    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery LIfe
    Scheduled Pinned Locked Moved Suunto 7
    450 Posts 54 Posters 181.5k Views 55 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      MeazzaS9 @olymay
      @olymay said in Battery LIfe:
      @meazzas9 i promised an update on my S7 from Friday, sorry for the delay. I accidently put it on charge briefly on Saturday (it’s automatic for me to put it on charge when I have a shower), so it has lasted a bit longer then expected.
      During this time, I did no activity tracking (letting a knee injury recover) but did receive quite a large number of notifications.
      As you can see, the battery life is significantly more than yours, but what stands out to me is the Bluetooth battery usage. It does seem like this is where your battery is being drained. Maybe a setting is causing an issue? Either on the watch or the phone? Or maybe there is a hardware issue? Contacting support may be your best best, sorry 😞
      Side note, have you tried wearing it 24/7 yet? Have you got the body resources and sleep tracking data? If so, how are you finding it?
      The Bluetooth connection makes me last the battery of the S7 around 14 / 18h.
      The discharge trend is sudden and continuous until the phone is restarted, on more than one occasion I have noticed that the discharge curve is much slower and consumption approaches 2/3 days.
      In the days with the best battery estimate, the bluetooth “fault” degradation accounts for 1%, the biggest problem is that consumption starts to rise for no apparent reason … I find myself with the modified battery curve and the bluetooth percentage> 12 %
      My use of S7 is as a smartwatch (for sent work, notifications and calls), for outdoor uses S9Baro.
      Count that the clock is “exploited” more in working hours.
      In the night monitoring with “normal” bluetooth it absorbs me 6/9% instead when the problem occurs it even reaches over 40%
      The connected mobile is a Samsung A40 with the latest updates.
      Here is the configuration of my Suunto 7
      • Suunto dial
      • Rotate the wrist for energy saving
      • brightness 2/5
      • 24h HR monitoring
      • sleep monitoring
      • screen off 5 seconds
      • do not disturb when not worn
      • increase brightness with sunlight OFF
      • WIFI OFF
        -NFC OFF
      • Use position from phone and watch OFF
      • vibration
      • tap to reactivate
      • show point for notification
      I sent the whole report to assistance, let’s see what they say
      Suunto Race S Gravel Gray (2024)
      Suunto Vertical Black Lime (2023)
      Suunto 7 Graphite Copper (2021)
      Suunto 9 Baro Black (2020) sold
      olymayO 1 Reply Last reply Reply Quote 0
      • olymayO Offline
        olymay Gold Members @MeazzaS9
        @meazzas9 There is definitely something strange going on here. I have just had a new best of 56hrs of battery life from my S7 (no activity tracking during that time, just used as smartwatch).
        This is still with my usual settings:
        AoD off
        power saver tilt
        many notifications
        24/7 HR on
        sleep tracking on
        etc.
        You mention that it is a Bluetooth bug that only happens now and then. I wonder if this could be related to something on the phone? Maybe there is an overly aggressive power setting on the phone that is killing the connection to the watch, thus causing the watch to hunt for a connection? This would cause it to drain the battery quickly?
        Just a thought…
        Suunto App Beta (Android - Pixel 6 Pro)
        M 1 Reply Last reply Reply Quote 0
        • M Offline
          MeazzaS9 @olymay
          @olymay the next step is a reset of the phone and if that weren’t enough I will change phones
          • olymayO Offline
            @meazzas9 check the power/battery settings in the phone first, it could be a simple fix that doesn’t require a reset.
            Worth a try.
            If unsure, do a Google search for battery optimisation on your specific phone.
            Make sure it isn’t killing WearOS or the Suunto App (i think WearOS migt be the important one here)
            • BinoWorld UKB Offline
              BinoWorld UK Bronze Member @Steff
              @steff Hi there
              Just got my S7 three days ago and I already charged it like three times between playing around checking the apps……
              Today, I charged it to 100% at 7am it’s 13:30pm and my battery went down to 85% without any usage?!
              It says I have one day left.
              Watch idle 3%
              Android System 2%
              Android OS 1%
              Bluetooth 1%
              Is this normal?
              I have raise to wake off
              Screen is also off
              No Wifi
              No NFC
              Brightness on Auto
              Auto app update off
              Using Suunto Stock face
              Any help would be appreciated
              Thanks
              olymayO Jamie BGJ 2 Replies Last reply Reply Quote 0
              • olymayO Offline
                olymay Gold Members @BinoWorld UK
                @optics-field-test WearOS (as with Android on pones) takes roughly a week to fully settle down and to adjust to your typical usage. This is part of the adaptive battery and means the first few days will not be representative of true battery life.
