    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Lockdown setting suunto 9
    31 Posts 6 Posters 2.8k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • G Offline
      GingerBeardMan Bronze Member
      What are the chances of getting a better GPS resolution at the expense of battery life so we can get more realistic representation of our miniature garden routes. I ran loops until my watch said 15km but when i measured the loop I did more like 20km.
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Online
        isazi Moderator @GingerBeardMan
        @GingerBeardMan I consider running in small confined spaces the same as running indoor, and use the treadmill mode (paired with a Stryd) for that. The usefulness of a GPS track in my own 10 square meters garden is very questionable, and I just want distance, time, pace.
        Blog: isazi's home
        • G Offline
          thanks, unfortunately i don’t own a stryd pod
          isaziI ? 2 Replies Last reply Reply Quote 0
          • isaziI Online
            @GingerBeardMan would work even without (or with any footpod). May be less precise without a footpod, but better than with GPS.
            Blog: isazi's home
            • G Offline
              thanks, I’ll give it a go
              • isaziI Online
                @GingerBeardMan I am just commenting because GPS is not made to give you accurate tracks in a confined space, and will never be, no matter how much battery power you may want to give up on your watch.
                Blog: isazi's home
                • G Offline
                  I was just looking at the GPX file exported from movescount and the time stamps show a GPS resolution that varies as high as 6 seconds in some cases. was wondering if there was a way to prioritize GPS to achieve closer to the 1 seconds resolution as advertised
                    Dimitrios Kanellopoulos Community Manager
                    Please don’t confuse sampling rates with GPS. Most providers (even Strava ) linearly interpolate the distance. (to fill 1s)
                    We don’t support gpx export btw. So you probably are using sports tracker data which are not compatible with what your watch records. They are too simplified and a different model.
                    As it has been said before, you cannot really record small loops. The GPS avg error is about 7 meters. That means that if you don’t move more let’s say than a 7 meters in general it might error, thus no record of data.
                    As it has been said before, GPS is not made for this kinda thing. Or at least yet, there is a chnace that maybe this chnages especially for BEIDOU.
                    That said, you can try if you own a suunto 9:
                    Use BEIDOU.
                    Or you can try the fused track, eg enabling endurance mode.
                    That will power up all internal things to do inertial GNSs extrapolation. It might work but maybe no. Give it a try and I am eager to see the results.
                    Creator of Quantified-Self.io
                    youtube.com/c/dimitrioskanellopoulos
                    https://instagram.com/dimitrioskanellopoulos
                    https://www.strava.com/athletes/7586105
                    G 2 Replies Last reply Reply Quote 1
                    • G Offline
                      Hi Dimitrios,
                      I tried Beidou with no noticable difference.
                      I was just curious about the GPX data points(Sportstracker and movescount) because if I walk slowly, I get an accurate measurement, 160m out and back across the property(very accurate), when i run i get 110 to 130m per lap. This is why I suspected resolution rather than accuracy as I thought maybe the ends of each lap were being missed because they occurred between gps readings.
                      I have resorted to using the watch to just count laps, had a problem this morning when I pushed the lap button for lap 62, the watch reset. I’ve never had my watch reset during a workout before.
                      • ? Offline
                        A Former User @GingerBeardMan
                        @GingerBeardMan said in Lockdown setting suunto 9:
                        Get a regular footpod. I think Zwift one used to be like $25 and it’s reasonably accurate.
                        G 1 Reply Last reply Reply Quote 0
                        • G Offline
                          GingerBeardMan Bronze Member @Guest
                          @NickK total lockdown here. We can’t even order non-essentials online so, by the time I get it, I won’t need it😬
                          ? isaziI 2 Replies Last reply Reply Quote 0
                          • ? Offline
                            Tough love! Can you claim footpod as essential? We are supposed to have all non-essential businesses closed where I live. Apparently, bakeries, liquor, and flower stores count among essentials. Because they all are very much opened.
