    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    HR reading problem
    Scheduled Pinned Locked Moved Suunto 7
    32 Posts 10 Posters 5.3k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      Shrek3k @loopylou72
      @loopylou72 my experiences with OHR combined with a textile strap are not as good as with a silicone strap.
      The reason seems to be, that the silicone strap is flexible - even when tightened - which the textile strap is not. When pushing the tightened watch up the arm it only stays there reliably with the silicone strap.
      using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
      OS - Android 16/Pixel Pro 7
      ? L 2 Replies Last reply Reply Quote 0
      • ? Offline
        A Former User @Shrek3k
        @Shrek3k Try the new Velcro loop strap if you can get your hands on it. It’s pretty grabby, yet comfortable. My readings aren’t perfect but definitely improved. I think between the strap and a band to push the watch higher up arm, this should do the trick.
        I’m still wondering though why this became a problem about a year ago and wasn’t much of an issue when I first got the watch? Could it actually be some firmware changes last year?..
        One shouldn’t have to put on a wardrobe of accessories to get a single sensor working properly.
        • L Offline
          loopylou72 @Shrek3k
          @Shrek3k OK thanks for that could save me some money! I can use the silicon strap from my old watch but it is white and my new one black!
          • JorgeFDJ Offline
            JorgeFD
            Today Tábata training
            Suunto 7 with Velcro strap in the correct place and good tight and Suunto 9 with polar fc
            Mff73M 1 Reply Last reply Reply Quote 0
            • Mff73M Online
              Mff73 @JorgeFD
              @jorgefd78
              Both are saying you are alive 🙂
              SSU (retired), SV1, SV2
              Wife : S9PP
              SA: Always the latest beta :)
              Android + Galaxy S205G
              JorgeFDJ 1 Reply Last reply Reply Quote 0
              • JorgeFDJ Offline
                JorgeFD @Mff73
                @Mff73 hahahahaha thank you suunto to let me know!!
                • Brad_OlwinB Offline
                  Brad_Olwin Moderator
                  Here is a comparison I did last weekend on a long run. One S9 with Velcro strap worn above the S7 (silicone on left wrist) on my forearm, one S9 on the right wrist (silicone strap) and the S7 on the left wrist. This was a very steep and technical trail so it is very hard for the watches when running downhill as they can bounce. The S7 only had a little trouble in one spot, and the S9 on my wrist was horrible, the other S9 was great. No strap but I can tell you the strap would like exactly like the S9 worn on my arm. All are OHR.
                  This shows the S9 OHR is fine, it just does not work well on the wrist for running. The S7 is much better.
                  Vector/T6c/Vertical 2 Ti
                  JorgeFDJ 1 Reply Last reply Reply Quote 2
                  • JorgeFDJ Offline
                    JorgeFD @Brad_Olwin
                    @Brad_Olwin way different in my case. I was doing Tabata trainings with quick movements. Next Saturday I will test running
                    • isaziI Offline
                      isazi Moderator
                      I’ll do my first strength training with the S7 today, and I’ll report the results of my HR later.
                      Blog: isazi's home
                      isaziI 1 Reply Last reply Reply Quote 0
                      • isaziI Offline
                        isazi Moderator @isazi
                        @isazi replying to myself. Did a similar circuit like the previous week (that time with S9 + chest band), results have a similar trend to last week in for the first 20 minutes, but then I did hangboard training and that’s not great for a OHR on the wrist.
                        Blog: isazi's home
                        • JorgeFDJ Offline
                          JorgeFD
                          Today I could do my first run. Very slow rhythm so the watch didn’t bounce too much. Left wrist S7 with Suunto velcro strap. Right wrist Suunto 9 Baro + Polar OH1
                          The HR was P E R F E C T
                          s7 in red/pink color
                          GPS was worst in S7… but this is an HR thread 🙂
                          1 Reply Last reply Reply Quote 3
                          • L Offline
                            loopylou72 @Guest
                            @NickK yes 100% agree. I think it might be updates too…
                            I got my new textile strap and tried it today - no change at all same problem. I actually think it is picking up cadence as you suggest, not heart rate - I tried a few faster, slower paces including fast downhill where heart rate doesn’t go up… So is there a fix for this?
                            Register Login
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