                If after a week you still get poor battery life then it is worth looking at. But in the mean time it’s nothing to worry about.
                BinoWorld UKB 1 Reply Last reply Reply Quote 1
                  BinoWorld UK Bronze Member @olymay
                  @olymay Hi,
                  Thank you mate for the swift response and reassurance.
                  I hope the battery will improve, I will certainty give it a week and see if things improve. So far it seems worst then my my Apple Watch S6.
                  Btw the watch arrived dead with no battery at all. Not sure if this bad or not?
                  Finger crossed!
                  Thanks
                  • olymayO Offline
                    @optics-field-test I typically get an easy 48hrs from a charge (although recently i’ve been getting well over 50!)
                    I have:
                    Always on display OFF
                    tilt to wake OFF
                    Power saver tilt ON
                    Touch to wake OFF
                    Auto update ON
                    WiFi ON
                    NFC ON
                    Continuous HR ON
                    Sleep tracking ON
                    And plenty of notifications throughout the day
                    Although recently I haven’t been doing any activity tracking due to an injury. Obviously, activity tracking (especially if using GPS) will affect the battery life.
                    You should be easily outlasting any Apple Watch with battery life.
                    I got my S7 over 18 months ago, so I can’t remember how it arrived in the box, sorry.
                      @olymay WAW that sounds great!
                      I am crossing my fingers that mine gets to this stage of battery life.
                      I guess like all smart watches they need time to settle down. Finger crossed.
                      Did your watch also had worst battery the first couple of days??
                      Thanks
                      • M Offline
                        MeazzaS9 @olymay
                        @olymay today i try a reset of the phone … the bluetooth problem drains my battery too fast.
                        I update you
                        BinoWorld UKB olymayO 2 Replies Last reply Reply Quote 0
                          BinoWorld UK Bronze Member @MeazzaS9
                          @meazzas9 what operating system are you using? Android or IOS.
                          My watch sometimes it disconnect too easily from my IPhone. Only 10 meters away and it’s disconnected.
                          I probably should have wifi on Auto but it does kill the battery especially when using for Google store. I tend now update or install an app only if my watch is on charge
                          M Brad_OlwinB 2 Replies Last reply Reply Quote 0
                          • olymayO Offline
                            @meazzas9 said in Battery LIfe:
                            I update you
                            Have you checked the power settings of the phone? Some phone manufactures use aggressive app management to extent battery life. Make sure there isn’t anything killing the Bluetooth connection or the WearOS app.
                            M BinoWorld UKB 2 Replies Last reply Reply Quote 0
                            • Jamie BGJ Offline
                              Jamie BG Bronze Member @BinoWorld UK
                              @optics-field-test #
                              Normal usage battery life is anywhere from 1.8 to 2.7% / hr depending on settings and usage. So yes well within the norms, especially as most peoples first week isn’t really normal usage as you are using the watch far more than you normally would, and that beautiful screen loves to suck up the battery.
                              • M Offline
                                MeazzaS9 @olymay
                                @olymay there are no connection cut settings … everything is fine
                                • M Offline
                                  MeazzaS9 @BinoWorld UK
                                  @optics-field-test I use android, reset the phone but the problem remains … the bluetooth is very energy consuming
                                  • olymayO Offline
                                    It looks like you are using a Samsung phone, they are well known for aggressive battery and RAM management which can kill processes in the background.
                                    Check the battery optimisation settings for WearOS and Bluetooth, make sure they are set to unrestricted.
                                    I haven’t used a Samsung phone for years, so are there are any Samsung users here who can help more?
                                    ? M 2 Replies Last reply Reply Quote 0
                                      @olymay I checked and it looks like the culprit was that I had another Suunto traverse lying near by and powered on. Since I removed the Bluetooth connexion of the traverse and reset the S7 to factory things have been working flawlessly. Also, my battery seem to be amazing now. Off the charge at 9am at 6pm still on 80% with few notifications and checking body battery every now and again. All good so far! Happy days
                                      olymayO 1 Reply Last reply Reply Quote 3
                                      • olymayO Offline
                                        @optics-field-test said in Battery LIfe:
                                        YES!! That’s brilliant news!!! 😄
                                        • ? Offline
                                          A Former User @olymay
                                          TO DELETE
                                          • olymayO Offline
                                            olymay Gold Members @Guest
                                            @flypg Thays good to hear 🙂
                                            Like I said, it’s been a while since I’ve had a Samsung and they used to kill apps very aggressively (although not as bad as the OnePlus I had before that!).
                                            I’m glad to hear that at least key apps are being whitelisted from these lists.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
