    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S5 keeps crashing
    Scheduled Pinned Locked Moved Suunto 5
    9 Posts 6 Posters 1.2k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Cornell TsiangC Offline
      Cornell Tsiang
      I have had the Suunto 5 unit for just over one month now. The watch has crashed 3 times during that time. I can sense it will crash by the time it takes to save an exercise. When it takes over 10 minutes, then I know the watch is about to crash. THen its a hard reset and all the data and connectivity has been lost. It is not a huge hassle but surely for a new watch, it should not crash so ofen ? My old Ambit never crashed in the 5+ years I used it !
      Has anyone ele encountered the same problem with the Suunto 5 unit ?
      • sartoricS Offline
        sartoric Moderator
        Did it always crash when saving ?
        Some people had similar issue (just search for “watch crash”) but maybe in different situations and in some cases it was related to the watch connected to both app while using it.
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.11.12 beta
          Cornell Tsiang
          Thats very interesting. Yes, it crashes during the saving mode. I will check the thread you mentioned. Thank you
          Mff73M Brad_OlwinB 2 Replies Last reply Reply Quote 0
          • Mff73M Offline
            Mff73 @Cornell Tsiang
            @Cornell-Tsiang
            Do you have set to on, the feeling option?
            If no, try to put it on before any bigger investigation. This never ending saving may be solved with feeling on.
            SSU (retired), SV1, SV2
            Wife : S9PP
            SA: Always the latest beta :)
            Android + Galaxy S205G
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @Cornell Tsiang
              @Cornell-Tsiang This should not be happening and I have never had mine do this. I assume firmware is up to date?
              Vector/T6c/Vertical 2 Ti
              Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 1
              • Łukasz SzmigielŁ Offline
                Łukasz Szmigiel @Brad_Olwin
                @Brad_Olwin yeah, this isn’t normal. I’ve had my S5 hang once while trying to save POI and soft reset was enough to keep it going. Never had any problems since.
                S9PP 2.50.28
                  @Cornell-Tsiang said in S5 keeps crashing:
                  I may not recall correctly but I thought this issue was fixed in a firmware update.
                    Cornell Tsiang
                    I spoke with the Suunto support line. According to their records, the issue is the fact that I use a 3rd party infrared HR monitor (Polar OH1). The remedy is, apparently, in line with Mff73’s recommendation to enable the feelings option. I will try that over the next few weeks and see if it works. Suunto has kept the ticket open and I will report back to them after 2-3 weeks. I did try it this morning with the feeling option enabled and no problem. However, as the crashes happen intermittently, I need a few weeks to make sure.
                    WiredonionW 1 Reply Last reply Reply Quote 4
                    • WiredonionW Offline
                      Wiredonion @Cornell Tsiang
                      @Cornell-Tsiang I had the exact same issue with my OH1 and S5 a few months ago and enabling the feeling option sorted it out.
                      Register Login
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
