    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Import GPX to SA with waypoints
    Scheduled Pinned Locked Moved Suunto app and other software services
    35 Posts 11 Posters 6.6k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
      Dimitrios Kanellopoulos Community Manager @Fenr1r
      @Fenr1r I dont understand why it’s so hard in the GPX world for companies / services to keep it consistent and “compatible”. I bet they have their reasons but I would be interested to know why.
      Not that I know well, but it’s remarkable this variance.
      Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
      Fenr1rF 1 Reply Last reply Reply Quote 1
      • kabziorK Offline
        kabzior Bronze Member @Fenr1r
        @Fenr1r said in Import GPX to SA with waypoints:
        Another problem with the site is that only uses snap-to-road/-track. Great for the “the smallest forest paths”, useless for trackless areas.
        That is true, but this is where SA comes into play, their free-drawing is one of the best I have seen, easily beats komoot. And they use mapbox which is way better IMO than OSM (yes, I know mapbox is based on OSM), not as good as mapy.cz but still one of the best so far (not to mention Connect app with their google maps, that’s a joke). Mapy.cz with free- drawing like in SA would be ideal 😉
        TBH I do not know the first thing about gpx and that technology, what really confuses me is why I can not upload gpx from mapy.cz to SA via QS, while it works just fine when I upload the very same gpx directly in SA.
        • Fenr1rF Offline
          Fenr1r @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos said in Import GPX to SA with waypoints:
          Yeah. Me too. So many conjectures.
          In the meantime, perhaps the GPX file’s versatility is also it’s curse: it can sorta be made to work even when it shouldn’t. It might be that, following the manufacturers’ proprietary format domination, things went a little bit too wild west.
          • M Offline
            margusl
            @kabzior said in Import GPX to SA with waypoints:
            None of the services allows you to import routes with WP, whether directly or via QS
            from https://apizone.suunto.com/route-description :
            Waypoints are generated from:
            • wpt -elements that have same coordinates some rtept or trkpt -element.
            • rtept and trkpt -elements that have name and/or type.
            That “same coordinates” part is crucial here and that’s the reason why Suunto does not pick up waypoints from most gpx files. While there are probably few other sources for such GPX-es, I personally know only 2, and one of those is Suunto’s own Movescount.
            The other is https://www.plotaroute.com/ . For a quick workaround you could load your GPX to Ploataroute and download it again, this creates GPX with wpt elements that are compatible with SA.
            kabziorK 1 Reply Last reply Reply Quote 6
            • kabziorK Offline
              kabzior Bronze Member @margusl
              @margusl said in Import GPX to SA with waypoints:
              That is a valuable info, thanks for that.
              So, here are my observations after playing with it for a little while:
              1. I found how to plot a route with WP (max 5 in free version), but did not find how to name/edit those points or any list of them. I must be blind 🙂
              2. One can export gpx in various forms: route and track, with WP as POI or Directions.
              3. I found that exporting as “route” does not work, neither with POI nor with Directions, both SA and QS are saying that file format is not recognized.
              4. When exporting as “track”:
                a. with POI - WP are not imported neither with SA nor via QS
                b. with Directions - WP are not imported with direct SA upload
                c. with Directions - WP are imported when uploading via QS, but they are not editable in SA (and since I do not know how to edit them in website they are all just flags with description like “turn right”)
              Definitely I must dig into that site since it has a huge potential 🙂
              Before I figure it out I am sticking to mapy.cz / SA combo 🙂
              M 1 Reply Last reply Reply Quote 0
              • M Offline
                margusl @kabzior
                @kabzior , you skipped all the tooltips in Plotaroute, didn’t you? 🙂
                1 - look for “Directions”
                2 - routes work just fine, as long as you use those with devices that can actually do routing. This is for cycling computers, handhelds and other turn-by-turn capable nav systems. Not for Suuntos.
                4 - take a moment to read tooltips of those buttons. POIs are generated only from directions that you have labeled or added a symbol to.