                            • isaziI Online
                              @GingerBeardMan even without the footpod, use the treadmill activity and swing your arms. Better than just laps 🙂
                              Blog: isazi's home
                              • G Offline
                                GingerBeardMan Bronze Member @isazi
                                @isazi attempted this but got same results. did try excessive arm swinging though 😉
                                • G Offline
                                  @NickK If only. we have the army enforcing lockdown, no cutting corners
                                  • G Offline
                                    GingerBeardMan Bronze Member @Dimitrios Kanellopoulos
                                    @Dimitrios-Kanellopoulos the fused track was much worse. I did 15km: 75x200m loops. My watch measured just over 9.5km and my trace was all over the neighborhood:)
                                    • G Offline
                                      @Dimitrios-Kanellopoulos Sorry to be argumentative but the files exported from movescount show gaps of up to 8 seconds between data points I can’t imagine other manufacturers just fabricate 6 out of every 8 GPS points to achieve their advertised 1 second resolution. My Old Tomtom multisport is out performing my suunto 9. Is this just one of the costs of havin long battery life.
                                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                                        Dimitrios Kanellopoulos Community Manager @GingerBeardMan
                                        @GingerBeardMan Hi please dont use GPX files (Why the obsession with that? ) . This is how GPS tracking works in all modern applications.
                                        As an engineer on this subject with all the respect, because your Tomtom Did 1s interpolation doens’t mean that this is what happened neither what leading technology should do. I personally don’t like this type of argument. There are many reasons for that to happen on your old tom tom and mostly was not due to GPS but rather software extrapolation and interpolation on the export. (Yes I have worked on TomTom data 😉 )
                                        Here is an example of loose records and how FIT files from Suunto app are generated. Movescount had many issues on this part and this functionality will go away
                                        100:
                                        timestamp: Sat Apr 04 2020 15:01:45 GMT+0200 (Central European Summer Time) {}
                                        position_lat: 49.87775534391403
                                        position_long: 14.683535909280181
                                        distance: 379.5
                                        heart_rate: 162
                                        altitude: 404
                                        speed: 4.031
                                        activity_type: "running"
                                        cadence: 89
                                        power: 287
                                        accumulated_power: 34748
                                        stance_time: 224
                                        stance_time_balance: 48.5
                                        vertical_oscillation: 93
                                        vertical_ratio: 6.5
                                        step_length: 1310
                                        __proto__: Object
                                        101:
                                        timestamp: Sat Apr 04 2020 15:01:46 GMT+0200 (Central European Summer Time) {}
                                        position_lat: 49.87772106193006
                                        position_long: 14.683511098846793
                                        distance: 384
                                        heart_rate: 163
                                        altitude: 404
                                        speed: 4.056
                                        cadence: 88
                                        power: 283
                                        accumulated_power: 35031
                                        stance_time: 228
                                        stance_time_balance: 47.2
                                        vertical_oscillation: 91
                                        vertical_ratio: 6
                                        step_length: 1330
                                        __proto__: Object
                                        102:
                                        timestamp: Sat Apr 04 2020 15:01:47 GMT+0200 (Central European Summer Time) {}
                                        position_lat: 49.877690551802516
                                        position_long: 14.683481510728598
                                        distance: 388.5
                                        heart_rate: 163
                                        altitude: 404
                                        speed: 4.056
                                        cadence: 87
                                        power: 289
                                        accumulated_power: 35320
                                        stance_time: 234
                                        vertical_oscillation: 95
                                        vertical_ratio: 6.5
                                        step_length: 1340
                                        __proto__: Object
                                        103:
                                        timestamp: Sat Apr 04 2020 15:01:48 GMT+0200 (Central European Summer Time) {}
                                        position_lat: 49.87765618599951
                                        position_long: 14.683452928438783
                                        distance: 393
                                        heart_rate: 162
                                        altitude: 404
                                        speed: 4.056
                                        cadence: 87
                                        power: 295
                                        accumulated_power: 35615
                                        stance_time: 241
                                        stance_time_balance: 48.8
                                        vertical_oscillation: 100
                                        vertical_ratio: 7
                                        step_length: 1350
                                        timestamp: Sat Apr 04 2020 15:01:49 GMT+0200 (Central European Summer Time) {}
                                        position_lat: 49.87762190401554
                                        position_long: 14.683426190167665
                                        distance: 397
                                        heart_rate: 163
                                        altitude: 404
                                        speed: 4.056
                                        cadence: 88
                                        power: 294
                                        accumulated_power: 35909
                                        stance_time: 241
                                        stance_time_balance: 47.3
                                        vertical_oscillation: 101
                                        vertical_ratio: 7.2
                                        step_length: 1350
                                        __proto__: Object
                                        105:
                                        timestamp: Sat Apr 04 2020 15:01:50 GMT+0200 (Central European Summer Time) {}
                                        position_lat: 49.87758368253708
                                        position_long: 14.6833985298872
                                        distance: 401
                                        heart_rate: 164
                                        altitude: 404
                                        speed: 4.056
                                        cadence: 90
                                        power: 294
                                        accumulated_power: 36203
                                        stance_time: 242
                                        stance_time_balance: 45.9
                                        vertical_oscillation: 102
                                        vertical_ratio: 7.5
                                        step_length: 1350
                                        With all the respect:
                                        • GPS polling on the watch happens every 1second.
