    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Issue - two watches on one phone.
    Scheduled Pinned Locked Moved Digital service transition
    5 Posts 4 Posters 969 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • A Offline
      aleksander svetina
      Hello! I am turning to you for help, because Suunto does not have any e-mails available for their customers. My wife and I each have our own Suunto watches, from which we have so far downloaded workouts to Moviescount on the PC.
      Now we have decided to switch to the new Suunto app.
      Considering that only I have a Smartphon and my wife does not, I downloaded the new app and opened two profiles - one for me, the other one for my wife; then I downloaded all her workouts on her profile and all mine on my profile. I established the phone connection to her watch and then another connection to my watch, but here the problems start.
      The first problem is because only one watch can be connected at a time, so it automatically downloads only my workouts and hers not.
      The second problem: if I reconnect my phone to her watch, it uploads her workouts to my profile; what is more, it downloads the workouts for a whole past month!
      The third problem: I manually deleted all her workouts from my profile and edited everything properly. Then I reconnected my watch to the phone and it started downloading my workouts for the whole past month, although they were already loaded - so I had all workouts loaded twice.
      Again, I took my time and arranged everything manually, one by one.
      Seeing that this doesn’t work, I decided to use the app on my phone only with my watch and now it works ok.
      The problem is that now my wife cannot download workouts. Suunto claims that once you make the transition to a new application, Moviescount should no longer be used. In this application she has all her trainings from the last 10 years and it would be a shame to lose everything.
      I would be glad if you could help us solving this problem. Is there a way to slove this issue without buying another smartphone?
      Thanks.
      P 1 Reply Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator
        Please, use the search function as this problem has been already discussed and there are workarounds.
        https://forum.suunto.com/search?term=multiple watch&in=titlesposts
        Maybe your issue is that you need to logoff every time you use the app, and anyway I’m not sure multiple accounts can be handled correctly.
        I would contact suunto support asking for it.
        SVTS - 2.48.16
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Samsung A33 2022 - Android 15 - One UI 7.0
        Suunto App Android 6.6.3 beta
        Suunto App IOs 3.6.0 (20927) beta on MBP M1 Max
        • A Offline
          aleksander svetina
          Thanks, I will wait for the answer.
          • P Offline
            Peak Ambit 60 @aleksander svetina
            @aleksander-svetina Hello, we have the same and other problems with the Suunto app and are still waiting for assistance from Suunto Support. We use a tablet and have created two user accounts here. Each user has loaded his app on each user account and can use it to the extent possible. Logging out the watch from the app does not involve re-logging in after restarting, so the app must be uninstalled and then reinstalled. Very annoying. Since the user no longer logs off the app and Bluetooth is switched off, the app can be used at any time. Suunto Support, and you’re on your own
            Jamie BGJ 1 Reply Last reply Reply Quote 0
            • Jamie BGJ Offline
              Jamie BG Bronze Member @Peak Ambit 60
              @peak-ambit-60 if using Android create user profile on phone for your wife, install suunto app on both profiles with your own logins, then switch between profiles as and when you need.
              • First post
                Last post
              Suunto Terms | Privacy Policy
