    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7
    Scheduled Pinned Locked Moved Suunto 7
    1.1k Posts 110 Posters 528.7k Views 99 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • EgikaE Offline
      Egika Platinum Member @stromdiddily
      @stromdiddily yes, you can filter apps working for any device you have active in your Google account.
      stromdiddilyS 1 Reply Last reply Reply Quote 0
      • stromdiddilyS Offline
        stromdiddily Gold Members @Egika
        @egika said in Suunto 7:
        Hi Egika,
        That seems to only work if you already have an S7 🙂
        Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
        User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
        • EgikaE Offline
          @stromdiddily correct!
          Your golf app is not compatible…
          stromdiddilyS Jamie BGJ 2 Replies Last reply Reply Quote 1
            @egika Thanks!!
            • Jamie BGJ Offline
              Jamie BG Bronze Member @Egika
              however Hole 19 is.https://play.google.com/store/apps/details?id=com.hole19golf.hole19.beta
              There is a free version and a monthly subscription service which provides additional features.
              Not sure what the impact is on your battery life.
              • pilleusP Offline
                pilleus
                A barometric altitude app without using the location service. Usable as standalone app or complication in a watch face. I like the simple app and the possibility to calibrate to a known altitude.
                https://play.google.com/store/apps/details?id=com.wachete.wearaltimeter&hl=de&gl=US
                https://www.instagram.com/moves.are.life/
                Suunto Vertical Black Lime
                Suunto 9 Peak Pro Black
                Suunto Spartan Ultra Stealth Titanium
                giulioG 1 Reply Last reply Reply Quote 0
                • giulioG Offline
                  giulio @pilleus
                  @pilleus
                  Whats the name of your watch face?
                  I like
                  pilleusP 1 Reply Last reply Reply Quote 1
                  • pilleusP Offline
                    pilleus @giulio
                    @giulio
                    https://play.google.com/store/apps/details?id=fr.thema.wear.watch.quante&hl=de&gl=US
                    • SteffS Offline
                      Steff
                      I post here as a follow up on this post because it’s not related only with the battery anymore.
                      Yesterday I did another hike, 6h10min, 10sec GPS, airplane mode, route loaded with 2 waypoints.
                      The good news is that it used only 7.29%/hour, considering that in the first hour it used 9% (I switched to 10sec GPS after 20 minutes and I got many off route notifications at the beginning) and after that 6.5%/hour.
                      So, it can easily last 14-15 hours.
                      The bad news is that 10sec GPS + FusedTrack is a total mess.
                      The route which had 15.37km it was tracked as 18.68 km by the S7, 21.5% more distance.
                      Of course, the autolaps were also totally wrong.
                      This is the route
                      And this is what was tracked by the S7 with FusedTrack
                      If you zoom in, it’s a total mess, and surprisingly it’s more mess on straight lines.
                      And 2 instances where was totally off
                      As a comparison, this is what the same route looks on a Samsung Galaxy Watch Active 1, a 3 years old device and 3 times cheaper than S7, which used 72% of battery for the same track
                      17.28km, 12% more than the actual route.
                      This is without high accuracy mode enabled(not sure what that does, but it cuts the battery in half)
                      Also, the exact same route tracked with Huawei Watch GT2, again a devices 3 times cheaper than S7, which used only 25% of battery!!!
                      It’s split in 2, because I accidently stop it.
                      16.57km, only 8% more than the actual route.
                      I’m very disappointed with the S7.
                      I bought the S7 for mainly 3 purposes: daily wear, hiking and very rarely running.
                      For daily wear is far from ideal but let’s say that is ok.
                      Wear OS is more than enough for me, but with 1.5-2 day of battery means that I have to charge it daily to be sure that I don’t run out of battery on the second day.
                      For hiking it’s a total failure.
                      If I use 1 sec GPS I’m limited to 5 hours of GPS.
                      If I use 10 sec GPS I get almost unusable results.
                      Maps and navigation are very nice, but again almost useless with a 4-5hours battery life.
                      Running it the only thing ok.
                      I moved from devices like Samsung Gear S3 or Huawei Watch GT2 hopping that a device from a company with great sports experience will provide more reliable results and in fact I get much worse results.
                      When I got the S7 I had to choose between it and Garmin Venu.
                      I choose the S7 mainly because I find Venu to be too small at 43mm.
                      Now the only thing that is keeping me to switch to Venu 2 is the fact that I loose 30% if I sell the watch, and that the Venu 2 is still expensive being released very recently.
                      isaziI Jamie BGJ 2 Replies Last reply Reply Quote 1
                      • isaziI Offline
                        isazi Moderator @Steff
                        @steff are you sure those other watches do not piggyback on the phone GPS?