                                        • Depending on the signal quality and other errors the distance is calculated every 1s if possible (also accounting accelerometer)
                                        • GPX files cannot export non tree stuctures meaning that for each track record you need to interpolate or remove other track records if there are no data. For example if you miss coordinates but you have distance you cannot create a trackrecord as they dont support track records without coordinates.
                                        • FIT files is what you should use.
                                        Some side notes:
                                        • Running on a tarrace we dont measure the x,y you need to measure a circle by defining the radious.
                                        • Running on a circle you will injure your self eventually if you dont change direction as one foot will push more than the other.
                                        • GPS error is about ~5m in the best. If your tarrace is not >5m as of a radious I cannot imagine this can work with any equipemnt.
                                        • Educate your self since you are on it about accuracy. Dual frequency antennas and what is possible. for 5m loops I am sorry but this is not possible. To get a kinda good GPS “circle” you need 5m + 5m = 10m radious at least! That is if you have the best GPS signal! In normal conditions it should be 7m + 7m = 14m radious.
                                        Here is a site that can help you and here is the image of what I am talking about
                                        https://fellrnr.com/wiki/GPS_Accuracy
                                        Image of how accuracy works
                                        P.S. I am sorry if this sounds a bit agressive but I got a bit on my nerves because I tend to think that you are trying to create a problem for something that it’s not naturally possible in a way. I understand that and sorry.
                                        PS1.5 Please don’t focus on the 1s GPX export, that is not the reason for your issue.
                                        P.S2: Will a A3P work better than your S9? Perhaps. Perhaps even your old tom tom due to the antenna being external and patch (always looking at the sky)
                                        Here is the problem with circular antennas and how sony solved it:
                                        https://www.sony-semicon.co.jp/e/products/lsi/gps/technology.html
                                        Note this:
                                        The targeted low-cost and low-power system design, along with the expected harsh operational environment, derived us to face exceptional GNSS signal reception conditions.
                                        Sony Semiconductor Solutions GPS/GNSS receiver/processor chips use a proprietary positioning algorithm to enable accurate positioning in a challenging environment, such as the skyscrapers of Shinjuku (i.e., multi-path environment) and/or when running on an athletics track (i.e., body effect, such as arms swinging and swimming).
                                        (I would google GNSS body effect if I was you )
                                        Take it easy, be healthy and protect your self. I’ts more important to be healthy than to get perfect GPS on a tarrance. 🙂
                                        1 Reply Last reply Reply Quote 4
                                        • G Offline
                                          I’m sorry if I’m pissing you off. Let me me just shut up and be happy with what I have.
                                          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                                            @GingerBeardMan nah man. It’s all good. But just those comparisons like : Simpsons did it.
                                            On the contrary you gave place for some good analysis for tarrace runners.
                                            You didn’t piss me off per se, but rather step on nerves.
                                            It’s all good and it was my mistake to get nerves. I am the d528head here 🙈
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
