    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    resources and stress level screen
    42 Posts 9 Posters 5.3k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • nassoscN Offline
      nassosc
      Hello
      I really do not understand the resources info on my S9
      what is it all about?
      with about 2hr of recovery from my last workout and mid day (an easy day) resources were 25%. I feel they should be around 70-80%
      after my workout, 40 mins of running I now have 1% so according to this i think I would be barely move or drag my body to bed.
      In theory tomorrow morning it should be 80%? 90%?
      how are resources calculated? and what are value has this info? I just dont get it…
      • isaziI Offline
        isazi Moderator
        Here you can read about Firstbeat’s body battery. Not sure if Garmin and Suunto use the exact same Firstbeat algorithms for this, but it’s a good read.
        Blog: isazi's home
        sartoricS 1 Reply Last reply Reply Quote 0
        • sartoricS Offline
          sartoric Moderator
          @nassosc
          Check this
          https://www.firstbeat.com/consumer-product/suunto/
          SVTS - 2.48.16
          SSSWHR BARO Amber - 2.8.32
          Samsung A5 2016 - Android 7.0
          Samsung A33 2022 - Android 15 - One UI 7.0
          Suunto App Android 6.6.5 beta
          Suunto App IOs 3.7.1 (21291) beta on MBP M1 Max
          • sartoricS Offline
            sartoric Moderator @isazi
            @isazi said in resources and stress level screen:
            Should be
            SVTS - 2.48.16
            J 1 Reply Last reply Reply Quote 0
            • nassoscN Offline
              nassosc
              @isazi @sartoric Thank you guys.
              • J Offline
                jannis Bronze Member @sartoric
                @sartoric said in resources and stress level screen:
                Should be
                No, they don’t. The resources are on the Suunto watches clearly too low always, so they must have a different algorithm. I still have a vivoactive 4, and in the morning the body battery was 90-100 %. On suunto it seldom is more than 50%. About 2 pm I have mostly 0 %. So right now the resources are quite useless, as they have a big problem to measure periods of rest. Another problem is that with charging it again shows 50%. Really, these problems exist for long time, but Suunto somehow don’t solve them with Updates…
                Dimitrios KanellopoulosD sartoricS ? 3 Replies Last reply Reply Quote 1
                • Dimitrios KanellopoulosD Online
                  Dimitrios Kanellopoulos Community Manager @jannis
                  @jannis typically this happens if the user has set the rest HR to min HR
                  Creator of Quantified-Self.io
                  youtube.com/c/dimitrioskanellopoulos
                  https://instagram.com/dimitrioskanellopoulos
                  https://www.strava.com/athletes/7586105
                  Q 1 Reply Last reply Reply Quote 1
                  • sartoricS Offline
                    sartoric Moderator @jannis
                    @jannis said in resources and stress level screen:
                    No, they don’t.
                    How do you know ?
                    I’m not saying that there isn’t something that is not working properly, I’m just saying that the algorithm should be the same as I don’t think that Firstbeat deliver different algo for different brands
                    https://www.firstbeat.com/en/consumer-feature/body-resources/
                    Algorithms do math based on data feed. If inputted data are different, so it will be the result.
                    SVTS - 2.48.16
                    • Q Offline
                      QwertyBoy @Dimitrios Kanellopoulos
                      @Dimitrios-Kanellopoulos said in resources and stress level screen:
                      So, how can I know my resting pulse?
                      • ? Offline
                        A Former User @jannis
                        @jannis I think @Dimitrios-Kanellopoulos is partially right: how the rest HR in your vivoactive compares to a minimum HR registered throughout a day, or most likely during a night’s sleep?
                        Also consider additional three factors:
                        • Your Vivoactive RHR gets updated daily based on your sleep and early morning heart rate; the RHR in your Suunto watch is set
                        • Vivoactive is measuring HR continuously while S9 does only periodic measurements throughout the day
                        • We don’t know much about HRV recording from Valencell sensor in S9, or how it is implemented; Garmin took quite some time to work this out. The foundation for Body Battery/Resources is daily stress, which is built on top of changes in HRV relative your baseline
                        So, the algorithm may be exactly the same, but implementation matters – from a very different sensor to a very different data series fed into algorithm to the bounds that are used to establish your baseline
                        J 1 Reply Last reply Reply Quote 1
                        • ? Offline
                          A Former User @QwertyBoy
                          @QwertyBoy You can try measuring it immediately upon waking up, assuming you don’t have to run to the bathroom 😂 Or provided you have a 24/7 HR graph from somewhere, your minimum HR during a waking period will be your RHR.
                          Q 1 Reply Last reply Reply Quote 0
                          • J Offline
                            jannis Bronze Member @Guest
                            @NickK The Sunnto 5 says the average HR during sleep is about 63 bpm, and the Garmin Vivoactive says the rest HR is about 56.
                            • ? Offline
                              @jannis Well, average HR isn’t a minimum/rest HR. One number doesn’t preclude the other in your case.
                              If you had a workout late at night, it would take several hours for your HR to settle down during sleep. So, your average may be high but your minimum could still be much lower. For example, my average was 45, and my minimum for the same night was 41. As measured by the same device. Vivoactive and Suunto 5 will have further differences simply because the latter isn’t measuring continuously.
                              J 1 Reply Last reply Reply Quote -1
                              • J Offline
                                On the Suunto 5 the options show the rest HR value as 60 bpm. To what should I change it then?
                                • J Offline
                                  @NickK said in resources and stress level screen:
                                  The minimum HR for today Suunto: 54 bpm
                                  For the Vivoactive 4, the last time I measured was 50 bpm.
                                  • J Offline
                                    Resurces of today: IMG_20200219_171911.jpg
                                    • Q Offline
                                      QwertyBoy @Guest
                                      But like Dimitrios-Kanellopoulos said, that min HR is not the rest HR. So, it is incorrectly to specify the min HR. So, that’s why I want to know my rest HR.
                                      sartoricS ? Dimitrios KanellopoulosD 3 Replies Last reply Reply Quote 0
                                      • sartoricS Offline
                                        sartoric Moderator @QwertyBoy
                                        @QwertyBoy
                                        Take a look at this
                                        https://runalyze.com/glossary/resting-heart-rate
                                        One method to measure it, is to check it just after you wake up, still laying in the bed.
                                        SVTS - 2.48.16
                                        ? inkognitoI 2 Replies Last reply Reply Quote 0
                                        • ? Offline
                                          @QwertyBoy Your rest HR will be fairly close to your minimum HR. In fact, there’s a school of thought that says your sleep minimum HR is your rest HR.
                                          Search around in the forums… I had this exact argument with @Dimitrios-Kanellopoulos about resources not getting to 100%, though in my case it was about 85-95%, so not too bad. I posted comparison of my minimum and rest HR. I know, I know… Everyone’s physiology’s different.
                                          My larger point though: we are splitting hairs. Vivoactive, and other Garmin devices, has a very different OHR sensor from Suunto, has a different sampling rate, different handling of HRV estimation, and Garmin’s RHR isn’t fixed but changes from day to day and sometimes intraday. You can’t simply expect the same or even similar results under these circumstances.
                                          • ? Offline
                                            A Former User @sartoric
                                            One method to measure it, is to check it just after you wake up, still laying on the bed.
                                            That’s exactly what I told him. Bathroom run notwithstanding. Which is why I constantly croak about 24/7 HR. You don’t have to measure anything and can visit the throne room as much as you want. All HR events of note will be conveniently recorded and ready for review.
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
