    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Problem_exercise syncing problem with Movescount on PC
    23 Posts 8 Posters 1.7k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • kkunsteljK Offline
      kkunstelj
      Hi! Does anyone know how to avoid the problem of syncing with my PC Movescount. It was working until a month ago. In parallel I am using Suunto app on my android phone.Thanks
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
      • Dimitrios KanellopoulosD Online
        Dimitrios Kanellopoulos Community Manager @kkunstelj
        @kkunstelj I think the message is clear no?
        Good morning
        Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
          kkunstelj
          How can I fix it?
            @kkunstelj you need to fill reset the watch into factory settings.
            zvonejanZ 1 Reply Last reply Reply Quote 0
              kkunstelj
              So this proble will re-appear next time I transfer another route via Suunto app? Is that right?
                @kkunstelj yes that is correct. Or customize a sport mode.
                  kkunstelj
                  @Dimitrios-Kanellopoulos Thank you. But I find this awkward. Why can´t Suunto fix this by making both options available? So creating routes and syncing with both SW?
                  freeheelerF zvonejanZ 2 Replies Last reply Reply Quote 1
                  • freeheelerF Offline
                    freeheeler @kkunstelj
                    @kkunstelj
                    because they’re 2 different systems and one day it is time to take a step forward in order to further improve systems and technology 👌
                    living sideways
                      kkunstelj
                      @TELE-HO 👍 Thank you. I agree, it sounds reasonable. If so then Suunto can also develop a new SW for PC like they transferred from Movescount app to SuuntoApp 😉
                        @kkunstelj waypoints are soon coming to Suunto app so hold on there
                        kkunsteljK thexvoT 2 Replies Last reply Reply Quote 1
                          kkunstelj @Dimitrios Kanellopoulos
                          @Dimitrios-Kanellopoulos Perfect 👍. Thank you.
                          • thexvoT Offline
                            thexvo @Dimitrios Kanellopoulos
                            @Dimitrios-Kanellopoulos said in Problem_exercise syncing problem with Movescount on PC:
                            What about syncing them (and routes) with Ambit3?
                            To further lessen the need to sync via cable.
                            Ambit3 Vertical
                            Smart Sensor
                            SA beta on iOS 12
                            MarynM 1 Reply Last reply Reply Quote 1
                            • zvonejanZ Offline
                              zvonejan Bronze Member @Dimitrios Kanellopoulos
                              Nope, it is not neccesary. Just go in WATCH setting and FORGET mobile app. Did that al least 100 x times
                              N kkunsteljK 2 Replies Last reply Reply Quote 0
                              • zvonejanZ Offline
                                Well, I did not test this with latest version of FW on suunto 9…
                                • zvonejanZ Offline
                                  zvonejan Bronze Member @kkunstelj
                                  @kkunstelj
                                  Sync watch with Suunto app, but do not edit routes and sport modes. Do that on Movescount and sync watch with Movescount and cable
                                  • N Offline
                                    nseslija Bronze Member @zvonejan
                                    @zvonejan I will try that this weekend…
                                    Ambit 2S
                                    Ambit 3 Peak
                                    Suunto 9 baro
                                    Suunto Vertical Ti Solar
                                      kkunstelj @zvonejan
                                      @zvonejan Disabling Suunto app in Watch setting didn´t work for Suunto 9
                                      • zvonejanZ Offline
                                        Uf, this is realy bad news!!. you have the latest FW?
                                        ok, to repeat the steps:
                                        1. In Suunto app android go to setting manage connection and FORGET
                                        2. In watch setting go to mobile connection and tap FORGOT
                                        3. Upper right button 12 seccond, soft reset
                                        4. Close web page for movescount (if it is open)
                                        5. Connect the cable to the watch.
                                        Second step in most important
                                        • MarynM Offline
                                          Maryn Silver Members @thexvo
                                          @thexvo good question but I think you will not find answer 🙂
                                          Suunto Vertical, Suunto Race, Edge 530, Vantage V, Suunto Wings, Polar H10&Verity Sense
                                          freeheelerF 1 Reply Last reply Reply Quote 1
                                            freeheeler @Maryn
                                            @Marcin-Byrtek
                                            only time will tell
                                            living sideways
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
