    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S7 and Stryd with SA
    Scheduled Pinned Locked Moved Suunto 7
    9 Posts 6 Posters 938 Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Brad_OlwinB Offline
      Brad_Olwin Moderator
      Ok here a a sneaky way to get your Stryd data and S7 data merged. You need a Premium TrainingPeaks account (sorry).
      1. Record a run with the S7, wear your Stryd and allow it to sync to TrainingPeaks.
      2. Offline sync Stryd for the same run.
      3. In Stryd PowerCenter download Stryd fit file.
      4. Follow this and you have a merged file in TrainingPeaks that you can download as .fit
      https://help.trainingpeaks.com/hc/en-us/articles/204073774-How-do-I-use-AutoMerge-
      An example
      http://tpks.ws/RMAWZQX7OHCLCKZ5P6ELEQHIRE
      Vector/T6c/Vertical 2 Ti
      ? 1 Reply Last reply Reply Quote 3
      • ? Offline
        A Former User @Brad_Olwin
        @Brad_Olwin … Or you can just use Sporty Go 😂 Export your run to Strava and from there to SA using PhoneGap. Works well on treadmill. Haven’t tried it for outdoor runs though.
        You should also be able to do:
        1. Sporty Go > Strava > SA > Stryd Power Center
        2. Offline sync Stryd sensor to Power Center, which should automatically merge two activities
        3. Enjoy your FIT file that contains not only GPS tracks, HR, and power, but also Stryd specific fields
          Brad_Olwin Moderator @Guest
          @NickK My experience with SportyGo has been poor. I cannot read the screens very well, it is very buggy connecting to my Stryd and HR and it eats battery. It has crashed on every run, cannot properly detect altitude and loses Stryd connection on every run. I prefer SA and would rather combine the files than use SportyGo.
          • BulkanB Offline
            Bulkan Moderator
            All this would be easier if Stryd had a proper app in WearOS. Is a work around ok. The sensor with Suunto ap is the best solution but I’m afraid we won’t have it.
            Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
            Yak ImaY 1 Reply Last reply Reply Quote 1
            • ? Offline
              @Brad_Olwin I understand. Heard others had some strange issues with it too. For running, I only used Go on treadmill once, for about 5 miles test. It worked fine. No crashes, no disconnects for HR/Stryd. Otherwise, I mostly use it for regular gym training. Had a single HR disconnect around 43 minutes in once, but I’m not sure it’s Sporty Go faulty.
              Battery wise it’s worse than Suunto app, but not by much. I’d say around 10-12% per hour for me.
              Speaking of Stryd… I believe I mentioned it elsewhere but it’s worth repeating: I talked to Stryd support and this is the app they recommend. No plans to port their existing Apple Watch offering. At least, support isn’t aware of any work done in that direction.
                @NickK I am not using my S7 as my S9, just trying to help folks. The S7 does need a few things in my opinion. 1. all daily data/HR/Steps/sleep into SA, 2. Adjustable zones for HR and 3. Ability to load and follow routes. For me I think that would be it. I am ok with the sport modes on the watch.
                Fenr1rF 1 Reply Last reply Reply Quote 3
                • Fenr1rF Offline
                  Fenr1r @Brad_Olwin
                  @Brad_Olwin said in S7 and Stryd with SA:
                  1. Ability to load and follow routes
                  On the subject of which (feel free to move this over to general S7), did you ever get an idea of the comparative battery drain for ViewRanger app vs SA?
                  • Yak ImaY Offline
                    Yak Ima Bronze Member @Bulkan
                    @Bulkan Or even easier if Suunto allowed external sensors in their app
                    • JorgeFDJ Offline
                      JorgeFD
                      it’s a pity. I love my s7…it is the best all day watch I have ever try but the lack of official support of stryd make me left at home every time I go for a run and get my s9.
                      PLEASE SUUNTO…
                      1 Reply Last reply Reply Quote 4
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
