    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 - Heart rate
    Scheduled Pinned Locked Moved Suunto 7
    17 Posts 7 Posters 1.9k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      How are heart rate readings for you? I am having 20-30 lower heart rate on average with Suunto 7 compared to my previous measurements with Polar HR chest strap - for strength training. Today I got the normal readings for the first time, but for indoor cycling.
      I tighten it a bit more for exercise compared to normal use.
      • isaziI Offline
        isazi Moderator
        Strength training holding something, like weights?
        Blog: isazi's home
        • ? Offline
          A Former User @isazi
          @isazi Yes, for the most part.
          isaziI 1 Reply Last reply Reply Quote 0
          • Brad_OlwinB Online
            Brad_Olwin Moderator @Guest
            @Metalmi For weightlifting this could be an issue due to wrist movements. For most everything else it works very well and matches my belt readings nearly exactly.
            Vector/T6c/Vertical 2 Ti
            ? kriparK 2 Replies Last reply Reply Quote 0
            • ? Offline
              A Former User @Brad_Olwin
              @Brad_Olwin I wouldn’t say that wrist movement is that big to justify it (I would understand it during some Tabata or circular training with lots of quick movements). It’s incorrect by a lot, even during breaks I mostly get reading like 80-90 (while it should be 120-130). I would expect it to be at least a bit more precise.
                @Metalmi Here is a run with the S7 on one arm and S9 with smart sensor belt on the other arm. You can judge for yourself. Tempo Intervals this morning.
                ? MarynM 2 Replies Last reply Reply Quote 1
                • ? Offline
                  @Brad_Olwin I see, thanks! Do you maybe have any suggestions to improve the readings during weightlifting and other potentially problematic exercises?
                    @Metalmi No, I do a lot of Pilates and some plyometrics and have not had any issues, agrees with my belt when I use it.
                    • isaziI Offline
                      isazi Moderator @Guest
                      @Metalmi wrist heart rate measurements are not great in general when holding something tight.
                      Blog: isazi's home
                      • MarynM Offline
                        Maryn Silver Members @Brad_Olwin
                        @Brad_Olwin nice
                        What is your opinion for S7 OHR if the outside temperature is around 0-10 degrees?
                        Suunto Vertical, Suunto Race, Edge 530, Vantage V, Suunto Wings, Polar H10&Verity Sense
                          Brad_Olwin Moderator @Maryn
                          @Maryn said in Suunto 7 - Heart rate:
                          @Brad_Olwin nice
                          I’ve done a lot of cold runs last winter and ski mountaineering with the S7, the OHR can be a little less precise but overall great. I would not wear a belt. Obviously, I had to wear the watch against my skin where sometimes I cannot see it.
                          MarynM 1 Reply Last reply Reply Quote 1
                          • MarynM Offline
                            @Brad_Olwin thanks!
                            • kriparK Offline
                              kripar @Brad_Olwin
                              @brad_olwin I have a different problems while weight lifting. A common occurrence is that the heart rate goes DOWN on my suunto when in reality it’s actually going up. So I get the opposite of a peak. Seems like a software issue where the extra beats on a quickened heart rate are interpreted as noise.
                              N 1 Reply Last reply Reply Quote 0
                              • Marco GM Offline
                                Marco G
                                I use the watch a few times a week in the gym and it looks good, I can’t make a comparison with a proper belt but the readings always made sense to me. Altho I noticed a few things:
                                • in order to get good reading while gripping heavy stuff the watch needs to be really nice and tight and kept approx 5cm away from the wrist ( bit of a weir position, as mentioned in the instruction)
                                • the HR reading on the wrist can be delayed in time according to the exercise. For example, If I train the arms or upper body, the reading is basically instantaneous, if do a heavy deadlift or legs, the peak comes a bit later the end of the reps when I feel that the hr is actually going down, not up. I probably has something to do with what muscles activation and the positioning of the reading.
                                ? 1 Reply Last reply Reply Quote 1
                                • ? Offline
                                  A Former User @Marco G
                                  @marco-g said in Suunto 7 - Heart rate:
                                  How do you keep it there? As soon as I start sweating, it goes down to the wrist
                                  Marco GM 1 Reply Last reply Reply Quote 0
                                  • Marco GM Offline
                                    Marco G @Guest
                                    @metalmi
                                    I personally don’t sweat much and it stays in position, but yes it does slide sometimes. A good trade-off for me is to keep the strap edge at 2 cm from the middle of the bone bump in the wrist.
                                    You can also do a position-check by doing a full wrist movement from down to up. If you don’t move/lift the strap and/or touch the middle button you’re good to go. If you do one of the two the position isn’t good.
                                    This is how I usually do it.
                                    • N Offline
                                      Nshkira @kripar
                                      @kripar
                                      Same situation occurs with swimming. Swimming with breast stroke gives a stable and accurate HR. Crawl and butterfly stroke makes the HR go down, so usually at the end of 100m crawl screen shows me 70 pulse instead of 150-160. And only after a minute or so HR starts to go up.
                                      I prefer to swim with breast stroke now to control ny HR zones))
                                      Register Login
                                      • First post
                                        Last post
                                      Suunto Terms | Privacy Policy
