    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S7 and S9 on same phone
    Scheduled Pinned Locked Moved Suunto app and other software services
    10 Posts 4 Posters 720 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • B Offline
      BKtoo Bronze Member
      any tricks for using the S7 and S9 with the Suunto app on the same phone? Any possibility of using HR belt with S7?
      • EgikaE Offline
        Egika Platinum Member
        you can pair both and then in the app switch from one watch to the other by “forgetting” it and connecting the other one.
        Works pretty well.
        You can use a BT heart rate belt with the S7, just at the moment not with the native Suunto watch app.
        Other apps like Ghostrunner can use external sensors without problems.
        If you can wear your watch on your wrist, the new integrated HR sensor works pretty well though.
        B 1 Reply Last reply Reply Quote 2
        • B Offline
          BKtoo Bronze Member @Egika
          @Egika thanks for good advice. Do you mean disconnection and connection under this symbol in the Suunto app? 627C9217-D7FA-4CEF-BC28-067EA6375C80.jpeg
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @BKtoo
            @BKtoo Yes but do not unpair the watch, just forget. You can then easily swap watches. I swap up to 5 different watches with one phone and one SA😵
            Vector/T6c/Vertical 2 Ti
            B 1 Reply Last reply Reply Quote 3
            • B Offline
              BKtoo Bronze Member @Brad_Olwin
              @Brad_Olwin you mean forget watch in the Suunto app? I did it in settings-BTsettings om the phone. And now I can’t connect my S9. Any trick?
              • T Offline
                tomahawk5000
                Hi guys and hope about with connect one S9 to 2 phones? Is it possible to receive notification from 2 phones?
                Kind regards,
                Tomek
                Suunto 9 baro -> Vertical 2
                • EgikaE Offline
                  Egika Platinum Member @BKtoo
                  @BKtoo said in S7 and S9 on same phone:
                  Don’t touch the phone BT connection.
                  Just do it in the app only where Brad indicated.
                  Both watches stay in the list of known devices of the phone.
                  Brad_OlwinB B 2 Replies Last reply Reply Quote 2
                  • EgikaE Offline
                    Egika Platinum Member @tomahawk5000
                    @tomahawk5000 not possible
                    S9 can handle only one connection per type.
                    One phone, one foot pod, one HR belt etc…
                    It has been asked before to be able to manage multiple devices in the watch…
                      Brad_Olwin Moderator @Egika
                      @Egika Thanks Egika!
                      • B Offline
                        @Egika thanks! It solved the problem👍6FCA2278-35BE-4333-8ECB-CAAC62FB39B3.png
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
