that up). Then fully charge, overnight preferably. This should recalibrate the battery indicator.
          Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing/Race2Ti
          1 Reply Last reply Reply Quote 3
          • A Offline
            aidmax
            Thank you for the replies. Seems, I’ve exaggerated a bit. The battery lasts about 2-3 days at least, the case when it was working only a day seems to be a glitch. Nevertheless, I will keep an eye on that and try what you suggested if things went worse.
            • First post
              Last post
            Suunto Terms | Privacy Policy