                Besides, what I suggested was just loading an existing GPX with existing Waypoints/POIs to Plotaroute and then download it from there as track with POIs, should even work without creating an account. The track you get back is already altered and “fixed” for use with SA.
                kabziorK 1 Reply Last reply Reply Quote 0
                • kabziorK Offline
                  No… not all of them 😄
                  But seriously, either I’m technologically disabled or using this site is more difficult than average. This is my route, and after importing into SA I get non-editable A-> B without any WP.
                  text alternatywny
                  • M Offline
                    margusl
                    This is how import through quantified-self.io works. When importing directly through mobile app you might have different result - in-app route import should work offline and thus might be implemented differently than described in SA route API doc.
                    kabziorK 1 Reply Last reply Reply Quote 1
                    • kabziorK Offline
                      Well thank you very much Sir, this does indeed work.
                      As you mentioned, when imported directly to SA no WP, but import via QS provides WP (only downside is they are all just “flags” no matter which icon I chose, I guess it is incompatibility of icons between systems, easily solved once SA will let edit routes imported via QS).
                      @Dimitrios-Kanellopoulos - if I may suggest small change in QS: in Services -> GPX Upload it says:
                      You can upload a GPX file to your Suunto app info
                      NOTE: Route sync needs Suunto app Android 4.20 and higher. For iOS there is no Suunto app version that supports this
                      Currently uploading gpx to the iOS application (regular one from AppStore, not beta) via QS works without any problems with any given gpx file from route planning websites, and with one from plotaroute.com even with POIs.
                      • M Offline
                        margusl @kabzior
                        Plotaroute stores symbols in <sym> element ( like <sym>Summit</sym>), but SA route API only supports <type> for defining icons ( like <type>Peak</type>). Depends on how much effort you want to put into this, but you could just add <type> elements manually to GPX with any text editor, all waypoints are at the beginning of the file, at least for Plotaroute exports. Or use find/replace or some scripting to replace “<sym>Summit</sym>” with “<type>Peak</type>” List of supported waypoint types can be found from the same SA route API doc.
                        Or you could use movescount.com for changing waypoint types. Either build your route in Movescount or just import Plotaroute files to change waypoint types. You can export the result as GPX and send it towards SA through QS as before, now with fancy icons. [e: apparently not working as expected … ]
                        Here I added types manually
                        updated original Ploataroute <wpt> element
                        <wpt lat="59.375867" lon="24.615449">
                        <time>2020-08-17T00:05:13Z</time>
                        <name>LabeledToC</name>
                        <cmt>Keep left</cmt>
                        <desc>Keep left</desc>
                        <sym>Left_slight</sym>
                        </wpt>
                        to
                        <type>Sight</type>
                        </wpt
                        Brad_OlwinB kabziorK 2 Replies Last reply Reply Quote 3
                        • Brad_OlwinB Offline
                          Brad_Olwin Moderator @margusl
                          @margusl Even better, I may write an Apple Script to do this from Gaia as that is the plotting software I use most. Thanks for the info!
                          Vector/T6c/Vertical 2 Ti
                            Carlos my friend uses plotaroute and adze to fix the waypoints and add a type there.
                            Also adze is only osx I think but a really great tool
                            • sartoricS Offline
                              sartoric Moderator
                              Probably you can also use xslt to modify the source file.
                              Is it xml compatible ?
                              SVTS - 2.50.28
                              SSSWHR BARO Amber - 2.8.32
                              Samsung A5 2016 - Android 7.0
                              Suunto App Android 6.11.8 beta
                              • kabziorK Offline
                                No can do.
                                GPX import from MC gives me WP limited to lat, lon and name only.
                                This is what I get:
                                <wpt lat="49.130127" lon="22.624807">
                                      <name>Szczyt</name>
                                   </wpt>
                                From this route:
                                text alternatywny
                                But words of wisdom have been spoken:
                                I usually put 5-7 WPs into my route, it is really easier just to import “clean” gpx and add my WPs in SA.
                                • M Offline
                                  margusl @kabzior
                                  Oh… indeed. Though bit surprising, still should have taken a moment to actually check myself.
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
