    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Ambit 3 Peak : Keep Movescount or change for SUUNTO app ?
    Scheduled Pinned Locked Moved Ambit
    134 Posts 35 Posters 35.0k Views 35 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • J Offline
      Janfi @isazi
      @isazi ah you broke my heart if it’s only longer… 😭
      Suunto Ambit 3 Peak / Redmi Note 5 / MC App & SA
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @Janfi
        @Janfi someone said 2021 at least. More news coming at the end of the week. Search the forum for more discussion, but some discussion may break your heart.
        Blog: isazi's home
        lohtseL 1 Reply Last reply Reply Quote 0
        • lohtseL Offline
          lohtse @isazi
          @isazi said in Ambit 3 Peak : Keep Movescount or change for SUUNTO app ?:
          And stomp your feet…ALOT…
          Ambit 3 Peak with HRM, Movescount on Samsung S6 Active,Android 7.1.2…Suunto app installed for test only…
          • M Offline
            michaeldwilson Bronze Member @Bulkan
            @Bulkan said in Ambit 3 Peak : Keep Movescount or change for SUUNTO app ?:
            @michaeldwilson enjoy running with the web interface!
            Yay!! Thanks!!!
            • Bruno JacqB Offline
              Bruno Jacq
              Both the App and MovesCount habe been worth due to the transition:
              • I cannot see the Moves on MC anymore, but just plan a route, et set the watch parameter.
              • The App makes it impossible to set the watch parameters, to download a GPS track, to modify the GPS points, …
              • The App shows very strange HR-Profiles, like a crazy saw, what was not the case on MovesCount.
              • The App calculates the run distance new, after the upload of the track: 10,0 km on the watch, 9,71 on the App. It makes me crazy.
              It would really stay only on MovesCount, with all the functions and possibility it offered ! And with the easyness on PC, compared to a Smartphone display…
              Dimitrios KanellopoulosD ? 2 Replies Last reply Reply Quote 0
                Dimitrios Kanellopoulos Community Manager @Bruno Jacq
                @Bruno-Jacq are you using iOS ? I think there is a bug when editing an activity that it changes the distance… can this be it ?
                Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                Bruno JacqB 2 Replies Last reply Reply Quote 0
                • ? Offline
                  A Former User @Bruno Jacq
                  @Bruno-Jacq said in Ambit 3 Peak : Keep Movescount or change for SUUNTO app ?:
                  Why you don’t? You still can.
                  Install movescount app, moveslink, and suunto app.
                  Sync with movescount app or moveslink and then if you want your moves on suunto app sync with suunto app.
                  If you don’t want to have two apps, you can use rungapp.
                  Bruno JacqB 1 Reply Last reply Reply Quote 1
                    Bruno Jacq @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos I thought, that the App uses the tracks of the maps to adjust the distance. Could it be? If not, then I have a bug…
                      @Dimitrios-Kanellopoulos I use Android 10.
                      Thanks.
                        Bruno Jacq @Guest
                        @André-Faria I couldn’t do anything with MovesCount anymore. No upload from the watch anymore. So I changed to the SUUNTO App. I upload the GPS tracks from the watch via the SUUNTO interface on PC SuuntoLink, and can only see the moves on the App. The Movescount account is just frozen since move nr. 400 on 20 of June 2020.
                        But the watch parameters are only available on Movescount… I have no access to the watch parameters on the SUUNTO App. Is it normal?
                        Thanks.
                        • ? Offline
                          @André-Faria I couldn’t do anything with MovesCount anymore. No upload from the watch anymore. So I changed to the SUUNTO App. I upload the GPS tracks from the watch via the SUUNTO interface on PC, and can only see the moves on the App. The Movescount account is just frozen since move nr. 400 on 20 of June 2020.
                          Thanks.
                          Strange, I made the switch to SA, but since I didn’t enjoyed it, I continue to use moves count normally, via moves link or even moves count app on iOS.
                          Everything works fine.
                          Even found out that you can sync with moves count app and Suunto app on same phone, seamlessly.
                          And recently you don’t even need to do that, rungap does it for you.
                          It is normal that you don’t have access of watch settings on Suunto app.
                          Maybe this video help to understand how new workflow is done:
                          https://www.youtube.com/watch?v=c8VwhU99AIM
                          still, till now you are not obliged to use it.
                          Bruno JacqB 1 Reply Last reply Reply Quote 2
                            Bruno Jacq @Guest
                            @André-Faria : Thanks a lot ! But I don’t find the App rungap. Do you have an advice for me? Renamed as “SyncMyTracks” maybe?
                            • ? Offline
                              that is for android. rungap is for iOS. both do the same I believe
                              • angryrabbitA Offline
                                angryrabbit @lohtse
                                @lohtse said in Ambit 3 Peak : Keep Movescount or change for SUUNTO app ?:
                                Movescount works and works almost perfectly for mosts of us and fits are needs… Suunto App DOES NOT COME CLOSE to meeting the needs and functionality of movescount…
                                exactly!
                                1 Reply Last reply Reply Quote 4
                                Register Login
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