                        Blog: isazi's home
                        SteffS 1 Reply Last reply Reply Quote 0
                        • SteffS Offline
                          Steff @isazi
                          @isazi don’t know what’s the normal behavior for the Huawei GT2 but I’m sure that it didn’t shared the phone GPS because I remember I had it disconnected.
                          For Samsung I think they share the phone GPS, but does it even matter? At least with them I have an option to obtain some usable results and I always take my phone with me, especially on long hikes.
                          Is there an option to share the phone GPS on S7? Because I will gladly use it.
                          Not only that it does not have this option, but if I leave it connect to my phone I loose another 2-3 hours of battery.
                          • EgikaE Offline
                            Egika Platinum Member @Steff
                            @steff I think “good” GPS is the issue here together with the hiking mode.
                            Suunto states: “When running or cycling, FusedTrack™ is used to improve tracking quality.”
                            So in hiking mode FusedTrack maybe is not used and you just end up with a 10s GPS fix.
                            If you not already had a watch, for day-long hikes I would always recommend the Suunto 9B anyway! I have both the S9B and the S7 and for single oder multiday hikes I am taking the S9 with me.
                            I don’t have to care for battery consumption at all and can use best GPS.
                            The S7 stays on my arm during my daily life and for the casual weekend run or afternoon activity.
                            SteffS 1 Reply Last reply Reply Quote 1
                            • SteffS Offline
                              Steff @Egika
                              It’s very possible, I remember that I tested the FusedTrack with running profile, but walking not running, through the city, and it was nowhere near as messed up.
                              Probably the FusedTrack algorithm works best after a certain speed, but I don’t understand why Suunto are not enabling it for all profiles.
                              Worst than without it I don’t think it’s possible
                              Or I can get a Venu 2 and have a single watch for both daily wear and day hikes 😀
                              I know the smartwatch capabilities of Garmin are not comparable with WearOS, but for what I need(and I think most people also) in 90% for situations (notifications, payments, music) Garmin it’s enough
                              • EgikaE Offline
                                @steff correct. No need to stick to Suunto if the grass on the other side of the river is greener for you 🙂
                                • Martin VrskaM Offline
                                  Martin Vrska @Brad_Olwin
                                  @brad_olwin Hi, This morning, after updating Google Play services in the watch, a GPS icon appeared that had not appeared before. Does anyone have it too? Thanks. screen.png
                                  Suunto Vertical 2 - Arctic Gray - 2.56.28
                                  Suunto Spark
                                  Suunto Vertical - Steel Black, Strap Canyon Orange - 2.37.34 - SOLD
                                  Suunto 9 Peak Pro - Titanium Sand - 2.22.60 - my wife
                                  Google Pixel 9a - Android 17
                                  Suunto App 6.13.6 beta
                                  Nigel Taylor 0N 1 Reply Last reply Reply Quote 1
                                  • Jamie BGJ Offline
                                    Jamie BG Bronze Member @Steff
                                    @steff
                                    I am in a similar but different boat.
                                    I have bought a Fenix 6x Pro (solar) because I wanted what I had as close to possible as the S7 but with better normal battery life.
                                    From what I have seen there doesn’t seem to be a major difference in terms of tracks, distance, altitude etc - Fairly close, but then so far max distance i have used is 4km but done quite a few of those and all fairly close to my S7 on same routes.
                                    • SteffS Offline
                                      Steff @Jamie BG
                                      @jamie-bg yes, unfortunately the perfect device does not exist.
                                      Before the S7 I always said that the perfect device for me would be a Fenix with amoled and touchscreen.
                                      S7 and Venu are the only ones which come close to this.
                                      I still think that S7, even with the current hardware has a lot of potential.
                                      Maybe a 5sec GPS FusedTrack with 8-10 hours of battery and enabled for all profiles will solve all my problems but I doubt that this is something which Suunto would ever consider.
                                      Until then, I think I will go to the other side of the river where the grass is greener, like @Egika said 🙂
                                      isaziI 1 Reply Last reply Reply Quote 0
                                      • isaziI Offline
                                        @steff said in Suunto 7:
                                        Hopefully you will not discover that cows are dead on the other side too. And water is poisonous 🤣
                                        Blog: isazi's home
                                        • SteffS Offline
                                          Steff @isazi
                                          @isazi if the water is poisonous, both sides of the river will have dead cows 🙂
                                          Depends on which side of the river has fewer dead cows 🙂
                                          isaziI 1 Reply Last reply Reply Quote 2
                                          • isaziI Offline
                                            In fact I said “too” 😉
                                            Blog: isazi's home
                                            Jamie BGJ 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
